Question about Spa Parts Plus GFCI, Circuit Breaker, 40 Amp
Ge 50amp gfci trips, worked great before I bought it
Bought a used saratoga 10years old, worked great when i check it out, turned up on its side to move it, let it set for 2 months, hooked it up and it tripped the gfi, unplugged ext. units, stayed on, any thing I plugged in it tripped. replaced gfi with another ge, this time the light and the circulation pump would work without tripping the gfi. if I tried to plug in the pump or the blower, gfi trips. everything is dry under there, and has been. does the square D gfi work better, less sensitive, than the GE's? I now thinking that I may need to clean all connections to those motors, possibly corrided? FYi, the circulation pump is running with the heater and it came up to temp that I set with the control pad..
  • hondomoore Oct 21, 2008
    The surge should be well below the rating of the breaker, the pump does not turn on till one minute after the circulation pump turns on. What I did to get this going is to clean the ground between the pump and and balboa ground bar and that seemed to keep the GFI from tripping, so far so good!
    thanks anyway
    Kevin
    Sergeant:
  • 352 Answers
Hi hondo,
When an electric motor kicks on there is an in rush current called FLA(full load amps), it is usually about 125% of rated circuit amperage. Try a 2 pole 60 amp gfci circuit breaker and see if that solves your issue. Going up to this amp breaker will not be a fire hazard or cause any anomalies.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Posted on Oct 19, 2008
Laing circulation pump for Saratoga spa. Put in new pump but now tripping GFCI.
Check your wiring! If it wasn't tripping before and now it is, you have your hot and neutral crossed or neutral and safety ground crossed. You can not draw current via the safety ground, that is what caused the GFCI to trip, it senses current being drawn in that wire.
Sep 29, 2012 | Laing Thermo E10-NSHN1W-19 3/4" Barb...
Fisher and paykel trips gfci
probably ur pump.How old is it?kijji u prob find used washer cheap
Aug 12, 2012 | Whirlpool Washing Machines
Hello,I have an old jacuzzi vectra II hot tub (1988) 120 volt.the gfci on the unit trips every time the pump is on low speed with the thermostat calling for heat. there is no trip when there is no demand...
hi,
ok so when the pump is on high and the heater is running it doesent trip? you didnt say if it did. undo the heater leads so the pump is isolated completely. run the pump on the control centers gfci and see if it trips. if it does then try wiring directly - with an extension cord to a plug with a gfci in your house and see if it trips the gfci in your bathroom. if no trip inside house then bypass tubs gfci and run it with heater and pump through your bathroom gfci. if no trip then try and replace the tubs gfci, it gets pretty humid in the control center and gfci's have a semiconductor which which do fail after years of rough duty like that. if it trips the gfci in your house with the heater again it has a cracked heater element. craigslist always has old hot tubs and parts. you might have to buy a whole used old hot tub but that may be cheaper than a new heater box.
later
jm
Feb 22, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I bought a new GE 20 amp GFCI circuit breaker and installed it to a new outdoor curcuit with two separate outlets. everything seems to work fine - polarities ok etc. connnected the white gfci line to the...
You can buy an inexpensive GFCI tester for as little as $10-$12. A better one with several mv settings will cost you a bit more. This way you can test this circuit and even GFCI receptacles. Then you'll know for sure if your breaker is working.
Nov 14, 2010 | General Electric 20 Amp, 1 Pole Thick Type...
GE Profile 24, 15 years old: Occasionally, it trips the house ground fault circuit interrupter (GFCI). Tripping happens about 5 seconds after plugging to mains. For a week the problem disappeared, now it...
The motor (compressor) is pulling too high amps on the startup ... this tripps the GFCI...
The compressor cap is going bad or the motor is going bad...replace the realy and cap first...
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 28, 2010 | Refrigerators
Frig cools works great all day then trips the gfci
Hi Sturkle;
Does this happen say- every 6-8hrs? If so you may find the defrost element has a short, or defrost timer is faulty. Defrost element is located in the freezer compartment, Time located an back of fridge.. Use a qualified person when playing with electrics...Cheers
Mar 29, 2010 | Whirlpool ET8GHMXLQ / ET8GHMXLT Top...
Trip switch of breaker?
First of all, did you disconnect your Range prior to working on it. This is something that should be a priority when working on your range. Or, you can shut off the breaker, which is located in your house electrical panel. It's most likely a 50amp 2 pole breaker, and could also be in a sub - panel in some houses. Check this out first before continuing. And, if it is tripped, turn the breaker to the off position and leave it off until you replace your heating element. Once completed, then you can turn it back on. Try this, and if it works - great! If not, will try something else.
Mar 13, 2010 | GE Spectra JBP78 Electric Kitchen Range
Whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Keeps tripping circuit breakers bunn NHb
Hello
Coffee makers have a heating unit in them which draw a lot of current. If it is on the same circuit as refrigerator, toaster and other it will trip the breaker. Also, some breakers are more sensitive than others. Have an electrician run a separate circuit for the coffee maker outlet. Try running it in the dining room outlet, which I hope is separate from the kitchen outlets. Is the house old? Older homes have a lot of mixed up wiring.
John
Aug 09, 2009 | Bunn NHB Coffee Maker
Spa Parts Plus GFCI, Circuit Breaker, 40 Amp Logo
248 people viewed this question
Top Spa Parts Plus Electrical Supplies Experts
Steve
Gene Haynes
Are you a Spa Parts Plus Electrical Supply Expert? Answer questions, earn points and help others
