SOURCE: After installing Windows 7, my SamSung SyncMaster
Yes,Because Windows 7 is taking the higher amount of Ram.So the videos will be very poor and also system will be slow down.You must increase your Ram to 1 GB. (or) Use windows xp.
Thank u...
SOURCE: is there a new windows
try reducing the refresh rate of the screen. I Hope the Driver for the moinotor is installed !!
But if it is intermittant..
Then Monitor may be going through normal ageing.
Rate this solution, Write a comment to keep in touch.
SOURCE: I have a Samsung SyncMaster
I've installed Windows 7 on some pieces of junk and found it to work great. The downside to installing it on older or under-performing machines is that you probably will not get all the bells and whistles that 7 comes with like the Aero features and probably will just hold you to the windows classic theme. But functional features like pin-to-tab will work.
SOURCE: My Samsung Syncmaster 2333SW started splitting the
Welcome to Fixya
First this to check if the graphics card is the one doing this. Test the issue usng different monitor. if same thing will happen then you nee to replace the video card or have the driver resintalled. If you are not experiencing this problem using a different monitor then you have a problem with your LCD. Try to drain the elctrostatic charge of the LCD's mainboard. Unplug the power cord from the wall and press and hold the power button for 15 secs. Plug it back in then turn on the monitor. if same thing will happen then you need to have the LCD serviced by samsung tech.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
