Question about Nikon COOLPIX L3 Digital Camera
NIKON CAMERA LENS ERROR PROBLEM
When i open my camera lens error appear in the monitor and now the lens stuck.
  • 1 more comment
  • Anonymous Oct 22, 2008
    lens error in Nikon coolpix L2
  • chance2929 Nov 07, 2008
    My
    does the Same thing, i get a opening screen and then Lens Error message and Lens is stuck....Pissin me off
  • sanatogaje Dec 07, 2008
    I have the same problem. I drop my camera at a concert and the lens got stuck. The lens has since been able to go back in, but the camera still reads lens error. I wanted know if there was a way to reset the memory of the camera because I don't think that there is anything internally wrong with. Any solutions would be appreciated!!!
I had the same problem that everyone has my L12 was dropped from about 3 feet. I went to get it looked at by a dealer and they said it would cost 180 bucks. They said it was not worth it. Ok this is what I did to fix it. Mind you it can be a little difficult for the not so tech savy. First remove the batteries, then take all the screws out on the outside of camera, dont forget about the 2 under the battery cover and the one in the AV port. Carefully use a small flat tip screwdriver to pry the two plastic covers off. The hard part is over, now pull up the LCD, it is stuck on by double face tape. There is a silver cover 3 more screws to remove. Ok now for the easy part. Where the screen attaches to the motherboard there is some black tape low and behold under it is a connector. On my camera it was not connected very good. I pushed it back on and put it all together and now it works. 180 bucks saved. Hope this helps.
Posted on Dec 30, 2008
BUY A CANON THATS WHAT I HAVE DONE
Posted on Nov 03, 2008
My Nikon coolpix l3 digital lens is stuck and there is an error message. Please help
Posted on Nov 13, 2008
Nikon Coolpix S5 camera. Lens shutter remaining open.
From the manual: "Turn camera off and then on again. If error persists, contact retailer or Nikon representative."
Nov 18, 2009 | Nikon Coolpix S51c Digital Camera
Error Message
Try to take off the battery and reset the camera. You can also try to remove the lens and check the mirror opening..see if there is some thing stuck there. You can try to click the shutter while the lens is removed. If this procedure didn't work I suggest calling Nikon for further repairs.
Sep 25, 2009 | Nikon D60 Digital Camera with 18-55mm lens
When I press the on/off button to open my camera a message appears stating 'Lens error' and the lens automatically opens and closes a couple of times before closing so I cannot take any photographs. How...
Hi!
Most likely the focus is stuck. Could be sand or some dirt inside focus gears. They're very small for these lens which are used in many Nikon, Olympus, Casio and other cameras so even one small piece of sand can block the focus system. The only way to fix it to take the camera and lens apart and clean it.
Sorry for the bad news. I repair cameras every day and you can trust me - I know what I'm talking about.
Tom
Sep 23, 2009 | Nikon Coolpix S210 Digital Camera
Today lens error appeared at my nikon 220
turn your lens with your hand gently as the lens rotate when it stucks..
thats what i did when this error came//
dont forget to rate
Sep 07, 2009 | Nikon Coolpix 2200 Digital Camera
Lens error: Lens is stuck open when I power on.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 29, 2008 | Nikon Coolpix S50c Digital Camera
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Nov 19, 2008 | Nikon COOLPIX L3 Digital Camera
Nikon coolpix p50, lense error, camera won't work lens stuck.
May 28, 2008 | Nikon COOLPIX L18 Digital Camera
Lens is stuck open says lens error nikon coolpix l6
when the camera is turned on it displays "lens error". I can't take a picture and i can't access my pictures on the camera.
Apr 29, 2008 | Nikon COOLPIX L18 Digital Camera
Nikon Coolpix L11 Error....
Assisting the lens gently when it opens and shuts may work.
Dec 28, 2007 | Nikon Coolpix 5700 Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
325 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
