Question about Sony Ericsson T610
Recieving / answering phone
If i ring someone they cant hear me or if they ring me they cant hear me
I had the exact same problem. basically (sounds a bit weird) but it happens if you drop your fone and the only way to let people hear you again is by dropping it again! so whenever you drop your phone you have to drop it again to fix it.
Posted on Sep 20, 2007
My phone has lost its sound and when someone rings it will only vibrate then when i answer, i can hear them but they cant hear me, I have checked and it is not on silent.
First make sure the phone is not on silent,
Try changing the ringtone, go into phone->options->sounds, make sure type is set to ring, if so select a different ring tone.
May 31, 2011 | HTC Touch P3450 Smartphone
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
Samsung A707 Problems
best thing to do, so you don't waste your money is buy a brand new phone.it will save you trouble, headaches, time, and money
May 01, 2009 | Samsung SGH-A707 Cellular Phone
Lucent Partner 18
Please contact your Avaya Vendor to do programming
Sep 04, 2008 | Lucent PARTNER18 Corded Phone
No sound
I'm having the same problem. However, I have discovered that it is something to do with the upper slide part of the phone. For some reason, if you push the slide down just a bit when you're trying to play music the sound comes on. Not sure how to fix this problem other than scrap the phone.
Aug 09, 2008 | Samsung SGH-U600
Lexmark printer 8350
Okay for starters, you need to check to see if that fax machine is automatically answering the phone when it rings. you can check to see if it is trying to recieve by call that phone number from another phone and listen if it answers and when it does, does it make a high pitched squelling sound that varies in pitch.
if it does then it should be working ok, if not then you must program your recieve mode to automatically answer.
you can also check to see if it's sending by doing the opposite: put a sheet of paper in the machine to fax and dial your cell phone or other number, when it rings pick it up and listen for the high pitch squeel, if it works then your fax is working properly.
Thank You,
Mikey
Apr 04, 2008 | Office Equipment & Supplies
We cant hear the phone ring in our office now!
Call your phone from another phone. Don't answer it. Press you volume up/down button. Up makes the ring louder and down makes the ring softer. I bet someone turned you ring volume down. Once it is set it stays there. God Bless. Jerry
Mar 24, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Not able to talk
have the phone check fully the microphone needs to be replaced and the earpiece as well........the housing by the earpiece might be block so take a small flatbit screwdriver and have try to to clear it.
Nov 06, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Sony Ericsson T610 Logo
217 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
