Question about Frigidaire FSC23F7DSB Stainless Steel Side by Side Refrigerator
Water dipenser broke
The actuator of my water dispenser is broken i have the spare part but i'm not able to remove the drip tray what is the solution
  • rrodrigue340 Apr 15, 2010
    water dispenser is broke have replacement how do i replace
  • Frigidaire Master
  • 2,651 Answers
Drip tray pulls foward (might take some serious finger strength but itll pull foward, revealling 2 phillips screws that will release the dispensor facade. before attempting i would unplug the harness atop the freezer door, you dont want to short circuit boards behind dispensor.
Posted on Oct 19, 2008
My frigidaire side by side is about 13yrs old and we noticed no ice.
the water won't work at all either.
Posted on Apr 28, 2010
Fridgidaire refrigerater dispenses water
The part number you are going to need is 241734302. This is the water valve located in the back of the machine. Whats going on is the solenoid for the dispenser isn't seating properly and when the icemaker calls for water the pressure is enough to push through and come out the door as well
May 24, 2012 | Refrigerators
Just had a new part # 241734301 installed, because the old one broke during a move. It appears to work fine although the water continues to dribble for a while after filling a glass. Also, the water will...
It seems as though the water hoses are reversed, Ice maker line and water dispenser line are probably switched, this would explain why the water comes out the door intermittently. It's probably trying to dump water into the ice tray but its coming out the door.
May 22, 2011 | Frigidaire FSC23F7D Side by Side...
Water drips from dispencer
make sure if the water tray in the dispenser if not over flowing. or there mite be more frozen ice formed in and around the dispenser.
defreeze it and drain the water wash it and fill the water tray.
if this not your problem. Then check if the dispenser is not broken. live consult with a Refrigerators consultant Thanks for rating Good luck
Dec 24, 2010 | Refrigerators
Water dispenser lever is broken
1st, unplug or turn breaker off for refrig. 2nd, remove the slide out drip tray, 3rd, remove the 3 bottom screws at the bottom of the dispenser bezel (behind the drip tray). 4th, remove the bezel (slide up about 1/4" and pull forward, gently), WHEN DOING THIS BE VERY CAREFUL YOU DON'T ACCIDENTLY UNPLUG THE CONTROL BOARD FROM THE MAIN BOARD. 5th, remove the 3 screws holding the dispenser mechanism in place. 6th, remove the water dispensing hose from the dispensing mechanism., 7th, carefully unplug the power supply to the main board. hold down the clip to do this. 8th, with the dispenser out, remove the water dispenser lever plug from the coil board, 9th, remove the 2 screws for the metal hold downs for the lever pivot.
chances are, you will have difficulty removing the water hose from the dispenser unit. I did. I also had a harder time trying to get it back in. The factory hose is pretty rigid and I figured there mus be a better way. I had some 1/4" clear hose from home depot. I got a piece of 1/4' tubing and made a splice from the factory tubing to the clear, flexible tubing. The flexible tubing allows you to have additional tubing to play with and makes the job much, much easier. good luck
Apr 07, 2010 | Frigidaire Professional Side By Side...
Thanks for your response Woodchuck 789- it is greatly appreciated. I tried checking the dual inlet valves as you suggested - switching electrical connectors and checking output, etc. The valves seem...
its hard to ck a valve that drips / and the ice maker may be over filling . if ice cubes are stuck to gether it is over filling . if driping . it may be a bad valve that does not shut off tight. I would replace the valve .. ****
Jan 07, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Danze faucet and soap dipenser drip
it could just be a defective unit,it is not unheard of.i have run into this myself alot of times.if you can take it back and get another unit.
Jul 08, 2009 | Plumbing
Water dipensers drips
replace the water disp solenoid,its located at the back of the fridge where the water line connects
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Broken water actuator
Hi this is tech crazy
the solution to the problem is
You should be able to replace this part yourself. Follow these steps to replace the water actuator:
  1. Unplug the refrigerator to completely disconnect electrical power. Turn off the water supply to the refrigerator.
  2. Remove the drip tray (Key 23 in the image below) from the bottom of the dispenser.
  3. Remove the screws (Key 43) from the bottom of the dispenser module cover (Key 4). NOTE: You model may not have screws at the bottom of the dispenser cover. If not, push down on the top of the dispenser cover and pry out on the bottom of the cover with a flat tip screw driver to remove it.
  4. Pull to dispenser module cover up to release the top clips and remove this cover and set it aside.
  5. Remove the screws (Key 17) that are on each side of the dispenser module (Key 8).
  6. Carefully pull the dispenser module out slightly from the door. It will have wires attached. Pay attention to how the water tube and the ice door assembly are positioned. Pull this module out far enough to remove and replace your water actuator (Key 24).
Reverse the above process for reassembly.
Jan 25, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Water Actuator is broken.
I had the same problem with my water dispenser and since they were willing to sell me a part but provided no directions and I couldn't locate any I decided to make my own for those who might need them. Here is a link to a PDF I made, hope it helps.
Before starting this job I would also like to warn all to please be save and UNPLUG the fridge. The whole job took me less then 30 minutes and I doubt anything will go bad in that amount of time.
Jan 13, 2007 | Frigidaire FRS26R4A Side by Side...
Handle replacement for water dispenser
Melissa, you don't get it from the inside. Remove the drip tray by pulling it out. You should see two screws holding the dispenser cover on each side of the bottom. Remove these screws and push up on the dispenser cover, there's 3 hooks on the top. Unplug the harness from the dispenser board and get the cover out of the way. Now is the hard part. You have to get at the module itself that holds the paddle. These can be a fight. If you go to, go to appliance then parts and post your model number you should get a breakdown of the dispenser that will guide you. back
Dec 09, 2006 | Frigidaire FRS23R4A Side by Side...
Frigidaire FSC23F7DSB Stainless Steel Side by Side Refrigerator Logo
528 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
