Question about Cameras
When I turn on my camera it automatically turns by itself with new batteries
  • Cameras Master
  • 4,738 Answers
Are you still using alkaline batteries (or worse yet "Super Heavy Duty")? If so, alkaline batteries just don't have the power for more than a few pics in a digital camera. Some may have reached their shelf life, and though brand new may even have problems just powering startup of the camera.
Digital cameras for the most part should be used with rechargeable NiMH batteries. Retailers sell these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Posted on Oct 19, 2008
When you turn on few second its automatic turn off?
sounds silly but try a new battery my wife and i have the same battery's in our cameras one of us charges theirs the other don't when she has that fault she grabs my battery fits it and the camera is fixed .I hope its that easy for you the other problem she has had is sand in the lens protector if it is jammed the camera switches itself off clean it
Nov 10, 2011 | Canon PowerShot A3100 IS Digital Camera
Whenever I turn it on, it automatically turns itself off. The lens does not always withdraw. It is not the batteries, as this is the third set of new batteries I have tried in it.
The problem is in the system control board, either there is a fault in the systems board or it has detected an issue with the camera lens, it will require a camera technician to properly troubleshoot the issue.
Jan 12, 2011 | Kodak EasyShare Z710 Digital Camera
Everytime I turn on the camera, the lens start to zoom in and out for itself and then an "out of objective" warning message appears. then, it turn off automatically. What could possibly be the...
There is a capacitor dump that you can try.
Remove the batteries, wait 5-10 minutes.
With the batteries out, press and hold the power button for 10 seconds or so.
Put the batteries back in and your camera will start over (re-boot). You will know if it worked if you have to reset the date. But if that lens is really stuck you may be out of luck. The cost to repair it will exceed the cost of a new camera.
Regards 8ushy
Jan 04, 2011 | Nikon COOLPIX S230 Digital Camera
Camera turns off when you use telephoto lens camera turns off.
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
Apr 21, 2010 | Kodak EasyShare Z740 Digital Camera
When i turn on my Kodak EasyShare C913 Digital Camera it makes a werid sound and turns itself off. whats making it do that? and how can i fix it?
It is probably your rechargeable batteries are not holding their charge and therefore the camera is not receiving enough power to start. The whirring would be the camera lense attempting to open. When it can't get enough power it will automatically shut off.
As a first step try removing the batteries and replacing them with completely new ones. Make sure they are fully charged.
If this doesn't sort the problem out it may be something more serious which would probably require a technician to look at it.
Nov 16, 2009 | Kodak EasyShare C913 Digital Camera
I turn the camera on(new battery) & it automatically shuts off itself. Camera only a few months old. Now it won't go on at all. Also, zoom lens did not set itself back into camera, it's stuck in th...
Open battery door and shut it again, without removing the batteries. If this doesn't help to reset, change the batteries. Make sure they're lithium. If this still doesn't help, I'm out of ideas. Sorry!
Oct 05, 2009 | Kodak EASYSHARE Z1085 IS Digital Camera
SHUTS OFF BY ITSELF
yes,, when we charge the battery for a longtime. the battery's will automatically decrease, this is the reason the camera is getting turned off by itself, change your battery to make it work well.,, thank you.. plzzz rate me,,,
Jun 29, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Zoom error
Turn Camera off remove batteries for a few moments. Re insert batteries. Turn on will reset itself. Ensure you use correct focus settings as per instructions. If you dont use correct settings this problem will reoccur.
Oct 27, 2008 | Fuji FinePix S1000FD Digital Camera
I Have Kodak Easy Share CX7530 Camera and when I turn it on, it automatically shuts itself back off. First I thought it was the batteries but I have put new ones in and the same thing happens. Do you have...
What type of batteries are you using? A lot of times in Kodak cameras, regular alkaline batteries won't work. I would suggest using lithium batteries like the energizer e2 ones. They're a little more expensive, but they should solve your problem.
Jun 22, 2008 | Cameras
Olympus FE-115 : wont turn on..turns iself off!!!
I had the same problem and i called up cutomer support on 1300 659 678 (Australia) and they said that the problem may lie in your batteries. It was advised that you use Lithium batteries, and to avoid use of Alkaline, since they dont have the required power to operate the camera which is why it turns off right away. As to what type of rechageable batterires to use i am not sure, i think it was Nickel-metal-hydride (NiMH) batteries. Hope this solves your problem.
Sep 10, 2006 | Olympus FE-115 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
