Question about Zhone 6211-I3-200 Router
Configurar Router para otra empresa
No he podido configurar mi router 6211-I3-200 original de Edatel para que trabaje en Telecom, si alguien me puede ayudar se lo agradeceria muchisimo, mi correo es totumm@hotmail.com de antemano gracias.
4 Suggested Answers
SOURCE: Zhone 6211-I3-200
user: user
password: user
firmware update: www.zhone.com
Posted on Jun 30, 2008
serra_baby
  • 144 Answers
SOURCE: zhone linksys router
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
i have read the same problem on the supportrix forum and you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
Posted on Aug 07, 2008
SOURCE: My Zhone 6211-I2-302 is not listed on port forwarding router list
I have a Problem in opening port 81 :(
how can i open it
Posted on Aug 07, 2009
govinda123
  • 2260 Answers
SOURCE: I cant open port for Zhone 6211-I3-200 Router
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
Click Here
for more info
Posted on Dec 18, 2009
Buenas. compre un router marca D-Link modelo 600. quisera saber si es compatible con la Sony PCG 3A1M no logro que la lapto la acepte.
Le consegui esta informacion de paso por paso como instalar y configurar su router.. Por favor dejenos saber si esta informacion le fue de ayuda.. Pegue el siguiente link en su browser..
http://www.youtube.com/watch?v=LC8GemwkKvU
Si encuentra que esta informaci?n fue ?til a usted, por favor me valora y deja un comentario como esto me favorecer? a hacer el trabajo m?s libre para usted y para otros. Y permiti? por favor que s? si hay otra cosa con que podr?a ayudar usted. ¡Sin comentarios nosotros no podemos continuar ayudando... Gracias por utilizar FIXYA! Los saludos, Junior
Sep 13, 2011 | Computers & Internet
No se como acceder a la configuracion de mi router
Para entrar a las páginas de configuración, es necesario estar conectado al router. Esto puede ser con el cable de red, oa través de su adaptador inalámbrico. Inicie su navegador y escriba la dirección del router. Estas diferencias, pero para el router Linksys que se hará lo siguiente: http://192.168.1.1
A continuación se le pedirá un nombre de usuario y contraseña. Routers tienen un valor predeterminado para ambos. Para el Linksys, es el administrador de nombre de usuario y administrador de la contraseña. (Mira en el manual para la dirección del router y el nombre de usuario y contraseña por defecto.) Haga clic en Aceptar y estarás a su pages.If de configuración que no puede ver las páginas de configuración a continuación, la conexión de su ordenador y el router no funciona . Así que no culpar a su ISP! Es hora de verter sobre los manuales! Otra cosa que puede que tenga que hacer en las páginas de configuración es configurar la seguridad inalámbrica. Si usted no tiene la seguridad activada, cualquier persona dentro del alcance del enrutador inalámbrico podrá conectarse a él. Hay dos formas de seguridad que utilizan la mayoría de los routers inalámbricos, WEP y WPA. Lo que estamos haciendo aquí es encriptar sus señales con una llave. Con la seguridad inalámbrica activada, el router necesita su clave antes de permitir cualquier tráfico a través de él. No significa que no hay clave de acceso.
WEP
Wired Equivalent Privacy. Esta es una forma antigua de la seguridad y no es tan seguro como WPA. Hay programas en torno a que los hackers pueden descargar a romper el protocolo WEP. Una vez que han WEP de software, que puede ser capaz de acceder a su router y obtener un viaje gratis en Internet lo menos!
La clave WEP, sin embargo, será o 64 bits o 128 bits de longitud. (128 bits es de 26 caracteres, y se mezcla de los números del 0 al 9 y las letras A a F) Si usted tiene un Livebox de Orange, por ejemplo, entonces se trata con seguridad WEP. Al configurar el router para una conexión inalámbrica, usted tiene el tipo a los 26 caracteres. Obtener un mal y no se conecta!
WPA
Wi-Fi Protected Access. seguridad WPA es realmente una actualización de WEP. Se utiliza el cifrado diferente y más fuerte, y así es más difícil de roer. Es más fácil para usted para establecer, también, porque sólo tiene que crear una frase de pase corto en lugar de escribir las 26 letras y números! Usted debe utilizar WPA y no mucho WEPA de routers inalámbricos no tienen la seguridad activa de forma predeterminada. Las páginas de configuración le permitirá que se enciende, y suele haber un menú de ayuda que explican la configuración de seguridad diferentes.
Feb 23, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
HOLAS COMO NENCESITO EN DRIVER DE UNA IMPRESORA MATRICIAL MODELO LQ 2080 PARA INSTALAR EN CENTOS Y ASI PODER CONFIGURAR CON CUPS
Aqu? est?n a conductores para Epson LQ-2080. Por favor, seleccione a conductor para descargar. Adicionalmente, puede escoger Sistema operativo ver a los conductores que ser?n compatibles con su sistema operativo. Si usted no puede encontrar a un conductor para su sistema operativo, puede preguntar por los conductores para su sistema operativo en nuestro foro
http://driverscollection.com/?H=LQ-2080&By=Epson&dpage=2
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Nov 24, 2010 | Epson LQ 2080 Matrix Printer
La direccion de la consola esta deshabilitado mac xbox360
Conectar xbox 360 a internet; si tienes xbox 360 y quieres jugar en internet, ve este tutorial.
Como conectarse al Live.
Bueno tienes tu nueva 360 smile.gif y ahora quieres entrar a la experiencia Xbox Live y no sabes cómo. Acá una guía que te enseñara como hacer desde las conexiones de redes (VTR por ahora) hasta la creación de tu cuenta Xbox Live/gamertag.
Las Conexiones:
Hay 4 opciones para conectar tu consola:
A: Directamente desde el MODEM de VTR.
Conecta el cable de red que sale del MODEM a la 360.
MODEM ------------ 360
1. Llama a VTR (600 600 9000 opcion 3, 3), pideles que te cambien el numero de MAC al que tiene la 360.
2. Para saber como obtener tu numero de MAC debes buscarlo en las opciones del menu de 360
3. Una vez hecho esto estás listo para entrar a Xbox Live.
B: Desde el MODEM de VTR 2 conexiones (USB y RED).
MODEM red ------------- 360
usb ------------- PC
1. Conecta el otro dispositivo que tengas (Ej. PC) y conectalo via USB.
2. Conecta la 360 por el Cable de Red.
3. Llama a VTR (600 600 9000 opcion 3,3), pide que te registren 2 MACs, la del PC y la 360. Así ambos quedarán con Internet.
4. Una vez hecho esto estás listo para entrar a Xbox Live.
C: Router
Modem ------- Router ------ 360
1. Conecta la 360 al router con un cable de red.
2. Ahora hay que configurar el Router. (Ruteo de puertos)
1. Tienes que entrar al menú de administración del router. Generalmente la dirección es 192.168.0.1, después te pedirá nombre y contraseña. Generalmente es User: admin, sin password. Si no funciona, vas a tener que conseguirtelos.
2. Una vez dentro del menú.
3. En la página eliges Forwarding.
4. Elige la marca de tu router.
5. Elige Xbox Live 360
6. Sigue las instrucciones de cómo “rutear” los puertos para la 360 (88 y 3074)
7. Una vez ruteados los puertos, estás listo. Empieza la creación de tu Gamertag.
D: Router via Wifi
Router )))))))) 360
1. Necesitas el Adaptador Wifi para la 360
2. Necesitas un router con soporte Wifi b/g
3. Prendes la 360 vas a la parte de Sistema – Config de Red – Windows Connect Now.
4. Eliges el Spot Wifi
5. Desde un PC, Ahora hay que configurar el Router (Ruteo de puertos).
5. Elige Xbox Live 360, Sigue las instrucciones
6. Una vez hecho lo anterior, estas listo para crear tu Gamertag.
XBOX LIVE
Entendiendo Xbox Live:
Primero hay 2 tipos de cuentas para Xbox Live. Gold y Silver.
SILVER
• Permite a otros jugadores saber quién eres y cómo juegas gracias al perfil de jugador único.
• Entra en el Bazar Xbox Live para conseguir fantásticas descargas (incluidos los juegos clásicos de consola de Xbox Live Arcade), demostraciones y tráilers de los juegos que van a salir próximamente.
• Prueba la acción multijugador con acceso a partidas multijugador masivas. Lo único que tienes que hacer es crearte un gamertag.
• Disfruta de la acción multijugador sin límites con las oportunidades suscripción de prueba al nivel Gold.
• Crea y mantén una lista de amigos para conectarte y comunicarte instantáneamente con familiares y amigos mediante mensajes de texto y voz.
En otras Palabras... Puedes Bajar Trailers, demos, etc. Pero NO puedes jugar Online
May 20, 2010 | Microsoft Video Game Consoles & Games
No puedo activar mi router pongo el 192.168.1.1 y no lo acepta mi coputadora
Realice los siguientes pasos para restablecer y volver a configurar el router WNR1000:
RESET:
En la parte trasera del router se encuentra un pequeño agujero pequeño (que tiene un pequeño botón en su interior). Pulse el botón con la ayuda de un clip. y manténgalo pulsado durante 30 segundos. Después de 30 segundos, por favor, thebutton liberación y apague el dispositivo durante 5 segundos.
CONEXIONES:
1. Conecte un cable Ethernet desde el módem a la portof WAN del router (puerto aislado).
2. Conectar el ordenador al router mediante cualquiera de los puertos 4available. Por favor, asegúrese de que NO HAY CONEXIóN DIRECTA BETWEENTHE MODEM y los ordenadores (ya sea utilizando un cable Ethernet o cable USB).
3. Apague el módem y el router después de hacer theconnections.
4. Encienda el módem y espere a que las luces, y luego poder enel router.
Reconfigure:
1. Abra el navegador (Internet Explorer o Mozilla Firefox).
2. Acceder al router, por lo general con http://192.168.1.1 ultraperiféricashttp: / / www.routerlogin.com.
3. Entrar al router con el usuario como "admin" y contraseña "password" (por favor, tenga en cuenta que theusername y la contraseña distingue entre mayúsculas y minúsculas).
4. Haga clic en "Configuración básica" en el menú de la izquierda y select'Use ordenadores MAC Address 'de la sección' router de direcciones MAC.
5. Haga clic en Aplicar.
6. Una vez que se actualiza la configuración luego apague el router yla módem. Encienda el módem y espere a que las luces, el poder en therouter.
Espero que esto le permite ir en línea a través de la WNR2000 router.
Recuerdos
Anand
Mar 22, 2010 | NetGear WNR1000 Router
I want the software motorola l6 to connet to computer
You can probably download such software i dont know where but just poke around on google for one im almost positive you will find your software there
BestWishes                  -SunShine-
Jul 04, 2009 | Motorola Mobility L6 Cellular Phone
NECESITO CONFIGURAR MI CAMARA EN LA COMPUTADORA Y NO PUEDO....
pero tienes el cd?, de todas maneras yo estaba de vacaciones y deje el cd en mi casa, pero conecte la camara al computador de un amigo y las vaje de una vez, sin habere instalado el software(CD), luego cuando llegue aqui a mi casa instale el cd y el programa se llama arcsfot photoimpresion 6, despues tuve problemas para ver el video que habia hecho, pero tuve instalar quicktime, bueno si alguien puede dar mas informacion, a mi me gustaria saber mucho mas de la camara, porque me aparecen iconos como un avioncito, una rueda, tambien tome una foto y tiene sonido, si alguien sabe todas las funciones que no estan en el manual mi correo es indytu@hotmail.com clocas ref.camara
gracias
indira
Jan 12, 2009 | General Electric A835 Digital Camera
Zebra Stripes s400
el codigo de barras sale corrido de su posicion
Oct 29, 2008 | Zebra Stripe S400 Label Printer
Redes virtuales privadas
puedes comprar dos Linksys VPN RV - 42, tienes que tener dos static IP in cada lugar, despues hacer la configuracion, crear el tunnel VPN, los IP internos de las dos redes deben ser distintas, ejemplo: una puede ser : 192.168.0.1 y la otra debe ser 192.168.1.1, despues de bes de connetarlos y hacer las pruebas.
suerte, jajajaja ( si no sabes bien vas a estar dias intetandolo)
Jun 11, 2008 | Computers & Internet
Problema para configurar internet wireles
dependiendo de c?mo conecting wirelessly, por el tipo receptor o PCi o tipo conexi?n del usb del cuaderno de PCMCIA, necesitar?s los conductores para todos los ?stos, pero no permites que a Windows los gen?ricos los funcionen pues no son siempre compatable. Si los has instalado, quitar el adaptador sin hilos si no se construye adentro pues no dices si tienes una PC del cuaderno o del tablero del escritorio, reinstalas el software, entonces vuelves a conectar el adaptador sin hilos. si es un cuaderno despu?s va al encargado del >device del panel de control y mirar en la lista para cualquier marca del exclamation como esto significa no hay conductor compatable, si no y ves que tu adaptador sin hilos lo enumer? est? trabajando muy bien, ut que puedes enderezar para chascarlo encendido uninstall selecto de la American National Standard y para recomenzar el cuaderno para que se reinstale otra vez para ver si soluciona el problema
Sep 13, 2007 | Computers & Internet
Zhone 6211-I3-200 Router Logo
187 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Justin
Justin
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
