Question about Mitsubishi WS-55807 TV
Mishubishi ws-65819 I have a problem with this tv it is somekind of crosstalk efect in the picture and hard to explain maybe noice in the picture. i could see three four edges in the image it is like negitive efect .tv is 5 years old.
  • Welihena Roger Jul 02, 2006
    THE SOLUTION THAT TECMAN HAS SEND IS GOOD FOR CONVERGENCY PROBLEM
    BUT MINE IS A DEFFERENT KIND OF PROBLEM I HAVE THE PERFECT PICTURE
    ALL THREE COLORS ORVERLAP TOGETHER I COULD GET THE GOOD BLACK AND WHITE PICTURE.WHEN I HAVE A COLOR IMAGE THE COLORS HAVE A NEGITIVE EFECT .
  • lovesmovies Apr 21, 2008
    first off i have no picture.. but the menu comes up and i can mess around with the sound and video and all that, secondly when i access the menu the text at the sides of the screen look curved (or bowtied), offset and multi colored.. basically like a 3d image
    President:
  • 3,130 Answers
Very common problem Its the convergence IC's in the set and are not cumseumer replaceable unless you know your way around the inside of a tv set. Theres way to much Hi voltage inside these sets tp tinker around with them . This repair should only be done by a qualified technician, as it probably will need a good alighnment after the ICs are replaced . Should cost about 3 to 4 hundred bucks to have fixed. Good Luck
Posted on Jun 14, 2006
My Mitsubishi ws-65819 shows in an oval shape, can this be fixed, also is there a way i can do it myself to save some money? Also how to play an Xbox 360 in HD?
yes......you can rplace the convergence ic's on convergence module......these are the big stk type ic's and also the low ohm resistors.
These are 3.9 to 6.8 ohm half watt on the yoke return circuit. Let me know how you fare......regards. meder's tv
May 28, 2012 | Mitsubishi WS-65819 TV
I have a 65inch mitsubisihi and having convergence problems need help on instructions to put in stk-392-570 chips to fix the problem. WS-65819
Here is a youtube video I found that was quite helpful to repair my WS-65819 this weekend: http://www.youtube.com/watch?v=63TbxQaNkVo
There is a part 2 that deals specifically with the soldering of the chips. Hope this helps
Sep 26, 2011 | Mitsubishi WS-65819 TV
The picture is blank but there is audio and the menu is still operational. There seems to be a video problem. Please advise.
Maybe the cable that link the board with the proyector, was broken, or the contacts have corrosion. Open the back of the TV, check all the cables that link the board with the proyector, check for green corrosion and applies contac cleanner. I left you a video to check it out
Sep 20, 2011 | Mitsubishi WS-65819 TV
My WS-65819 won't power on. It would power on for
need to replace the stk's and some other caps, usually have to resolder the chasis on both convergence and power supply chassis.
Dec 03, 2009 | Mitsubishi WS-65819 TV
The tv does power up at all, we need a new micro-processor board
There are 23 Parts available from =>
http://www.partstore.com/Model/Mitsubishi/Mitsubishi/WS65819.aspx?ModelAliasNumber=WS-65819
Maybe they have the part you are looking for.
This website for Mitsubishi has only 4 parts for the model =>
http://www.mitsuparts.com/
Dec 30, 2008 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 Sender Board problem
yes it can the cost is $350 sumwut dollars ,i got my tv for $54 and thats wut was wrong with it ,the board that is connected to your power cord is wut needs to be replaced sears can do the job but the labor is $200
Nov 30, 2007 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 TV Problem
it the circut board that is connected to the power cord ,
Nov 26, 2007 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 got Fried by a mouse
Just replacing the board if its the main board is half of the repair. The memory IC which is usually located on the main board holds all the data for convergence,picture geometry,channel memory,color settings etc..So getting it to run is only half of the battle. Got to http://www.partstore.com and look for the main board. I couldn't however look it up because it says your model number is invalid.
Mar 14, 2007 | Mitsubishi WS-65819 TV
Mitsubishi WS-55807 TV Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
