Question about JVC AV-32F704 32" TV
Sanyo MTS/Stereo/SAP/DBC Tv picture flashes and makes noise
Just got a tv from my neighbor. It was working fine and then my little guy was watching cartoons and all of a sudden the picture started flashing and at the same time the tv makes a noise. I have universal remote and I'm wondering if somehow this is interfering with the tv or did I buy a dud?
Kimi
  • 277 Answers
SOURCE: On Timer light flashing on my TV
If you're NOT still under warranty you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. good luck!
Posted on Nov 30, 2005
  • 13 Answers
SOURCE: Help ,help.
It looks to me that your tv is starting up and then shutdown. I have suspect that your tv have a high voltage shutdown. Check your B+ voltage, if not correct rectify it. If it sound like gibridge to , then seek professional help. good luck
Posted on Dec 23, 2006
  • 11 Answers
SOURCE: TV wont power on, clicking noise and flashing standby led
Sounds pretty bad to me, I had a computer monitor that did a similar thing when plugged in after blowing, it's not a good thing. I didn't even bother to mess with it. You may have to replace the whole power board or at least have a whole handful of pieces to re-solder. It most likely isn't worth it unless your other tv's are under 30" and you don't have a lot of money ;)
- Dave
Posted on Dec 28, 2007
coleslaw424
  • 43 Answers
SOURCE: turning the sap off using my universal remote
If there are any menu setting buttons on the t.v. itself then I would try using them to find the sap setting.
Posted on Jan 31, 2008
ginko
  • 19396 Answers
SOURCE: TV will not turn on
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
No sound,but good pic.everything else works fine.(toshiba 57hx94)
hello,
• Check the antenna/cable connections (see Chapter 2).
• The station may have broadcast difficulties. Try another channel.
• The sound may be muted. Press VOLUME.
• If you hear no sound, try setting the MTS feature to STEREO mode (page 81).
• Make sure the SPEAKERS function in the AUDIO SETUP menu is set correctly (page 83).
• If you are not receiving a second audio program from a known SAP source, make sure the MTS feature is
set to SAP mode (page 81).
• If you hear audio that seems "incorrect" for the program you are watching (such as music or a foreign
language), the SAP mode may be on. Set the MTS feature to STEREO mode (page 81).
• When using an external audio amplifier, if you connect the amplifier to the VAR. AUDIO OUT jacks, the
volume of the TV and amplifier must be set above 0 or you will not hear any sound (page 20).
regards
shaun
Dec 03, 2010 | Toshiba 57HX94 57 in. HDTV Television
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
My wife was hitting buttons on our satellite remote and the audio no longer works. She thinks the tv is the problem. I have tried all of the Satellite volume menus and am unable to get the sound back on.
TV: check for SAP or MTS features, set them to STEREO. Also, verify that the TV Speakers are set to ON.
Cable Box: If the box has volume controls, make the volume is turned up. Also, check for the SAP or MTS feature. Again, set this to STEREO.
I hope this was helpful, best wishes.
Jun 12, 2010 | Televison & Video
I have no volume on channels 2 and 7. All other
Your SAP audio function is on. Look on your remote or in the TV menu for SAP or MTS. There are 3 settings, Mono, Stereo, and SAP... set it to Stereo. I hope this was helpful, best wishes.
Mar 28, 2010 | Toshiba 32A33 32" TV
No sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Mar 26, 2010 | Televison & Video
JVC AV-32F704 32" TV Logo
126 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
