Question about Gigabyte GA-7VT600 1394 Motherboard
Motherboard problems galore
I have 3 different Gigabyte motherboards each seems to be messed up in a different way. The GA-7VT600 that will power up but won't stay on for more than 15 seconds. It has been known to have ram problems. I have a Gigabyte 7NF-RZ which refuses to turn on evan after I've checked all the connections. I also have a Gigabyte 7VM400M-RZ that has a AGP slot that does not work. If anyone has any ideas that can help that would be wonderfull.
map9966
  • 2351 Answers
SOURCE: MOTHERBOARD INSTALLATION CD
Hi rex, you can download all the drivers you need for the 7VM400M-RZ motherboard directly from Gigabyte here.
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1764
These drivers are free.
Once downloaded & uncompressed you can burn the to a CD.
Enjoy!
Mike
Posted on Jul 13, 2008
bunnydawg
  • 5158 Answers
SOURCE: No Sound output im using Gigabyte 7VM400M-RZ
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1764
the drivers are on this page
Please take a moment to rate this solution
Posted on Jan 27, 2009
  • 53 Answers
Yes without the jumpers in the correct position the on-board audio won't function. Just follow the diagram. Make sure that there is no power to the board before you make adjustments to the jumpers just to be safe. It's also good to ground yourself by touch the case (if it's metal) before you touch any of the components and or motherboard.
Posted on Jan 28, 2009
  • 11800 Answers
SOURCE: 7NF-RZ Motherboard not go on
Check the memory and make sure the motherboard sits on glass, not on something conductive or that can generate static.
Posted on Feb 22, 2010
furiacega
  • 548 Answers
SOURCE: gigabyte GA-8s649mf headers
It is a very an old question. I had this problem myself at an early age.
Here is an image that will help you:59ae22f.jpg
These are small, 2-pin cables that are in Red, Blue and Green colors (with white main connector). Try to not bend te pins receptors, because they are very fragile.
1. Plug the POWER_SW cable on the first two left pins;
2. Plug the HDD_LED cable next to it;
3. Plug the POWER_LED cable either to the insulated 2-pin slot or next to the two others you plugged in;
Be carefull because if you missplace the order your system won't power up, and insert them horizontally.
If you need further assistance, please post.
Posted on Mar 11, 2010
Driver
Good Day
Here the site where you can download all the drivers for your motherboard. http://www.gigabyte.com/products/product-page.aspx?pid=1666#dl just click where your location is then safe the file then open the file where your downloaded drive is located then install. Hope this can help you Best Regards
Sep 22, 2011 | Gigabyte GA-7VT600 1394 Motherboard
Driver de audio
http://www.gigabyte.lv/products/page/mb/7vt600-rz/download/
Jan 25, 2011 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
I would like to know if GA-7VT600 motherboard is compatible with ATI RADEON 9600 PRO 256 MB! Also I would like to know how to install it (previous graphic card an nvidia)! Thank you very much!
As long as the card is the right fitment for the board (PCIE or AGP), there is no reason why it will not work. Installing is simply a matter of slotting it in and installing the drivers for the card
Jan 12, 2011 | Gigabyte GA-7VT600 1394 Motherboard
Which driver is best for Gigabyte GA-7vt600 1394 Motherboard? I installed realtek AC-97 but it didnt work
Realtek AC 97 is the only driver for this board, did you install the 64 bit driver rather then the 32 bit driver?
Jan 01, 2011 | Gigabyte GA-7VT600 1394 Motherboard
Just installed a gigabyte GA-7VT600 motherboard and on power up it got to bios screen and froze up. Now after trying to reboot I have no video of anykind. The pc sounds like it's running through boot...
Try taking the video card out and replacing it back...making sure that it is properly seated...if you can obtain another video card...try replacing the video card...this will rule out the motherboard if it works.
Dec 27, 2010 | Gigabyte GA-7VT600 1394 Motherboard
Did a fresh install of win xp pro 32 bit and now I have no sound
Download the RealTek AC'97 audio driver for this motherboard. Install it, restart your computer.
Gigabyte Support > GA-7VT600 1394 motherboard > Downloads > Drivers,
http://www.gigabyte.com/products/product-page.aspx?pid=1667&dl=1#driver
To the right of where it states > Choose your OS: , click on the blue down arrow.
Now click on the Operating System you're using.
Click on Windows XP 32bit
Download the RealTek audio file. Go to the right under the heading > Dowmload Here, and click on the Country nearest yours.
In the small window that comes up click on Save File.
(Opening motherboard_driver_audio_realtek_whql.exe)
Quickly look at the other window that comes up, at the top of the small window.
This states where the file will be downloaded to.
May have desktop, or My Documents, or Downloads in the heading name.
After the file has fully downloaded, close all windows, go back to your desktop screen.
Is the file there?
The file name is motherboard_driver_audio_realtek_whql.exe
If not look in My Documents. (Documents for Vista)
Click on Start > My Documents
No?
Look in a sub-folder of My Documents. Downloads.
Click on Start, click on My Documents, double-click on Downloads.
When you see the file name Double-click right on it.
Now follow the Installation Wizard's easy instructions.
(Essentially click on Next, Next, and Finish)
Restart your computer.
Nov 18, 2010 | Gigabyte GA-7VT600 1394 Motherboard
Need network driver
you can find the drivers for your motherboard at :
http://www.gigabyte.com/products/product-page.aspx?pid=1763#dl
Please rate my solution
Oct 12, 2010 | Gigabyte 7VT600-RZ (GA-7VT600-RZ)...
MOTHERBOARD GA-7ZX THE PROBLEM IS , I HAVE A MOTHERBOARD GA-7ZX,WITH VGA ON BOARD AND IN YOUR MANUALS , THERE IS NOTHER ABOUT THIS MODEL AS I SAID MOTHER BOARD GA-7ZX, ALL YOUR VER. IS MENTIONED THAT MODEL...
You posted this problem twice. I have replied to each differently.
The motherboard manuals would be supplied by the manufacturer, in this case a company named Gigabyte, which is not a part of nor related in any way to FixYa.com website. The following is a link to the support page for this motherboard on the Gigabyte website:)
http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=1369
There are three revisions of this motherboard {1.x, 5.0 and 5.1} and NONE of them have onboard VGA. All use an add-in 4X AGP VGA card that goes into the brown slot at the top of the white PCI slots.
Compare your motherboard to the pictures available at Gigabytes' support page (the link above) to make sure we are talking about the same motherboard, although as far as I can see there was no other manufacturer that made a motherboard with the GA-7ZX designation. Please verify and repost your results.
Jan 09, 2009 | Gigabyte GA-7ZX Motherboard
Gigabyte GA-7VT600 1394 Motherboard Logo
136 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
