Question about JVC AV-K29MX1U 29" TV
Progressive power up problem
Hi Guys. I am in S.Africa (PAL) and have a JVC AV-K29MX1. I mention that as the model is slightly different to that on the site and I don't know if it has any relevance. About 6 weeks ago, the TV started playing up when trying to turn it on. If turned off with the remote, the green light would go out and the red LED would stay on (front panel) Turning on with the remote worked fine. The problem started when the mains power to the TV was cut off due to a few short power outages. During the first one, the TV was only off for about a minute. It turned on with no problems. However in a subsequent outage, the TV was off for a few minutes and when I pressed the power button on the front of the TV, the red LED came on, the green LED then came on momentarily and then both "faded" off ... like a capactor discharging. Pressing the power button on/off continuously for a few minutes resulted in the green LED staying on for longer and longer until eventually the TV "fired up" and work fined ... until the mains power went off, and if odd for more than a few minutes, the entire process had to be repeated to get it going again Progresively, things got worse though. Eventually, when turing the TV off with the remote, even though the red LED on the front panel would stay on, when the remote was used to try turn on the TV again, the green LED would come on momentarily and then both would "fade" off as above. Using the previous "method" of repeatedly switching the power button on the TV, eventually we could get it going though. Eventually last week, even that would not work and as I suspected that heat (or lack of it) in a faulty component might be a factor in preventing it from getting the power going, I tried blowing hot air with a hair dryer into the air vents of the TV case (bottom right when viewed from front). This allowed me to get the TV going again. The "hot air" was directed in the general vicintity of the large black capacitor on the power section of the chassis. This particular model has a "diagnostic" routine which checks various functions of the TV prior to start up. If any are found, a yellow LED flashes on the front panel (next to the red and green led's for power) and the TV won't start. At no time in any of the above did the yellow light ever come on. Now, when trying to turn the TV on, NO LED's come on and it only makes a faint clicking sound. I had the flyback transformer replaced about 6 months back, so I don't know if it could be that ... also, even though the flyback transformer needed replacing, the red power LED would still come on and only then the yellow LED indicating a fault. Any ideas ?
  • Steve Wayne Jun 14, 2006
    Thx for the info techman!!
    I suspected a cap was at fault.I'll pull the likely culprit out and test/replace it. If you are right and other components are also gone then that won't fix the problem. In that case I'll send the set in for repair as I have very limited time and no testing gear here other than a DMM.
    Thx also for the voltage warning. Whilst not an electronics wiz myself, as a Sound Engineer I do have a little "electronics" experience, including getting zapped by one of the monitor/Chassis's I assembled (and forgot to connect the earth strap on) for a video wall some years back :-(
    So, I'll make sure to stay clear of the big red wire with the rubber cap going into the CRT when I remove /replace the capacitor . I DEFINATELY won't stick a screwdriver under the rubber cap to remove the lead from the CRT, especially not if the earth strap/discharge ciruitry is not connected and I absolutely, most certainly will NOT let my finger touch the metal of the screwdriver
    Yep ... I know .... my actions were shocking!!
    President:
  • 3,130 Answers
Yeppers. Sounds like the standby power supply has a bad capacitor in it and the regulator Ic is defective. These parts should only be replaced by quilified technician as there is very high voltage inside these sets. Good Luck
Posted on Jun 14, 2006
Hi
I have a JVC AV-K29MX1 and when I switch it on the picture starts shrinking vertically and it eventually switches off with auto timer and the orange led starts flashing. Could you please assist me with this problem. I have found a diode part no ISS 133-T2 close to the vertical output IC that seems to have overheated along with a couple of resistors. The problem is that I can not find this diode anywhere. Could I perhaps replace this diode with another replacement value?
Regards
MrT
Posted on Jul 30, 2011
Does anyone know if the L37G10A supports PAL I as well as PAL B/G. I'm moving from Australia to UK and am wondering whether to bring the TV
Screen Type LCD Panel Type IPS-alpha Progressive Full-HD LCD Panel Panel Aspect Ratio 16:9 (Widescreen) Aspect Ratio Control Modes (TV/AV modes) 4:3, 14:9, 16:9, Just, Zoom1, Zoom2, Zoom3, DTV: 16:9 & 4:3 Full Aspect Ratio Control Modes (PC mode) 16:9, 4:3 Comb Filter Yes Progressive Scan Yes TV Tuner Receiving System DVB (Digital), PAL-B/G (Analogue) Tuner Type Integrated SD/HD DVB-T 7MHz Australia, PAL B/G
Contrast Ratio 1 - Dynamic: 20000 Picture Adjustment Modes / Film Modes Normal, Dynamic, Cinema, Eco Colour Temperature Control Cool, Standard, Warm
May 21, 2011 | Televison & Video
JVC DR-MX1S
It's likely to be an incompatible signal. You have PAL (UK) and NTSC (Belgium), the DVDR/VCR combo may not be compatible with PAL causing it to seem like it's not receiving any signal, when in fact it is - but not in a recognisable format. You may try and get an NTSC to PAL signal converter like this: http://cgi.ebay.co.uk/NEW-TV-AV-Video-System-NTSC-To-PAL-Converter-Converor_W0QQitemZ270163920912QQihZ017QQcategoryZ32837QQtcZphotoQQssPageNameZWDVWQQrdZ1QQcmdZViewItem That'll solve your problem.
Sep 09, 2007 | JVC DR-MX1S DVD Recorder/VCR
JVC 27" TV model do not know what are the codes
Hi Roger,
You didn't mention the brand of your universal remote control. Anyway, here are the universal code for JVC Tv.
JVC Codes: 013/ 054/ 055/ 060/ 065/ 067/ 089
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 15, 2011 | JVC AV-27230 27" TV
Help
Go to menu and sub menu video .Under video option you will see video formatt,e.g Pal,NTSC.You confrim your tv standered if its pal or NTSC (this you can check at back of your tv set ,not always mention but most of them are printed)On your dvd player
you have to select same formatt as your tv .If not sure of you tv system try auto system on you player.
NB dont select progressive scan by mistake otherwise you will not see any picture on your tv if its not progressive scan tv.
If you could mention tv and dvd model and brand will be able to advise you exactly.
Dec 13, 2007 | Televison & Video
JVC AV-36950 TURNS OFF
Replace C953 1000mf / 35v in power supply....capacitor
top will appear slightly bulged or will check bad with
ESR meter...........................T.
Dec 02, 2007 | JVC AV-36950 TV
Jvc tv does not recognize toshiba dvd player sometimes....
Which cable type are you using (component, composite, HDMI...)? If it's composite (the white, red, yellow) it may be in "progressive scan" mode. Check the manual to see how to toggle betwixt the two.
Sep 10, 2007 | JVC AV-27530 27" TV
Image doubled when using 480p
No it is only 480i with component cable support.
Jul 27, 2007 | JVC AV27WF36 TV
TV "X-Ray" Error
HI Matt of south Africa Every Tv has an xray protection circuit.that circuit is faulty os you will have to take it to qualified tech to repair your tv.good luck.
Apr 26, 2007 | JVC AV-A21M3U 21" TV
JVC DVD player stuck in Split screen
the player is set to progressive scan mode.use relevant button on remote to reset to interlace mode. Duane,S/Africa
Mar 11, 2007 | JVC XV-N320 DVD Player
Help Needed for JVC GR DVM 76
Help Needed for JVC GR DVM 76 This model looks like it is a couple of years old. Yes it is NTSC. But it does have a firewire port which you can use to import your video to you computer, where you can convert to PAL and burn to a DVD. A stand alone converter to convert from NTSC to PAL is very expensive. John
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC AV-K29MX1U 29" TV Logo
242 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
