Question about Whirlpool Ovens
Changing the oven from celsius to fahrenheit
My oven is set for celsius how do I change it back to fahrenheit? I have a Whirlpool gold self cleaning single oven. Model number GBS307PDS5
  • 1 more comment
  • lsamples Nov 06, 2008
    Thank you so much for that; it worked. I have pushed everything but apparently not long enough.
  • maire3065
    maire3065 Mar 01, 2013
    Thanks! I almost had to learn Celsius.
  • Gail Ward
    Gail Ward Apr 27, 2017
    It worked! Thank you so much!
You will need to push the broil button down for at least 10 seconds then you will see the c change to a f for farenheit
Posted on Nov 06, 2008
  • 6 more comments
  • jmarissa Nov 26, 2010
    Thank you sooooo....much this worked for me
  • Kathy Beebe Sep 05, 2012
    Thank you. It worked for me too.
  • Judith Sparks
    Judith Sparks Sep 19, 2012
    Thank you, that was so easy.
  • caressawms79
    caressawms79 Sep 26, 2012
    thanks it worked for me
  • maire3065
    Thank you! I almost had to learn Celsius!
  • doctorofdivi
    doctorofdivi Apr 14, 2013
    That was too easy! Thank you. Now I know what to do when the grandchildren do it again. Now if I can just get the clock to stay on! LOL
  • S claus Sep 13, 2013
    almost called the repair thanx so much!!!!
  • Keith Williams
    Keith Williams Feb 14, 2017
    What u we to.change the c I get the beeep but it want change
180 fahrenheit = ? celsius
82.22222 or you could use the formula below:
(°F - 32) x 5/9 = °C
To convert (°C) Celsius to (°F) Fahrenheit use the formula below:
°C x 9/5 + 32 = °F
Mar 06, 2015 | Frigidaire 30" Self-Cleaning Freestanding...
Cant figure out how to get back to farenheit temp..
to change between fahrenheit and celsius
The temperature is preset at Fahrenheit, but can be changed to
Celsius.
To Change: Press and hold CUSTOM BROIL for 5 seconds. A
tone will sound and “C” will appear on the display. Repeat to
change back to Fahrenheit. To remove, press UPPER OFF,
LOWER OFF or OFF/CANCEL. you can click on the link for guide http://www.ajmadison.com/ajmadison/itemdocs/8300609.pdf
Aug 16, 2008 | Whirlpool GBS277PDS Electric Single Oven
Temp probe indicator stays on
sounds like your probe connection may be shorted. Can you inspect the probe itself, and perhaps do a test for continuity with an ohm meter? Also, you might be able to disable the probe in the menu settings, and run it on manual, just for a test.
Do you still have the user's manual for this unit?
Feb 13, 2008 | Thermador C272 Electric Double Oven
How do you change the key pad from celcius to ferenhite on my whirlpool acubake oven
Look for the button marked "Precise Clean" in the upper left corner of the control panel.
Press and hold this button for five seconds until the display reads "Temperature Unit Celsius.
Release the button and push it again for another five seconds until the display shows "Temperature Unit Fahrenheit."
Push the "Off/Cancel" button to lock in the Fahrenheit setting.
Jul 10, 2011 | Whirlpool SB160PEE Gas Single Oven
Our Whrlpool Super capacity 465 oven will only let you preheat to 260 degrees. After 260 the display showing rhe temp. will not advance any higher. It will still broil when you push the broil setting but...
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Whirlpool oven, however if you could post the complete model number I can speak directly about possible remedies instead of generalizing...
**Though it may not be necessary as I believe your disply may be set to Celsius (centigrade, like Canada and Europe) instead of Fahrenheit since 260C equals 500F thus it tops out at 260...most ovens will not exceed this temp unless in a self clean cycle.**
I suspect if you refer to your operator/owners manual it likely will instruct you how to change it back to display the temperature in Fahrenheit.
Thank you for choosing FixYa. I'll need to watch for your reply before moving forward.
Regards,
Macmarkus :)
Apr 28, 2011 | Ovens
How do you change the temp from Celsius to Fahrenheit? Whirlpool Gold.
Press (precise)clean for 5 seconds, display shows temp Celsius press it again for 5 secs display shows temp Fahrenheit, press off/cancel to store
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 27, 2011 | Whirlpool Ovens
Change oven from celsius to fahrenheit
press the custom broil button for about 5 seconds, or possibly the bake button depending on the model
Jun 30, 2009 | Whirlpool Ovens
Getting oven back on fahrenheit instead of celsius
Actually for the Whirlpool Accubake I just figured out, the bake button didn't work, but holding the broil button did the trick.
Apr 19, 2009 | Ovens
How do I change my whirlpool oven back to Farenheit instead of celcius...
its in your manual, did not give model number so i looked up anyone. if this does not work you can enter your model number here for a copy of user manual
http://shared.whirlpoolcorp.com/product_literature/search.jsp
To Change:
Nov 07, 2008 | Whirlpool Ovens
Whirlpool Gold Accubake oven
depress the broil button for 5 seconds it will revert back to Farenheit
Feb 20, 2008 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
7,632 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
