Question about Canon imageCLASS D320 Digital Copier
Light or blank page printing
Have installed new S35 cartridge
sometimes it will print one or two very light pages then blank pages after that.
I tried to follow the canon manual but the instructions don't help.
    Genius:
  • 2,035 Answers
2. Remove the cartridge from the machine.
3. Remove the new cartridge from its protective bag.
Save the protective bag. You may need it later when you remove the cartridge from the machine.
4. Rock the cartridge 5 or 6 times to distribute the toner evenly.
5. Place the cartridge on a flat and stable surface. Grip the sealing tape tab and snap it in the direction as shown. Make sure that the tab itself is detached from the cartridge.
6. While grasping the cartridge with one hand, firmly and slowly pull the sealing tape tab straight out with the other hand to remove the sealing tape completely. Throw the tape away.
To avoid breaking the tape, do not pull the tape out at an upward or downward angle.
7. Hold the cartridge and position the arrow mark on the cartridge towards the inside of the machine shown below.
8. Align the projections (A) on both sides of the cartridge to the guides (B) in the machine (location (1)) and gently slide the cartridge into the machine until the right cover slightly rises up (location (2)).
The right cover moves simultaneously with the action of the cartridge. Do not push the cartridge farther than location (2). Doing so will result in catching your hand in the right cover.
9. Close the right cover and the cartridge will be set in place (location (3)).
If the LCD displays [INSTALL CARTRIDGE], reset the machine by opening the right cover and then closing it.light or blank page printing - ad0a33c.gifed9d2af.gif
Posted on Oct 19, 2008
    Brigadier General:
  • 6,966 Answers
To my knowledge, if any copier has reached a certain number of copies (say 50K), then it would be mandatory to replace/service the following:
  • developer;
  • OPC Drum;
  • cleaning blades; and
  • rollers.
This is in addition to the replacement of the cartridge.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Hi, thanks in advance for any solution suggestion. My xerox pe 220 prints blank page. Cartridge is new. Th poblem should be with the driver, installed it several times, but it doesn't help. Can anybod
Does it sound like it's trying to print or does it just quickly spit out a blank page. If you print something three pages long, do three blank pages come out??
I know this may sound silly, but did you remove the piece of tape that covers the contacts on the new print cartridge?
Nov 25, 2013 | Xerox Computers & Internet
Blank page feeding during print job
Please adjust paper size in printer properties.
Oct 09, 2008 | HP Deskjet 6940 InkJet Printer
I have installed a new ink cartridge and the z645 printer. It sounds and acts like it is printing, but the page is blank. After I first installed the new cartridge, I printed a test page, but only about 2...
Doing the "clean printhead/cartridge nozzles" multiple times would have cleared clogged nozzles. You can also try to manually wipe the cartridge nozzles with a slightly moistened soft cloth. If that still won't help, try to replace your cartridge with a different known working cartridge to determine if your other cartridge is faulty.
May 08, 2011 | Lexmark Z645 InkJet Photo Printer
Printer prints blank page
Is this a brand new printer? What is the make and model of your printer? Are the ink cartridges brand new? Sometimes when the printer driver becomes corrupted it will print out blank page (page after page) I would reinstall the printer driver that goes to your printer and then restart your computer and try to print a new page.
http://en.allexperts.com/q/Printer-mechanical-problems-1024/HP-Printer-prints-blank.htm
http://techrepublic.com.com/5208-6230-0.html?forumID=101&threadID=207297&start=0
Feb 13, 2010 | Lexmark Office Equipment & Supplies
HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
HP Laserjet 1500 Color, Print out Blank
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
pages.
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
empty.
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
cartridges.
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
cartridges.
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
DIMM.)
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
bin.
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
specifications.
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
Nov 13, 2008 | HP LaserJet 1500L Printer
Dell a940 all in one printer
hmm..ok..if the test page is good, then it's in the drivers. get new ones, remove old ones first, re install try again.
Jul 21, 2008 | Dell A940 All-In-One InkJet Printer
HP Officejet 6210 printing blank pages
Hi steve well I suggest that you remove the cartridges and clean the little gold contacts on the carriage and the cartridge. If this doesn't work then install brand new original cartridges as the cartridegs that you have refilled the data ribbon may have been damaged when you refilled them..
Try the above and I hope it works for you
Thanks J
Oct 23, 2007 | HP LaserJet 4 plus Printer
Printer HELL !! need assistance
illustrate on how to replace the ink cartridge on printer
Sep 15, 2007 | Office Equipment & Supplies
Canon imageCLASS D320 Digital Copier Logo
109 people viewed this question
old marine
old marine
