Question about Apple iPod touch
My iPod 8GB won't charge even though it's plugged in and I got a new charger, I got a wall charger, a car charger, and a new computer charger for it. All that comes up on the screen is a battery that shows a little piece of red blinking at the end. Underneath that is a lightning bolt. I would let it charge all night in the computer or the wall but it still doesn't charge. When I press the home button, a battery with a symbol that looks like when you have to plug it into the computer.Beside that is a lightning bolt.( That's when it's not charging.)
  • Anonymous Oct 21, 2008
    my ipod wont charge
Try resetting the iPod buy holding the home button and the shut off button on top at the same time, hold till unit shows it reset
Posted on Oct 19, 2008
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
Replaced battery since it wasn't holding a charge. Has been plugged in for 24 hrs, still won't power on when unplugged from wall charger. What course of action should I attempt?
Possibly the charger itself is bad and only operating as a electrical connection/power cord for your camera. Try borrowing or buying another charger or take the camera to a local camera repair center or Best Buy, etc or contact customer service for your camera's manufacturer.
Hope this helps. Mike
May 24, 2015 | Kodak Easyshare M580 Digital Camera
My laptop won't hold a charge. have a new battery
Is the battery a genuine Dell battery? 3rd party batteries can be high quality or crap, just depends on the maker. Regardless, when you attempt to charge it, does it at least take a charge even though it won\'t hold it? Or does the battery refuse to accept a charge at all? When you plug in your laptop, does the charge light come on? Does the the battery level icon on the lower-right corner of the screen show it\'s plugged in? I know, lots of questions.
Sep 06, 2014 | Dell Inspiron 1420 Laptop
Battery won't charge
Have you test the charger? To test it just try to start your notebook without battery ? Can it start ? If not your might need to replace that charger !
If it can start, then try again with battery plugged in, is same problem appear ?
Nov 16, 2012 | Sylvania G-Netbook
My laptop not charging
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
Or: 2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
Or: 2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
Oct 28, 2012 | Computers & Internet
My hp pavillion laptop will not charge my battery . It won't even work without the battery but plugged in with power supply even though i know battery and power supply are sound.
It won't ever be a 'software' will be either a :
Adapter/Charger issue (Have it tested by local PC repair shop.)
if it is good, then it is the other prob. If it is not good, then buy a new one.
Laptop power connector issue. (expensive repair.)
Sep 06, 2012 | Toshiba Satelitte M300 St3401 Core 2 Duo...
Laptop won't come on even when plugged to wall outlet
you will likely need to remove the battery pack to run the unit. If this works, you will need a new battery to use the laptop portable.
Jun 09, 2012 | Acer Computers & Internet
What do u do when your phone won't charge even
charge your battery on another phone and then place your battery in your phone and switch on your phone and connect the charger to it if still it isn't charging then check your charger and if the charger is ok then you need to repair your phone manually or by taking it to authorized dealer
Apr 25, 2012 | Cell Phones
Mp3 player will not charge from my computer or wireless wall charger
U might half to go to the store and ask someone the charge part at the bottom might of broke you might need a new one sorry
Dec 23, 2011 | Sakar Audio Players & Recorders
IPod Won't Charge
I am assuming that this is the First Gen iPod Touch. My friend had this problem and the way that I fixed it for him is to drain the battery completely, so that it won't turn on. (Even the display shouldn't turn on and say VERY LOW BATTERY with a charge icon).
Plug it into the WALL SOCKET and charge it for 24-48 hours.
If this doesn't work, then the battery is defect. If it is still in Warrenty. Visit the Genius Bar in any apple store and see what they can do
Oct 19, 2008 | Apple iPod touch
Apple iPod touch Logo
283 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
