Sony dav hdx274
Dvd home theater will not turn on nothing at all. somtimes tray will open
  • Anonymous Apr 13, 2009
    dvd tray will not open and makes funny noises
4 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: how to make sony dav-s300 dvd player multi region
Do you have the manual?
I'd check there first. You'll probably need the remote as well.
Posted on Jul 07, 2008
SOURCE: DAV-HDX265 dvd tray doesnt open
well, if you hearing clicks is possible that you will only be able to fix by opening and looking if the door has been misplaced..... is possible that a cd is stuck and you need to open to fix.....
another way to fix is to press and hold Eject and Stop ON THE UNIT! while turning the nub to the right (volume up)
that will open the the service unlocking the system!!!!! THAT WILL ONLY WORK if the door or a cd is NOT stuck on it
Posted on Mar 14, 2009
SOURCE: push power protector showing up in sony dvd home theater system
Always be the audio amplifier IC damaged
Posted on Jun 24, 2010
gopakumarg43
  • 72670 Answers
SOURCE: my home theatre sony dav tz135 cant open the cd tray is locked as displays when i try to open it pls what can i do help please
Visit the site linked here. Tray unlock procedure to Sony decks are given. http://electronicshelponline.blogspot.com/
Posted on Jan 07, 2017
How do I unjam a disc stuck in the 5xCD tray of a Sony DAV-C770 compact AV system?
If you experience difficulty with the disc tray opening or closing, follow these steps to try to resolve the issue.
  1. Turn off the power to the disc player or the stereo system, if the disc player does not have a separate POWER button.
  2. Unplug the power cord from the AC outlet.
  3. Verify there is nothing is blocking the tray from opening or closing.
  4. Let the disc player or the stereo system remain without power for approximately one minute.
  5. Plug the power cord back into the AC outlet.
  6. Turn on the power to the disc player or stereo system.
  7. Attempt to open or close the disc drawer or tray.
If the issue is still unresolved, service may be required.
this is direct from sony hope it helps
Dec 31, 2014 | Sony DAV-C770 System
My DVD player on my Sony Dav-HDX274 5.1 Channel Home Theater System With Dvd Player won't open. When I push eject (on both the unit and remote) it will read open or close and although it sounds like it is...
It sounds that the laser pickup unit to your HTS is faulty. Contact any service technician to replace it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 16, 2014 | Sony Dav-hdx274 5.1 Channel Home Theater...
Aug 28, 2008 | Audio Players & Recorders
SOnt DAV S550
There is a gear underneath the tray that may be broken or possibly the open close detect switch nay be bad. You will have to remove the tray,you will then see that gear.
Aug 10, 2008 | Sony DAV-C770 System
Comcast on demand custom dvr 3 device codes for sony dvd-hdx576wf
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Good luck. Let me know if it works.
Aug 06, 2008 | Audio Players & Recorders
Dav-DZ100
hehehe, its funny problem. let me try to help you.
1- Press Power to turn the set ON.
2- select DVD function.
3- press STOP and EJECT buttons for Five (5) Seconds.
4- the message UNLOCKED will display.
Enjoy n have nice day ;)
Jul 19, 2008 | Sony DAV-DZ100 System
Tray Stuck
I managed to open up the player and found that the drive belt for the tray opener had come off. I simply replaced it and away it went
Apr 12, 2008 | Sony DAV-SB100 System
Error with DAV-S500
Sony DAV-S500 error c-81: On the rear side of the DVD board connected to the DVDv drive is a power transistor Q002 that is shorted BASIS-EMITTER. The device is an Toshiba 2SA1213Y (PNP transistor 1$) Replace and your DVD works! good luck :) Foxi from Budapest, Hungary, Europe
Jun 11, 2007 | Sony DAV-S500 System
173 people viewed this question
 Grubhead
Grubhead
