Question about Samsung SIR-S4040R DirecTV DTV Receiver / 35-Hours Video Recorder
On the converter box that we hooked up we are geting every channel except 5-1 5-2
  • pamelabrown7 Oct 19, 2008
    on the rca converter box that we hooked up we get all the channels except for channel 5 any help with this would be greatly appriciated thanks
    Problem Solver:
  • 5 Answers
Any -1, -2 channles considered as a off-air antenna channels. I assume you have the off-air antenna and good reception on it. So make sure your off air antenna hooked up to your receiver.
If everything is hooked up right and your reception on antenna is good, try to trace the line for your antenna. may find any visual problems such as loosen up, dog chewed the cable etc :D
Last thing if you don't find solution by yourself is call your service provider for service call.
Good luck
Posted on Oct 19, 2008
Cannot locate local channels from ematic model#AT103B
you hook to this a flat panel tv?
you don't need converter box with a flat panel
Mar 16, 2016 | Televison & Video
How do I hook up Coby 5" black & white TV to my digital converter box ?
You will need a digital to analog converter which you can get at Radio Shack, Best Buy and most big box retail outlets or online. Your Coby is most likely analog and will require the digital signal to be converted to an analog signal from the digital converter box to the TV. UNLESS the digital converter box has analog (round connectors on the back) then you just need an analog RCA cable (which you can also get almost anywhere even your local CVS/Walgreens) to make the connection.
Nov 24, 2014 | Coby Televison & Video
Panasonic Viera LCD TV Can't Find Channel 7
I can't receive channels 3 and 6 right across the Delaware in Philly. Welcome to the club.
Aug 15, 2017 | Panasonic Viera TC-L32C12 32 in. LCD TV
Converter boxes hook up
u need a stronger antena , best check without the converter box and see if u get chanels , if u do hookup the antena to the converter box then to the tv and do the scan again , move the antena to diferent places
May 01, 2009 | Funai Trutech 13" TV
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
HDTV converter box only brings in 3 channels
We have a pretty good signal when we use the antenna but when we hook up the converter box we get no channel weak signal no channels we have a amplipher on it it does not help .
Nov 22, 2008 | Insignia Digital-to-Analog Converter for...
Insignia Digital to analog converter menu doesn't come up
When my Menu did not come up, I found it on the AUX channel (one below channel 3). I was able to go through the set up, but found only one digital channel available. Hope this helps!
Nov 10, 2008 | Televison & Video
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
I have purchased the converter box to receive digital signals and my tv doesn't have the red/yellow/white connections. Is there a model of converter that will work on this tv which is an RCAModel F25423...
THE CONVERTER BOX HAS R.F. OUTPUT. JUST HOOK IT UP AND PUT THE T.V. ON CHANNEL 3.(OR WHAT EVER THE INSTRUCTIONS THAT CAM WITH THE BOX) YOU WILL NEED TO CHANGE THE CHANNELS WITH THE REMOTE THAT CAME WITH THE BOX. YOU MIGHT NEED TO SET UP THE BOX (SCAN FOR CHANNELS) THAT IS ALL IN THE INSTRUCTIONS THAT CAME WITH THE BOX.
DON.
Jun 15, 2008 | RCA Televison & Video
Insignia NS-DXA1 - Digital to Analog converter box
I have had my converter box 5 days now. I hooked it up to the TV and set it up. No Problem. Except there are no instructions on how to set up the VCR/DVD player with it, which we use more than we do watching TV. Everything worked fine until on the second day we had it I read I could program the remote to turn the TV on and off. I followed the instructions and the TV went off. When I turned it back on, my remote went berserk. If I try to change a channel it will quickly flip through all the channels until I turn the converter box off. Same with the volume, it goes up and down, up and down until I shut off the box. The remote does not work unless you are about 1 foot away from the box. And the remote has never turned the TV on or off except that first time I programed it.
May 19, 2008 | Insignia Digital-to-Analog Converter for...
Samsung SIR-S4040R DirecTV DTV Receiver / 35-Hours Video Recorder Logo
100 people viewed this question
Henry  Thomas
Henry Thomas
