Question about E-Machines e15t 15" Flat Panel LCD Monitor
Emachine 17" lcd monitor from Best Buy
I just purchased an emachine 17' ldc monitor from Best Buy and it worked fine for about an hour. I pressed the Auto adjust button on the monitor to callibrate the size of the new monitor and it was working fine. Then when I tried to reboot I got an error message that said 'No Signal' I tried to restart in the safe mode and I got a 'VGA' error. Then tried to run the Microsoft scan disk and it stopped (3 times) at 24%. I called Best Buy and they said their Geek Squad would charge $75 to evaluate the problem that occured due to the product I just purchased from Best Buy. Does anyone know how to get this emachine monitor to work?
  • Bill Speer
    Bill Speer May 11, 2010
    Is the screen set up as an analog or digital input and which one are you using to connect the monitor to the computer?
    Habit-Forming:
    Scholar:
  • 58 Answers
1: Check the cable connections for the VGA or DVI cable at both ends for a secure connection.
2: There may be a button on the bezel of the monitor for input source to switch between VGA, DVI, or HDMI. While the monitor is on, press that one or more times waiting 2 or 3 seconds between presses to see of it finds the signal.
Posted on Apr 10, 2017
SOURCE: Emachine monitor E17T4 does not respond when the front switch is depressed
Have you found a solution yet? I just posted the same problem with my E15T4.
ken
wa2kkg@gmail.com
Posted on Feb 02, 2008
SOURCE: eMachines TFT LCD Gone Black
I have a E17TR (17") version that a friend gave me (free) a few months back, and just this morning it failed in the exact same way.
My theory is that the image is there but that it is just not being illuminated (so that I can see it). Such a case would suggest a problem with the Backlight or the Inverter.
I have found two web pages (from a company selling LCD repair parts) that can explain better than I.
http://www.lcdparts.net/CCFL1.aspx
http://www.lcdparts.net/DesktopInverter.aspx
Hope this help (the pages educated me).
Now if I can just figure out how to open the case; I took out the 4 screws (on the lower end of the back panel), but it just will not open in any way that seems logical . . . .
Gary
Posted on Feb 14, 2008
leroyal
  • 2120 Answers
SOURCE: eMachine computer fans run but no monitor picture
Remove and reinstall memory.
Posted on Feb 13, 2009
noone
  • 105 Answers
SOURCE: Monitor works in dos starup, but fails in Vista startup mode.
Sounds like windows resolution or refresh rate is too high for the 15" monitor. Try starting in safe mode and setting the resolution below 1024 X 768 and refresh at 60. Restart.
Mike
Posted on Feb 17, 2009
Dreamornaut
  • 55 Answers
SOURCE: Emachine T2385 Won't Boot in Normal Mode past Windows XP Screen
The first thing I would check is your video card (usually driver) problem. Start windows in safemode with networking. If this problem has occured after updating the video card driver you may try rolling back the driver to a previous version, otherwise try
Once windows starts you'll want to go to the start menu and find and click run. In the text box enter the command "devmgmt.msc" and hit enter and the device manager should appear. Look for display adapters and left click the + and you should see your video card. Right click the video card and select properties from the drop down menu. Select thr driver tab. Now if the problem had occured after updating the driver, choose rollback the driver from the menu. If not try selecting the update driver option. After updating/rolling back the driver you'll want to try restarting in normal mode.
If it still won't start in normal mode you can try troubleshooting the video card under the general tab in properties, though to be honest I've found this rarely usefull but it might help you. Otherwise you'll want to make sure that your videocard is enabled in BIOS. A quick totorial of BIOS if needed http://www.tomshardware.com/reviews/bios-beginners,1126.html.
Otherwise it's likely a physical issue with the graphics card. Since you've tried reseating the card already it may be that the card is damaged and will need to be replaced.
Posted on Aug 13, 2009
Would this monitor be covered on any warranty? I cannot find my receipt. When powered on, the screen stays black.
The warranty is 36 months parts and labor. If you have and the monitor longer than that it will not be covered. If you have had it less time than that, you can normally get a copy of the receipt from the place of purchase (example Best Buy). If you purchased an extended warranty from vendor (example Best Buy), you should be able to take it back to them for repair or replacement.
I hope this helps
Aug 31, 2011 | Envision EN7410 17" LCD Monitor
The display on the screen is jumping and does not hold still. Can this be fixed or is it time to replace the monitor?
A "previously-owned" 17-inch LCD screen probably will cost $30 to $50.
A brand-new 17-inch LCD screen is hard to find -- probably, nothing less than 19-inches is being sold, for $100 to $150.
An audio/video technician will charge $60 to $75 per hour to try to repair your LCD.
So, responsibly recycle (or "free-cycle") your old screen, and purchase a new 19-inch screen.
Jun 20, 2011 | Gateway FPD1760 17" LCD Monitor
Monitor takes anywhere from 15 minutes to more than an hour to produce a display after starting the PC. It starts by flashing briefly on the screen, and eventually produces a display. It works fine after...
Sounds like you have an LCD inverter going out there might be some leaky compasitors on the main board. Its probably cheaper to buy a new one then to have a repair center fix it. Unless you know someone who is good with a sodering iron.
Best of luck and have a happy and safe 4th of July!
Jul 02, 2010 | eMachines E17T4W 17" Monitor
The menu constantly pops-up on my Samsung 17 inch LDC monitor
what does the pop up menu say? I'm guessing it says something like "Optimal settings are 1280x1024, Press 1 to confirm, press 2 to disable". If the message is anything like this, your monitor is trying to tell you that your display settings are less than optimal. You can either disable the message by "pressing 2" or changing your display settings to the recommended resolution. If the menu you're getting is just the control panel and there's no actual message, leave your computer on, reach around the back and disconnect the power cable from the monitor, wait 5 seconds and plug it back in. Samsung monitors sometimes have a glitch and need to be reset.
May 13, 2009 | Samsung SyncMaster 173V 17" Flat Panel LCD...
Mike
Feb 16, 2009 | E-Machines eMachines Monitor E15T4
Cables for the KOGI 17"
Any Computer Electric Plug Will Work But The Cable For The Screen To Hook To The Computer Can Be Bought On Ebay, Circuit City, Radio Shack, Best Buy Wal-Mart Even.
Jan 05, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Computer turns on and off repeatedly
it sounds like your ram or video card is not functioning. You can try some different ram and video card and that is where i would start. This is probably not going to be an easy fix so be ready
Dec 24, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Dell 17" lcd tv monitor
Follow the link below for solution.
http://babelfish.yahoo.com/translate_url?doit=done&tt=url&intl=1&fr=bf-home&trurl=http%3A%2F%2Fangelitodiaz.blogspot.com%2F2007%2F10%2Fmonitor-dell-w1700.html&lp=es_en
Oct 11, 2008 | Dell W1700 17 in. HD-Ready LCD Television
E-Machines e15t 15" Flat Panel LCD Monitor Logo
164 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
