Question about Texas Instruments TI-15 Explorer Calculator
TI-15 square root Function
When I enter square root 36 equals syn error; 36 square root equals syn error what am I doing wrong? Deb
  • 1 more comment
  • Anonymous Mar 17, 2014
    -r6-r6
    closest integer
    what do i do?
  • Texas Instru... Master
  • 7,993 Answers
You should enter it as follows [SQRT]36 ) [ENTER/=].
If you define some function f of a variable x you write that f(x), where the parentheses enclose the so-called argument (objet on wich the function acts). It seems that on this calculator the opening parenthesis is implicit: the calculator supplies it when you press [SQRT] but does not display it (a design flaw?). However the closing parenthesis must be entered by you to signifie to the function [SQRT] that you have finished entering the argument. Weird but one can live with it.
Hope it helps.
Posted on Sep 07, 2009
Square roots doesn't work
Two ways the calculator may work:
Enter a positive number then press the square root key, or
Press the square root key then type in a positive number and press =.
Feb 09, 2016 | Texas Instruments TI-15 Calculator
What is the square root of 30?
We are asking what number, times itself, is equal to 30. Five times itself is 25. Six times itself is 36. The answer is somewhere between 5 and 6. Let's split the difference and try 5.5. 5.5 times 5.5 is 30.25. This is above 30, so let's try a smaller number, 5.4. 5.4 times 5.4 is 29.16. This is lower than 30, so we need a higher number. How about 5.45? I get 29.7025. We need a number a little higher. How about 5.47? I get 29.9209. Still need a little higher. How about 5.48? 30.0304. So it is somewhere between 5.47 and 5.48.
On a calculator, you can use the square root function. Sometimes you have to enter the number before you hit the square root function and sometimes you need to enter the number after hitting the square root function. Another way of doing it is to use the exponent function, usually with a y to the x key or a ^ key. Enter 30, hit the exponent key, and then enter 1 divided by 2 in brackets.
I get approximately 5.477225575051661134569697828008.
Good luck.
Paul
Mar 29, 2015 | Office Equipment & Supplies
Square Root Again
On a TI 36X Solar, you enter the number and press the square-root key.
If you're asking about some other calculator, please reply to this post and specify the make and model of the calculator.
Apr 16, 2014 | Texas Instruments TI-36 X Solar Calculator
Math hypotenuseof right triangle
Press 2ND square-root 1 5 x^2 + 3 6 x^2 ENTER
Dec 03, 2013 | Texas Instruments TI-83 Plus Calculator
Does my ti-86 solve sq. root problems
Yes, your Ti 86 should solve square root problems. At the HOME screen press [CLEAR] [2nd] [x^2] which gives the (Square Root Symbol) to display at the Home screen. Then enter the number you want the square root of and close the bracket [ ) ] and, press the [ENTER] key.
You can even get the square root of complex numbers too. Select the correct complex format in the mode settings. For example: I'll do one in the rectangular form by enter a number as (a, b). I then will go to [2nd] [MODE] then [Arrow down] 3 times and make sure the RectC is highlighted and selected. Then quit out of the mode settings screen and enter [CLEAR] [2nd] [x^2] [ ( ] [9] [ , ] [ - ] [4] [ ) ] [ ) ] [ENTER], this displays the SQRT((9,-4)) equals (3, 2); The real part is 3 and the imaginary part 2.
Jan 09, 2011 | Texas Instruments TI-86 Calculator
Square Root
Don't forget to close the parentheses.
To compute the square root of 2, press SQRT 2 ) ENTER
Mar 09, 2010 | Texas Instruments TI-15 Explorer...
How do i use the square root on my ti 36x calculator? thanks,marie
There is a dedicated key for the function. The key is labeled as on the third line of the table below. You enter a positive number, press the key and then hit [=]. Hope it helps.
Nov 16, 2009 | Texas Instruments TI-36 X Solar Calculator
How do i put the square root of a problem in a TI
Use the square root key accessed after pressing the [2nd] function key.
Press [2nd] [Square root key] 121 [ ) ] [ENTER]. Do not forget the right parenthesis, even if you did not have to enter the left parenthesis.
The result should be 11 (one of the square roots to remember).
Hope it helps.
Oct 24, 2009 | Texas Instruments TI-30XA Calculator
Trying to find the hypotenuse of a trangle
A squared + B squared = C squared
15 squared + 15 squared = C Squared
225 + 225 = c squared
450 = c squared
the square root of 450 is 21.21320433
May 12, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-15 Explorer Calculator Logo
1,540 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
