Question about Mitsubishi VS-45603 45" Rear Projection Television
I Can't See Anything
The problem with my television is that I can hear what is going on but I can't see anything. All I get is a blue screen.
    President:
  • 3,130 Answers
One of two differant problems. One Maybe the blue tube is shorted?? Two is there picture in picture built into this set? yes ok its the PIP video processor pcb. NO ok then theres a problem in the video jungle circuit. None of these problems are customer servicable as there are no user serviceable parts inside these sets and should be serviced by a quilified service person. Thats mostly because of the Hi Voltage dangers inside these sets Even when they are unplugged! Call a repair center as in the long run it will cost ya less. Good Luck
Posted on Jun 14, 2006
SOURCE:
I have a image on my screen that won't go away. i can hear the tv but can't see anything but image on screen
Check and replace the T'Con board. If you wish to get some details; check the site linked here. Pull up older posts.
Sep 28, 2016 | Samsung Televison & Video
Out of no where my Vizio won't show cable, Blue Ray, or shows on Roku. One of the HDMI ports hasn't worked well for awhile so would have to switch HDMI ports to watch Roku or Blue Ray, but overall worked...
you may need to change the HDMI board in the tv. it will be the hole board the parts are just to small to replace them all to get the HDMI board working again. find a second hand replacement. should be fine with another known working one.
Sep 21, 2013 | Vizio Televison & Video
It has a blue screen i cn hear but not see
The blue screen appears when there's no signal so probably the video cable is out of its socket or broken.
Jan 16, 2010 | iLO V27DMBX Television
Rca rear projection screen way to much blue
replace convergence ics .press the menu and go into the convergence
alignment.see if you are able to align the blue convergence. if not replace the convergence ics.
Aug 04, 2009 | RCA P52771AT 52" Rear Projection...
Turns on .encripted channel comes up. cant switch channels
threw the damn thing in the trash. will never buy another ilo tv. this is the replacement for the first set that quit working. thank you
Feb 18, 2009 | iLO 2600 Television
Sony Color Rear Video Projector - KP 57hw40 / Mfg. February 2002
i have the same problem picture is blue/green with blue and green arched horizontal lines
no picture at all only sound then tv shuts off after 5-10 seconds and then a bright blue flash in the center of the screen
have tried adjusting the voltage screws didnt do anything
Jul 13, 2008 | Sony KP-57HW40 57" Rear Projection...
Olevia LT27HVX 27 just blue screen
I just had this same problem over the weekend. Is your TV hooked up via HDMI?? Mine was and i've been having problems with the tv image shrinking whenever i turn on the tv, so i would have to change the channel 1 or 2 times for the image to come up normally. On Saturday I went to change the channel and then all of a sudden I hearld this loud pop and when the image came on it was just a sky blue screen, I couldnt see anything, but I could hear the channel. So I disconnected the HDMI and hooked up the tv with component cables I had and now it works fine. I ordered a new HDMI cable just to see if it will work again. If not, i'm calling Olevia.
Feb 18, 2008 | Olevia LT27HVX 27 in. LCD Television
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Televison & Video Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
