Question about Janome 1600P-DB Mechanical Sewing Machine
Skipping stithes i have a janome 1600p-db .i am trying to quilt and the thread is skipping. the machine will stitch once or twice then skip a lot ,then pick up a few stitches,then skip many more over and over.the fabric is a batik,batting is warm and natural,thread is king tut.the needle is 100\16.all are recommended by janome.i am using the free motion foot that came with the machine.this is a brand new machine.could the timing be off?i bought it on-line.the dealer is in cal. and i am in Cincinnati . thanks
  • LydiaMA May 07, 2009
    My machine is on a Grace Frame and does the same thing. I have tried everything posted on this site to rectify without success. Needle, tension, bobbin, frame take up rails height. My biggest frustration is all these skipped stitches.
    Problem Solver:
  • 6 Answers
Try practicing on a test piece before moving on to the quilt. Batik fabric is beautiful! I would check the thread size and needle. I tried quilting with invisible thread and had the same problem. The minute I changed to 50 wt.thread and a new needle the problem disappeared. I've found that 40 or 50 wt. thread works best on my Janome.
Posted on Oct 21, 2009
Janome 1600P skipped stitches
Normal top tension is 3-4; normal bobbin tension (iirc) is 35 grams.
I'm betting, though, that a new needle, right way around and the correct size, would solve your skipping problems.
Jan 15, 2014 | Janome 1600P-DB Mechanical Sewing Machine
Trying to quilt on my Hinterberg. First the thread kept breaking. Made some tension adjustments, now I am skipping stitches
possible problems
1) too thick for the feed dog to move the fabric forward need; lighter tension
2) are the upper and lower threads the same kind of thread?
3) is the thread feeding properly from above? sometimes the spool can snag the thread causing the tension to jump and skip stitches
I have a Janome 1600P DBX. The needle is installed correctly but the thread on top keeps breaking or skipping stitchings while free motion quilting? the quilt shop says it is not out of time. I have...
Is it a new needle? a dull needle or one with a burr on it can cause those problems that you mention.The kind of needle you use is also very important. I like to use a 70/10 or 80/12 jeans needle depending on how thick the thread is.
Apr 20, 2011 | Janome 1600P-DB Mechanical Sewing Machine
As others have written, my upper thread shreds and if I loosen the tension, I get skipped stitches. When not quilting, she runs just fine HELP Ann Marie
change the needle
rethread the machine
some needles & thread are not compatable-try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
check to make sure there are no burrs on any of the thread guides
try a 3 or 4 top thread tension
Nov 03, 2010 | Janome 1600P-DB Mechanical Sewing Machine
I'm using a Janome 1600 DBX on my Grace quilt frame. It keeps skipping stitches and breaking the thread. I put in a new # 16 Janome needle - made sure it was installed correctly, and tried 30 weight and...
The tension is not right and you are moving the machine to fast. Go back to your 50 weight thread top and bottom. Have you got a quilting foot on and the foot in the down position
Dec 01, 2017 | Janome 1600P-DB Mechanical Sewing Machine
Feed Dogs on Janome 1600P
I recently purchased a Janome 1600P-DB and in order to do free motion quilting I had to cover the feed dogs with an index card. I also cut a small section out of the card to allow for the thread and needle to move freely. Standard tape was used.
Jun 14, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Skipping stitches
Rule of thumb: Fast needle, slow hands. This should help. GiGi
Feb 19, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Janome 1600P DB Stitch length
The machine is skipping stitches and is probably out of time. Change the needle, rethread the machine and try it again. If it still skips stitches, try lowering the needle by about 1/16 inch and see if it works better. If the timing is off you should take it to a technician for a complete service.
sewman7
Jul 14, 2008 | Janome Sewing Machines
Skipped stitches
You will need to take your machine to a dealer and have it adjusted. Machines should be cleaned and serviced at least once a year. Needles should be replaced when dull. Skipping stitches can also be from using the wrong kind of needle. When quilting on cotton, use sharp needles, when sewing on knits use a ball needle. You can use a universal needle but they aren't perfect and will cause skipping on some fabrics.
Apr 26, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Janome 1600P-DB Mechanical Sewing Machine Logo
528 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
