Question about Hotpoint HSS25GFP Side by Side Refrigerator
GSH@%JSTASS - No water, Ice ok, Filter changed, defrosted...still SMART water is not coming
GSH25JSTASS -- I have a one year old ref..Same problem..Ice comes fine, no water. Changed filter..defrosted Freezer compartment. Kept the light ON for a couple of days, .used compressed air to check water tube between water disp to bottom of the freezer. Not frozen...
What could be wrong with this SMART water filter from GE! My water quit working a few days ago...replaced filter - ice appears to still be working. Not sure what to do.
  • 1 more comment
  • twms Oct 29, 2008
    My fridge is two years old. I did have a problem with noisy compressor motor but had it fixed under warrenty. Last week, the water stopped working. Ice ok, just water. Any suggestions?
  • workload3 Nov 01, 2008
    No water. Ice is fine. Changed filter. Still no water. Lines are not kinked. Any help out there?
  • worksonit May 11, 2010
    dont buy ge
The first step for put the used my
frigerator
Posted on Oct 19, 2008
2 Suggested Answers
  • 61 Answers
SOURCE: GSH@%JSTASS - No water, Ice ok, Filter changed, defrosted...still SMART water is not coming
http://www.geappliances.com/search/fast/infobase/10003601.htm
there are only so many comonents to the water suply
ensure there is a clicking sound when you go for water to no the solinoid is actualy actuating. hope this link helps.
Posted on Oct 20, 2008
Ge gsh jstass
There could be problem with the electronic control board. This controls the fan operation as well as all other operations of the refrigerator.
May 19, 2014 | GE Refrigerators
Water dispence slow
do you know if it is a whirlpool made model, 27ft french door, ice maker in ceiling, they had issues with a seal between ice compartment and ref side- leaks freezing air to water tank area, freezing tank. other wise if its not the filter -then water flow to unit. ck where it connects to ref, if good( should have steady stream with press. replace ref valve if bad look at your valve in wall or at sink.
Sep 14, 2012 | Kenmore Refrigerators
General Elec. refrig. about 12 yrs. old. water in bottom of frig., cleaned up, found water a second time.
drain is cloged. at some point the ref section was set too cold. the defrost water from freezer drains through the ref back wall. becaust it was set too cold the drain froze. two ways to fix .... empty unit and unplug for 24 hrs. OR remove back panel, defrost drainrail, remove bottom panel ,remove ice, insert 1/4 inch tube down drain, and squirt very hot water down drain till it is clear of ice..... when defrosted set ref on "3"
Aug 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water Dripping and freezing from icemaker fill spout.
I appears that no one offers solutions to the hundreds of requests on your website. I don't have enough time to wait for an answer from you folks.
Aug 03, 2009 | GE Refrigerators
3 year old kenmore top freezer, won t defrost ''no ice'' buildup behind the freezer panel I removed. no clicks on the defrost test, same result for method #2. The ice maker works ok when freezer is at...
your freezer had a heater and a bi metal behind its pannel. if they won't work properly than you would face problem like this.......contact your service authority. it cannot be solved by your own
May 14, 2009 | Kenmore Refrigerators
Oct 18, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE GSH25KGMBWW REFRIGERATOR WON'T GET COLD AFTER REPLACING SOLENOID
The ref is iced up because of the ice door being left open, you will have to manually defrost the ref by leaving it open for 7-8 hours,put you food somewhere else.
38 years exp burke
Sep 22, 2008 | GE GSS25JEM Side by Side Refrigerator
WATER DISPENSER,
Aug 02, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Samsung SR-S22FTCS
dear friend
The water filter doesn't affect the cooling perfomance of ref.ther may be problem of defrosting of ref.compartment.
regards
sandy
May 17, 2008 | Samsung RS2534 Side by Side Refrigerator
No water nor ice comes out
do you have water pressure to ref. water control valve? check voltage to water control valve assy. note: very difficult to diagnose these control valves, replace them both and be done with it.
Apr 23, 2008 | Maytag MZD2766GES Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
280 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
