Question about SAMTRON 55V 15" CRT Monitor
No monitor Installed new Gforce graphics card (hp-pavillion),after hours with tec. support, and deleting on board driver, lasted one day, then lost monitor(lg) stays in power saving mode, tec. suggested power suplly , installed new 450w still same no monitor HELP?????
  • flynntrades Oct 19, 2008
    Thanks, tried that earlier, all are good, I'm having a hard time with deleting the on board driver, questioned it during tech. support, but it seemed to work, for a day!! now what, I've pulled the bat. still nothing I'm wondering if I should locate an xp recovery(since wasn't supplied) would that do the Job????
  • flynntrades Oct 22, 2008
    Thank you, but I can't even get into bios, I have try the F8 upon start up, even try hp's F1, wait 5sec. F5 F8 to save, still can't get monitor. I have given up, and sent the tower in for repair thank you all for the support.
    Scholar:
  • 136 Answers
If you have been fiddling around with the vga cord, you might have bent one of the pins, or problably dislodged the vga card. Try taking it off and back on. Sometimes is as simple as that.
Posted on Oct 19, 2008
  • velut_umbra Oct 21, 2008
    There must be an option in BIOS to enable/disable the onboard vga.
    Once disabled, boot in safe mode and uninstall the gforce software. Reboot and wait for it to recognize the new hardware. Cancel the automatic instalation, and use the driver cd that came with the gforce.
I cant install drivers
Go to the manufacturers website (nvidia) and download the most current driver for your 32-bit machine. If you have upgraded to a 64-bit processor your driver would be IA-86-32 (x86). Make sure you download the correct bit dor the driver
You do need a new driver for the new gforce but only nvidia can give you the correct one.
Apr 04, 2012 | Evga NVIDIA GeForce 8400GS, PCI Express...
HP pavillion a6300f pc when powered on, the fans come on and can feel the hard drive spinning, however there is no video output; I took the pavillion to another pc monitor and same result, no video output....
If it shows the bios on your screen.... Try to go the bios setting and make check the "default operation" and save upon exit.
Check the Motherboard, if there are swollen/bulging capacitor on the board, replace it.
If there are no bios whatsoever, sad to say, problem will be the board already......usually the bios chip that breaks down.
Try to use another power supply, sometimes the power supply is the culprit of the boards problem.
Hope that helps you out!
Aug 09, 2011 | HP GX613AA Pavilion A6300F Desktop PC
Cannot get a g force 5500 to work in a new hp a6700y its plugged in but will not work it has a integrated gforce 6150 in board but will not recognize the new card
Hi..
Make sure that your motherboard can support your new installed video card. Check also that it is plug correctly, try to remove it first and reinsert it again. Remember that the video card are not working properly if your video card driver is not installed.
You need to installed the video card driver.
ICmanServer
Jul 03, 2009 | Nvidia GeForce FX 5500 Video Card Graphic...
I have the hp w1907 monitor ( lcd ) and whenI switch programs it flashes and freezes up programs untilI hti the task manager. I am running windows xp home on an hp pavillion m8400f with a nvidia gforce...
I don't see how this can be a problem with your monitor. Your monitor is simply showing what is happening with your computer. I think the nvidea driver is probably at fault. Pls update with the latest version for your operating system.
Jul 03, 2009 | Computers & Internet
How to get gforce card in pci-e slot to run a second monitor?Help
all you need is the latest drivers for your graphics card...
it contains the software needed to control your dual displays...
Jan 29, 2009 | XFX GeForce4 MX440, (64 MB) Graphic Card
Installed new video card but the signal remains black
REMOVE THE CARD AND UNINSTALL THE VIDEO CARD IN ADD REMOVE PROGRAMS. THEN REMOVE VIDEO CARD AND INSTALL DRIVERS THEN INSTALL YOUR VIDEO CARD. I HAVE THIS SAME VIDEO CARD AND HAD THE SAME PROBLEM.THIS WAS THE ONLY WAY I COULD GET IT TO WORK. ALSO YOU NEED TO DISABLE THE VIDEO CARD THAT IS ON YOUR MOTHERBOARD. YOU CAN DO THIS IN CONTROL PANEL. ADMINASTRATIVE TOOLS THEN CLICK COMPUTER MANAGEMENT THEN CLICK DEVICE MANAGER GO TO YOUR DISPLAY DRIVERS AND DISABLE YOUR GRAPHICS CONTROLER. THAT SHOULD DO IT. HAPPY NEW YEAR.
Jan 08, 2009 | HP Pavilion A6010N (882780985575) PC...
K9mm-v via k8m800 + vt8237r / amd athlon / running ubuntu 7.10 video problems
MY GUESS IS THE NORTH BRIDGE ON MOTHER BOARD IS BAD, REPLACE MOTHER BOARD.
Dec 16, 2008 | Computers & Internet
New wide screen monitor incompatibility issues with older comp
The two cards(Gforce Nvidia card) might not be compatible for your motherboard because they're for heavy graphics like playing games, and *********** board is old that you;ve mentioned. including the message memory range unavailable. Try using your old card with the new monitor.
Nov 25, 2008 | Computers & Internet
Fifa 08
go to ea site and download the patch
Sergio
install also the nvdia drive.
Mar 27, 2008 | Nvidia 64MB GeForce3 AGP Video Card with...
Video card
actually your computer is working on the onboard video adapter.
1. connect first the monitor to the onboard video card.( do not remove the connected geforce video card.)
2. switch on the computer and press "F2" on new model computer, "Delete" on old model computer.
so that you can enter to bios setup.
3. if bios setup is open; try to find the "AGP bridge configuration"
(some other bios AGP B C is in chipset) by arrow up,down,side left and right) enter.
4. Find " primary graphics adapter"
5. In there, select : If Video card is "pci" connected ; select "pci"
If Video card is "AGP" connected ; select "AGP"
6. press F10 to save and exit the setup.
7. after saving the configuration, disconnect power cord and transfer the monitor to the video card (Gforce). and then connect the ac power cord and then start. or switch on the computer.
Note: be sure to install the drivers of your GFORCE for optimum performance of the card.
hope this help.
Dec 21, 2007 | ASUS P4P800 SE (890552603657) Motherboard
SAMTRON 55V 15" CRT Monitor Logo
69 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
