Question about Sony CDX-M850MP CD Player
Help ASAP Plaese
I hooked up my Amp to my sub out on my stereo, the amp turns on but I get nothing out of my subs. I know they are not blown because i already tested them . help please any suggestions?
    President:
  • 3,130 Answers
Are you saying you connected the sony output jacks to your subs directly without any other amp? Are the sub outputs powered? Or line level? Are the subs powered or direct? need some more info please. and post the Manual here if you can. Thanks
Posted on Jun 14, 2006
SOURCE:
My amp is on but the subs don't work Kenwood amp
Ok. Simple test to check if your subs are blown. Hook up speaker wire and simply touch each wire to each end of a new aa battery. You should hear like a sizzling static sound from the sub and it should jump slightly if its good. If subs are good you may be having issues with the connection terminals or worse. And it could simply be the audio connection from the stereo or the audio wires need replaced. Possibly replace the stereo or amp. So many more options but this should get you headed in the right direction.
Sep 04, 2014 | Car Audio & Video
I have a stock stereo and two subs with an amp in the trunk. Also two alpine speakers in the rear. Whenever I turn my balance to the left my subs don't play. What's wrong?
Hello.... I am sorry to hear you are having problems. The reason for this is that since you have a stock stereo, the shop (or person) whom installed the amp and subs used a line out converter. What this part does is allows the connection of RCA cables to the factory head unit. Almost all bass signals are always in stereo, so since you were only hooking an amplifier for just subs, you can actually just connect to just one of the rear speakers instead of connecting to the right and left. Just makes the install a little quicker. There is nothing wrong with this as I usually do the same thing in our shop. However, if you are going to be using the balance control, then you will need to go back to the shop and have them hook the converter up in stereo (to both rear speakers). Hope this helps!
20 year car audio/video installer
Bay manager
Mar 15, 2011 | Alpine Car Audio & Video
Sony radio sub outputs don't work at all
you may need a new head unit. it sound like you have lost the fron rca hook ups on your unit. common prob. usually cause by a surge traveling then the rca cables. i myself have had this happen and there is nothing you can do to the unit to fix it.
Sep 26, 2009 | Sony XS-V1330 Coaxial Car Speaker
Amp dosnt work right
your amp cant handle the impedance of your subs i.e your running a 2ohm sub on a 4ohm amp!
Change the wiring on the sub so instead of running at 2ohm your run at 4
if you need to know how to wire up your sub to run at 4 then take a look at this wiring diagram
take a look at option 2
Click here
Hope this helps if so please dont forget to rate :)
Upfront Audio
Apr 13, 2009 | Pioneer GM-5100T Car Audio Amplifier
KAC-9102d no sound, Amp powers on but no sound to the subs.
If the sub isn't working, you won't get a pop. All you need is a small speaker. Don't need a sub, you just want to test the sound. I recently blew 2 subs, no smoke, no smell, no sign of being blown. Absolutely nothing from the subs.... In the past my sub locked up. You can take your sub out of the box and hook the + and - to the battery to see if you can get the sub to pop there. I believe a small box will push a sub into a deep excursion to the center of the cone. I have 2 lanzar VW12D's that just quit. I hooked a 6 x 9 up to my amp and low and behold I had sound! Try that and see what you get...
Feb 07, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Amp and Stereo hooked up, no sound coming from the sub
It sounds as though either the sub or amp is blown. When an amp blows quite often the light will still light, but the internals are trashed. The only surefire way to tell whats going on is to use a Digital Multi-meter to check the impedance of the sub, and the voltage at the amp. You can get a multimeter as cheap as $10 at most autoparts stores, Radioshack, Sears, etc...
Also, always post brand names and model numbers, because more info equals more help.
Apr 30, 2008 | Car Audio & Video
Subwoofers not getting music
looks like you need to check the SOURCE of where the signal is coming it could be that your CD car stereo SUB opt. is turn off , check the menu of SOURCE and switch to SUB on , hope this helpful
Apr 28, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Hooking up DVC subs
The amp is rated to run a 2 ohm load on each channel. To do this, connect the voice coils of one sub in parallel (tie both "+" on the sub to each other and both "-" on the sub to each other), then connect that sub to one channel of the amp. Repeat this process for the other sub and connect it to the other channel on the amp. The subs will be in stereo and the amp will be outputting it's maximum power.
Mar 09, 2008 | Legacy 2CH 1000W AMP Car Audio Amplifier
The light on top on my MRP-M450 blinks and the amp doesn't work
Well if you took off the cover on the amp and nothing seems to be burn't, check the voice coils on the sub. It's possible the voice coils have separated and is causing the amp to short it self out due to ground error. If that doesn't help let me know and I'll tell you the next step.
Sep 29, 2007 | Alpine MRP-M450 Car Audio Amplifier
Alpine pdx 1.1000 amp
These subs are dual voice coil I'm sure...make sure they are putting a 2 ohm load on the amp total, and also set your gain and frequency setting right. Set the frequency around 85 or 90, make sure the lo pass filter is on. Turn the gain ALL the way down and turn your stereo to the point right before your speakers distort....then slowly increase the gain until the subs are playing at full volume. This should not even be close to all the way up, and the subs should sound accurate and bold. Turning them past this point will cause distortion, in which case you should back off the gain a bit. Distortion causes power to cycle through the amp very rapidly and can cause blown subs and blown fuses. If you do not know how to wire both subs for a combined load of 2 ohms, please let me know what type of subs you have.
Aug 05, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Sony CDX-M850MP CD Player Logo
102 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
