Question about 2wire 802.11b+ Wireless Ethernet Client Gaming Adapter1000-100046-000 (1000100046000)
Access the wireless ethernet client box without the setup CD
I misplaced my setup CD. Is there a way to access the wireless ethernet client without the setup CD. I am familiar with the DOS IPCONFIG command. Since the box is a bridge and you don't see the IP node when the wireless is disconnected. My ethernet linked to the bridge has IP address: 169.254.134.121. I can ping it. But I don't know how to get the wireless ethernet client(bridge)'s UI. Please help. Thanks.
  • lpang55 Oct 21, 2008
    Connecting the ethernet port of the wireless ethernet client(WEC/bridge) to the ethernet of the gateway router, the WEC will be able to get an IP address from the router so that you can login to
    reconfigure the wireless interface of the WEC.
Have you figured it out yet?
Posted on Mar 07, 2018
  • 10 Answers
SOURCE: 2wire 1800hg random no internet/random access, repair/wait fixes
It seems that you said your computer gets the ip address from your router,, which means thru DHCP of the router but if you look at the DHCP settings of your wireless card inside your computer ---the DHCP is OFF -- check your ipconfig/all command as shown in your problem too,,, your wless card does not accept the new IP which comes from your router --as DHCP is OFF on your wless card and sticks with the old ip address whereas the router maintains a new ip for your computer in its table and a mismatch occurs and you loose the internet connection ,,,,thats why repair works and then again the IP changes in the router for your computer and your computer's wless card lags behind and use the old ip adress ..... DHCP--- IS DYNAMIC , WHICH MEANS IT RENEWS THE IP address after some time and you computer gets stuck to the old one ,,, hence mismatch. "you make the DHCP -ON on your wless card too. it will be fine."
Posted on Mar 06, 2008
SOURCE: I need help installing my 2wire wireless adapter card.
I used this one:
Introduction
This document describes the procedure to install driver for the 2Wire Wireless USB Adapter under Microsoft Windows, and to run a wireless configuration program to configure your 2Wire Wireless USB Adapter to work with a 2Wire HomePortal or OfficePortal wireless gateway. These drivers work under Microsoft Windows 98SE, ME, 2000, and XP.
STEP 1 - Driver Installation
1. Make sure your 2Wire Wireless USB Adapter has not been connected to your computer USB port.
2. Double-click on the file to run WinZip Self-Extractor. The driver installation files will be placed in your hard disk in the C:\TWWUSB_TEMP directory
3. Connect your 2Wire Wireless USB Adapter to an available USB port in your computer. Windows Found New Hardware Wizard will startup.
4. Select the option to search for driver in specific location. Specify C:\TWWGUSB_TEMP as the location of driver.
5. Follow on-screen instruction to finish driver installation.
STEP 2 - Wireless Configuration
1. Run the program WirelessCfg.exe in the directory C:\TWWGUSB_TEMP. You can do so by clicking on the Windows Start button and select Run. The Windows Start button is typically at the lower left corner of the screen. Type in C:\TWWGUSB_TEMP\WirelessCfg.exe to launch the program.
2. Follow on-screen instruction to configure your wireless setting. Enter the serial number and encryption key as they are printed on the bottom of your 2Wire wireless gateway.
Posted on Oct 18, 2008
SOURCE: psp cant obtain ip address
Open a browser and type http://gateway.2wire.net or http://192.168.1.254
Posted on Apr 26, 2009
  • 73 Answers
SOURCE: Can't Access 1000SW
http://gateway.2wire.net/ This should get you into the router.
Posted on Aug 29, 2009
  • 72 Answers
SOURCE: 2WIRE wireless router
While changing the name,its not in wireless router.
!.switch off the wireless router.
2.first change the name of the PC.(don't connect to wireless)its normal name changing.
3.Restart the PC.
4.Now enable the DHCP on bothside.
Posted on Dec 30, 2009
I installed this router on repeater mode, connection to existing router and signal is perfect but have no access to internet... in the access router the internet access is perfect. please let me know how I...
this is from Encore-usa.com
How to use ENHWI-N3 / ENHWI-N34D / ENHWI-2AN3 / ENHWI-2AN34D / ENHWI-3GN3 as a Repeater?
  • For Advance Users, you can download this document.
  • The reason why people use a Encore wireless repeater is because some wireless remote client computers are out of range from the main network's access point (wireless router), or the wireless client is in the dead spot or the device you want to share to the network have no wireless interface card.
    The function of a wireless repeater is basically to extend the wireless signal coverage. Wireless repeater does not authenticate, screen, secure, connect to the internet, give IP address to clients, broadcast names, etc., these are the wireless router's job. Repeater only repeats what the main wireless router does to the wireless clients.
    Checklist:
    • You should know the wireless security type of the existing wireless AP/router, is it a WPA, WPA2 or a WEP?
    • The wireless security key, or password or passphrase of the existing wireless router
    • Your existing wireless router's SSID
    • We recommend that the existing network you are about to add the Repeater on have a DHCP server running and able to lease IP address to all network clients. If you are not sure about this, please ask your ISP or the person who installed your network.
    Hardware Checklist:
    • Computer with wireless device turned off. This is only to set up the repeater, once finished the wireless can be turned on again.
    • The computer must have an available RJ-45 network interface card and web browser installed.
    • A working wireless router or Access Point with one available RJ45 port
    • RJ-45 UTP/TP Ethernet LAN Cable
    • The Encore Router is set to factory default. If your Encore Router is brand new and just pulled out of the box, no need to reset. If changes were made to any settings to the Encore Router before, make sure you "hardware reset" the Encore Router to the factory default settings. Check the User's Manual on how to "hardware reset" the router.
    PROCEDURES:
    1. Hooking up hardware connections:
    1. Both PC or Laptop and the Encore Router should be turned-on.
    2. Disable the wireless client from your PC or laptop computer (if not done so)
    3. Connect the Ethernet cable to the PC or laptop computer and the Encore Router. (This can be done while PC computer and router are turned on.)
    2. Switching mode from AP Mode to Repeater Mode
    1. Using your computer's web browser such as Internet Explorer or Safari Firefox, enter 192.168.0.1 to the address field then hit enter. You should see the Encore Router's User Interface screen still in the AP Router Mode
    2. On the upper right corner of the user interface menu, click on the drop down menu and select "Repeater Mode". Click the "OK" button to the warning box. Wait around 35 seconds until your screen comes back to Encore user interface screen, this time the screen is now in the Repeater Mode. If for some reason you were asked by the repeater to enter the username and password, enter the default username and password (admin/admin) and your Encore Router is now in Repeater Mode.
    NOTE:
    As of this moment your repeater is not connected to any router or network. It has to be configured further to be able to be connected to your current network and access point router.
    3. Connecting your Repeater to your existing network access point or router:
    1. As soon as the Encore Router switched to the Repeater Mode, you should be able to see the same Utility Screen with fewer selections on the left pane.
    2. From the Main Menu screen click on "Wireless" located on the left pane.
    3. Click on "Site Survey" button, a new Window dialogue box will pop up showing a list of Access Points reachable by your Repeater
    4. Check your existing network's access point SSID then click on the radio button that corresponds to your access point router then click "Connect" button.(If you can't find your existing AP router, click on "Refresh" repeatedly until your access point show up, or your location is too far from your existing AP router).
    5. Click on the "Encryption" drop down menu, select your existing access point wireless security, enter your existing router's wireless security key or passphrase then click "Apply". If you get a FAILED message, repeat this procedure again, a wireless hiccup might be interfering, otherwise you now have a working Repeater.
    6. Check your repeater connection by going to your internet browser and open a web page of your choice. If successful your new wireless repeater is working.
    7. Disconnect the Ethernet cable and setup your computer back to its original wireless settings. At this stage, the Repeater is now invisible to any wireless client computers. When connecting a new wireless client within the repeater's wireless range the process is the same as there is no Repeater device at all, the SSID of the wireless router will just be extended in range around where the Repeater is physically located.
    4. Connect your remote wireless client to your wireless router
    1. Using your wireless client utility program, look for your existing router's SSID and connects to it, if this is a new client you will be prompted with the wireless security key. Your repeater is invisible to all wireless clients. All it does is to repeat the wireless router signal as it is to extend its range. Once you have converted the Encore Router to Repeater and successfully connected to your existing router there will be no more configuration needed to the repeater. If you happen to see two identical SSID's of your existing router, this means your wireless client is within the same range of your existing router and the new wireless repeater, then your client don't need the repeater's service.
    NOTE:
    If you are using Windows 7 and your existing access point security wireless is set to WPA2 (AES), make sure your Windows 7 wireless security type properties is set to WPA2-Personal. To check go to Windows 7 Wireless Network Connection, look for your REPEATER router, right-click on it then click Properties, check the settings in the "Security" tab.>
    NOTE:
    When checking the wireless site survey, you may see two routers with the same SSID (names), these are your Access Point and the REPEATER tied together. This also means you are within the reachable range of both Access point and REPEATER.
    5. To check the Repeaters user interface
    At this moment, the Repeater is invisible to any client. The client's IP address is drawn from the DHCP server most likely to be also your wireless router. Therefore the IP address of the repeater is also invisible to the clients. Follow steps below:
    1. Disable wireless connection or turn off wireless in the client PC computer
    2. Connect Ethernet network cable to the RJ-45 port of the client PC computer
    3. Connect the other end of the Ethernet cable to one of the LAN ports of the repeater.
    4. From your computer, set the network card IP address to Static IP Address entering 192.168.0.102, Subnet Mask 255.255.255.0, leave the rest as blank.
    5. Open IE or Internet explorer or any other web browser software and run 192.168.0.1, you should be able to see the Encore Repeater user interface screen. (Changing any settings in the repeater may affect its performance)
    That should help :)
    Christopher
    May 15, 2012 | Encore Enhwi-2an3 Wireless-n Router
    How do i set bridge mode?
    Depends if you need a wireless or wired bridge?
    Here is some info for you.
    Infrastructure Mode
    With a wireless Access Point, you can operate the wireless LAN in the infrastructure mode. This
    mode provides wireless connectivity to multiple wireless network devices within a fixed range or
    area of coverage, interacting with wireless nodes via an antenna.
    In the infrastructure mode, the wireless access point converts airwave data into wired Ethernet
    data, acting as a bridge between the wired LAN and wireless clients. Connecting multiple Access
    Points via a wired Ethernet backbone can further extend the wireless network coverage. As a
    mobile computing device moves out of the range of one access point, it moves into the range of
    another. As a result, wireless clients can freely roam from one Access Point domain to another and
    still maintain seamless network connection.
    Wireless Bridging Overview
    Using Wireless Router as a Wireless Access Point
    May 03, 2011 | NetGear RangeMax WPN824 Router
    I can't enter the web from 192.168.1.1 or 192.168.1.2 how i can enter web setting AP senao 8610S? what sould i do?
    Start>Run>Type in CMD
    Press enter
    Type ipconfig
    Note your gateway
    Go to internet explorer and type your gateway in by itself. i.e. 192.168.1.254
    Press enter
    If this does not work attempt reattempt the gateway address but replace the last number with 254.
    i.e. gateway=192.168.2.1 instead type in 192.168.2.254.
    Mar 03, 2011 | EnGenius ECB-8610S 802.11a/b/g Wireless...
    Set up wireless security
    1 On a computer wired to the SBG900 USB or Ethernet port, open your web
    browser (for example, Microsoft Internet Explorer)
    2 Type http//:192.168.100.1 and press ENTER to display the login window:
    3 In the User ID field, type admin (case sensitive) and press TAB.
    4 In the Password field, type motorola (case sensitive) and click Log In to
    display the SBG900 Setup Program main window:
    As soon as your network is operational, run the SBG900 Setup Program to:
    "Wireless Network Setup"
    For a LAN with one or more wireless clients, enable wireless security on the SBG900.
    After enabling wireless security on the SBG900, as required on each wireless client:
    > If you disabled ESSID broadcasting on the SBG900, set the client Network
    Name (ESSID) identical to the ESSID on the SBG900.
    > If you enabled WEP on the SBG900, set the client WEP key identical to the
    WEP key on the SBG900.
    > If you enabled Allow Only Listed Stations Access, be sure the MAC
    address for each client is correctly listed on the SBG900.
    Dec 22, 2010 | Arris SURFboard SBG900 Wireless Router...
    How do I find out what the ip address of the bridge so that i can access the setup page?
    wire the bridge into the ethernet port on your router. access the setup page of your router and check the DHCP client table. you should see the name of the bridge there with the corresponding MAC address. Just type the ip of the bridge into the address bar of your internet browser, you should be able to access the setup page of the bridge by then.
    Sep 17, 2010 | Linksys WET610N WirelessN Bridge...
    Internet connection is fine when my PC's connected directly to the modem. The router connects fine. But won't let the wired PC online. Under the "status" bar the "router" tab won't show the correct...
    here are times when there is a need to connect a wired computer to an access point in order to set it up. To connect a wired PC to a Linksys access point, follow the steps below. Step 1:
    Connect the PC to the Ethernet port located at the back of the access point.
    Step 2:
    Assign a static IP address on the computer. For instructions, click here.
    NOTE: To assign a static IP address using Mac, click here.
    The Access Point can be configured in four different modes:
    • Access Point
    • Access Point Client
    • Wireless Repeater
    • Wireless Bridge
    The Access Point mode allows wireless clients to connect to the access point and routes traffic between the wireless and wired interface. Use this mode to create a standard wireless Infrastructure network. For instructions, click here.
    The Access Point Client mode allows this device to act as a wireless client. You can connect a wired PC to the access point to connect to a wireless router or another access point wirelessly. You can enter the MAC address of the Access Point or use the Site Survey button to select the Access Point you want to connect.
    NOTE: The WAP54G will only communicate with another WAP54G when set to the Access Point Client. For instructions, click here.
    Sep 05, 2010 | Linksys Wireless-G WRT54G Router
    No internet access
    Configure the Router 1. Step 1
    Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
    2. Step 2
    Use "Admin" as the username in the pop-up box and leave the password blank.
    3. Step 3
    Connect to the Internet and click on "Internet Setup."
    4. Step 4
    Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
    5. Step 5
    Set a service set identifier (SSID) to identify the router and change the password.
    6. Step 6
    Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
    May 15, 2010 | D-Link DIR-625 (790069292637) Wireless...
    How do make my router secure when its states it unsecure
    How to secure the wireless network
    You want to secure the wireless network.
    Is there any computer connected to the router with the Ethernet cable?
    If not then you will need to connect the computer to the router with the cable.
    Check the IP address on the computer. Open the router set up page.
    Once you open the set up page, you will find the option to make it secured
    Apr 28, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    How to make my DWL-2000AP works like a wireles card and is there any driver for it?
    It sounds as if you want to use your access point to connect into a wireless network. A typical, simple wireless network includes (1) access points and (2) clients such as a wireless card in your laptop. Access points can only communicate with clients and clients only communicate with APs. However, many access points can be configured to be clients. Usually you would find that in the basic wireless setup page. I don't know if the DWL-2000AP can be set up that way, but you can check in the manual. If it can, then you would select that mode, then specify the SSID of the network you want to join.
    Apr 15, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
    Computers & Internet Logo
    172 people viewed this question
    Top 2wire Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
