The computer won't charge or run off of the ac adaptor. HP 60000 laptop
  • 4,338 Answers
The DC connector is loose from the system board. It needs to be re-soldered. That involves taking the laptop apart and pulling out the system board. If the laptop is still in warranty, contact HP. If not, I would have a reliable tech do it. Enter your zip code to the right under Repair Service and hopefully there will be a tech in your area to do it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 19, 2008
My hp pavilion dv6-2117ax laptop won't power up (no power light on where adaptor meets laptop). Replaced power adaptor / charger and laptop powered up and operated for a day and then next day woul
The laptop probably isn't charging. Could be a bad d/c connector on the laptop or the battery is bad. Remove the battery and plug in the a/c adapter and see if it powers on. Wiggle the a/c plug in gently while pressing the power button on the laptop. It powers on and off briefly then I'd say it's the d/c jack on the laptop, bad sodder joint.
Dec 04, 2012 | Computers & Internet
Battery won't charge
Sounds like you have a broken AC plug. You can buy them cheap and disassemble the laptop and soldier the new one in but unless your electronically capable I wouldn't try it yourself. You can Google your laptop model number and watch videos to help if you insist on doing it yourself.
Aug 11, 2012 | Toshiba Satellite A215-S4807 Notebook
Netbook is dead, won't operate on AC power,is the adaptor dead?
A good chance the ac is bad, try getting another one, the battery may be bad as well, or the charging port on the computer may be bad as well.
Aug 10, 2011 | Gateway LT2021u Netbook
HP Pavillion 6000 battery issues
Hi Steve, If you haven't gotten any batteries to work properly at all and the problems are different each time, I would say the motherboard is shorting out the batteries and causing weird problems. One last thing to try if possible..
Try a known good working battery, if that battery doesn't work then its verified that the motherboard is bad. If the known good working battery works in that laptop then you got a bad batch and it will be a battery problem.
Since your laptop turns on with the ac adaptor means that the ac adaptor is good.
Jun 02, 2009 | HP Pavilion dv6000z Notebook
Ac adapter will not charge my computer
If the laptop will run from the adaptor, then the adaptor is probably fine. That being the case, if the charge light flashes when the adaptor is plugged in, the battery is faulty. No charge light on an otherwise working system is probably the battery charging circuit in the laptop.
May 17, 2009 | Dell Inspiron 1525 Laptop
AC Adaptor input issues (fries cord, won't charge computer)
dear,
are you using same wall socket everytime for this job...
if yes, then check the mains there too...might be its because of that..
if all are fine in the socket then u have to check the laptop power supply section ....
rate it if issue resolves.....
Apr 17, 2009 | Computers & Internet
Ac Adaptor not working??
as u said that when u plugged in the ac adaptor into the laptop it recognises that the ac adaptor is connected but it does not charge the laptop in this case what u can do is that if have the same charger extra then u can try with the another charger and if the other charger also does the same thing then in this case u need to replace the mmotherboard and if the other charger is working fine in this laptop then definately chage ur aac adaptor.....good luck...
thanks
Jan 25, 2009 | HP Pavilion dv6000z Notebook
HP Pavillion dv6000 -when I plug in AC adaptor, it won't charge
Hi ja525,
If you have tested the power adaptor with a multi-meter to confirm it is OK or the other adaptor is also OK assuming that it is the correct voltage and at least the same current rating. Then the fault is most likely the power connector in the laptop.
To confirm this, power up as normal with the power adaptor connected and switched on, when the blue LED dims wriggle the power connector where it connects into the laptop and if the LED comes on or blinks, that means that you have a faulty power connector, it couls be a dry solder joint at the power connector.
It is possible that the power adaptor is shutting down (thermal overload) due to insufficient current capacity, Check the Amp rating of the laptop, it is usually on the lable on the botom of the laptop and check it against the power adaptor, the adaptor should be equal too or greater that the laptop's current rating.
To fix a faulty connector, you can dismantle the laptop and with a fine tip temperature controlled soldering iron, resolder the power connector and hopefully this will fix your prolem.
Nov 18, 2008 | HP Pavilion dv6000z Notebook
Lap top problem
Hi
If the AC power light is blinking, try the following steps:
1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
Regards
Mike
Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
Computers & Internet Logo
David Payne
David Payne
