Question about Kenmore 73932 Gas Dryer
Kenmore gas dryer runs but won't heat up
The dryer runs well, but won't heat up. I changed the ignitor today and cleaned all the dust and lint from the inside, but still does not heat. What might be the problem.
  • Anonymous Feb 01, 2009
    Kenmore 80 series. I replaced the igniton glow bar but I still have no heat
    Genius:
  • 1,028 Answers
If ignitor is glowing suspect coils on valve assembly if not could be flame sensor on side of burner housing short wires together to find out last suspect thermal fuse located on blower housing ..small white object with 2 wires
Posted on Oct 19, 2008
My kenmore 5200 series gas dryer won't heat. My
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Kenmore Dryers
Why won"t my dryer heat up? We have cleaned it
heatman101
Aug 05, 2011 | LG DLE0442 Electric Dryer
MY dryer is not putting off any heat. I have had it for 4 months. I have cleaned the lint out too? Is there anything I can do to get my clothes to dry?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 04, 2010 | Kenmore 500 6952 Dryer
Burner ignites for 8 seconds and then shuts off. never heats up. vent clean, lint trap clean, lint screen clean
heatman101
Jun 20, 2010 | Kenmore 67082 Electric Dryer
No heat
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 10, 2010 | Kenmore HE5
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Feb 03, 2010 | Kenmore 62802 Electric Dryer
I have a Kenmore gas dryer that the timer will not move and the ignitor will not glow. Both happened at the same time. What might this be
if you have the timer on auto it will not advance without heat,when the heat shuts off the timer moves,you could have popped the thermal fuse located on the blower wheel housing,if the lint filter is on top you have to take the vent line off and remove the back panel to get at it,if the filter is inside then the thermal fuse is in front to the right of the lint filter,this is mostly caused by a blocked dryer that needs a clean out,take off the duct that the lint filter slides down into and clean it out,vac out the inside of dryer where the motor is,and clean out the vent line,if it's a long run blow it out wiyh a leaf blower,you should do this once a year so the dryer runs correctly and clothes will dry faster,if it's not the fuse check the ignitor the sensor and the gas coils,when the dryer cools down and you turn it on and if there is heat for like the first 10 or 15 minutes then no heat it's the gas coils that are bad,hope this helps you
Jan 19, 2010 | Kenmore 63942 Dryer
Have a Kenmore Gas Dryer 80 series, model # 110.78842990 that runs but has no heat, have torn everyting apart and cleaned out all the lint, but still no heat.
Burner not lighting/staying lit. Most likely the ignitor.
Check out
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/ignitor.php
Dec 08, 2009 | Kenmore Dryers
Dryer heats intermittently clcles off heat then
Try vacuuming lint and dust out of the burner intake and exhaust ports. Hope this helps!
Dec 05, 2009 | Kenmore 73952 Gas Dryer
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Kenmore 73932 Gas Dryer Logo
310 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
