Question about Emerson MW8985W Microwave Oven
Emerson Microwave (mw8992rd) not heating up
The store wouldn't take it back because they said it was a fuse. It comes on and the light, turn table, and clock work, but it doesn't heat up. Is there a solution?
  • chen0528 Dec 02, 2008
    Emerson MW8985W Microwave Oven does not heat. The light and the clock and the plate are all right but does not heat. What's the problem? Is there any solution?
  • ruben313 Mar 07, 2009
    where can you find extra fuses for this model, i've checked radio shack and cant find the exact one. is there a fuse that is compatible?
I have replaced the main fuse on this model. Though blown main fuses are common in this model, it will not even turn on when they blow, so your problem is most likely NOT a blown fuse. I had heard of your problem so, when replacing the main fuse inside one, I looked for additional fuses and saw none. The store was wrong. Even if it were a fuse, the security Torx screws mean that you couldn't replace the fuse anyway.
This microwave seems to have been haphazarly been recommended by Consumer Reports, but it is terribly unreliable. The turntables break when popping popcorn, the main fuse repeatedly blows, and they also stop heating.
Posted on Feb 23, 2009
My emerson mw8992rd continues to run when I plug it in The light inside is dim. but it doesn't heat
The most likely cause is that the fuse for the magnetron/klystron has blown. It is usually somewhere under the cover, if you are not skilled in electrics then I suggest you take it to a repair man the fuse is cheap just a few cents but the repair man will want a bit more!
Jul 29, 2014 | Microwave Ovens
Microwave turntable stopped turning. Can I fix this?
The turntable motor will need to be replaced, this type of repair is tricky not to mention the lethal voltages it carries. I strongly recommend a professional for this job.
Jun 24, 2012 | Emerson Microwave Ovens
When I press the start the button the turn table inside microwave is not turning and there is not heat on the food. But the light is on and the clock is working. What do you think is the problem? and what...
The turn table motor of your microwave is defective already and also the magnetron - the source of generated heat of the microwave is also defective. But before assuming that magnetron is dead, check the high voltage fuse it may be blown and replace the fuse (if it is blown) it with similar rating. I hope I help you with your microwave problem.
Mar 21, 2011 | Emerson MW8107WA Microwave Oven
I have an Emerson MW8992RD model and just opening the door blows the fuse! any idea ,could it be a bad door switch? if so where can i purchase a new 1?
Definitely sounds like a defect or misadjusted door switch. This site has venders of M/W parts. FYI,Federal law requires a leakage test after door repair, magnetron replacement or interlock repair.
Jun 20, 2010 | Emerson MW8987B/W Microwave Oven
Need to replace the glass tray for Emerson Microwave Oven model #MW8992RD
Glass tray replacement for the Emerson Microwave MW8992RD has been discontinued.
Oct 06, 2009 | Emerson Microwave Ovens
My emerson mw8117w just stopped working
hi! first thing first check all the fuses for busted.
Sep 15, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Mw8992rd seems to be working fine except won't heat food. timer, touch pad, inside light, carousel all work fine. tried different times and power levels but still no heat.
This sounds like a bad magnetron that would have to be replaced. There is up to 2000 volts stored in a microwave, even when unplugged. For saftey reasons I would strongly suggest you have a qualified technician check it out.
Hope this helps.
Aug 24, 2009 | Emerson Microwave Ovens
The fuse blows when i plug the microwave in with the door closed
first you gotta detach the button plate ( the thing with all the buttons) using a flathead screwdriver .Keep pushing it is stuburn. It will pop back in when you are done. the fuse is behind that. just take it out and put the new one in.
Nov 16, 2008 | Microwave Ovens
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
May 11, 2008 | Microwave Ovens
Emerson MW8985W Microwave Oven Logo
1,075 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
