Question about Soundstorm V900.2 Car Audio Amplifier
Protection Light Keeps Popping On
The protection light keeps popping on even when i dont have the speakers hooked up I can unhook everything but the battery ground and remote but the light still pops on. could there be something wrong with the amp?
    President:
  • 3,130 Answers
Yes I would certainly say there is. Sorry to be the bearer of sad news but you have a short in them thar circuits! Its not a consumer replaceable part that you can open the unit and find a part thats bad and simply replace it. All these parts are soldered in and need a mutimeter at best to test the output and driver devices. It should be taken out and sent to the manufacturer or to a local audio repair center. Good luck
Posted on Jun 14, 2006
SOURCE:
It keeps popping up write protection on and won't let me take pictures
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 09, 2012 | GE T123 Digital Camera
I have a brand new logic soundlab tx1002. it was hooked to a brand new radio and new speakers. When turned on, it is in protection mode. you get a popping sound from the speakers. we have checked all...
first disconnect one wire at a time, making sure the power is off. then connect power and check to see if your speakers are making the popping sound. when you do your speakers, make sure you disconnect both positive and negitive of each speaker at one time. when your amp goes out of protect mode you will have found your suspect wire. then trace to the issue. it could be as simple as crossed over possitive and negitive wires
cheers
Jan 11, 2011 | Logic Soundlab LSX2600 Car Audio Amplifier
Protection light keeps flashing on and off
try hooking up only the power ground and remote see what happens if protection light is on then u have a problem with amp if it goes off then hook up rca if still off then hook up speaker wire if it turns on then u have a prob with speakers
Feb 02, 2010 | Kicker ZX10001 Car Audio Amplifier
Xm-2002gtr amp keeps kicking protect light on
check your amp and speakers and make sure their both hooked up 4 ohm instead of 2 ohm because if you have 1 set of voice coils on your speakers they can only be hooked up four ohm and not bridged to your amp because if you keep trying this you will lock up your speakers if the speakers are only 4 ohm than just hook them up regular to each channel on your amp if your trying to brigde four ohm speakers to your amp it will keep going into protect or worst case scenario you will fry your speakers and you can check your ohm with a ohmmeter trust me my brother owns a stereo shop
Oct 19, 2009 | Sony Car Audio & Video
Model MX6441 i have antivirus protection that keeps popping up if i do what it says then it says the cost is 49.96. I do not want to pay this for a viris protection. I have another one how do I get this...
hi anna4042, are you referring to your antivirus popping up messages that you need to buy the product? or a notification that you have a virus on your pc and you need to remove it by purchasing the said product? whats MX6441
Jun 03, 2008 | Gateway Computers & Internet
Sony explode amp for my car
Try disconnecting everything but the power connections. If the protection light still comes on, then there's a problem in the amp. If it goes out, then there's a problem elsewhere. In that case, hook up one speaker cable at a time and power on. If the protection light comes on, then either that speaker is bad, or you've got too many speakers connected to that one amp output. Too many speakers connected together can cause an overload and trigger the protection circuitry, or worse, blow out something out.
Hope this helps, and please rate my advice.
Thank you, and good luck!!
Feb 04, 2008 | Car Audio & Video
Protection light
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Jan 15, 2008 | Volfenhag ZX-7180 Car Audio Amplifier
My amp wont put out sound
it's blown....probably, check your connections and make sure your presenting it an ohm load it can handle....so check the sub with a dmm.
Feb 28, 2006 | Jensen A600HLX Car Audio Amplifier
Soundstorm V900.2 Car Audio Amplifier Logo
Top Soundstorm Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
