Question about Pie Hon03 F/Mm Car Stereo Wiring Harness Honda / Acura Adapter Harness for Use with Hon03 F/Mm 2003 and Up Factory Navigation Radios
I have a honda civic 1992 and i buy a sony car stero i have problem with de wiring like red goes with red black goes with black but de others color from my honda civic are difent can i have an ide
Problem with de color or the wires honda civic agains sony xplod the colors are diferent i now red is positive , black y like negative how can i identify the righ color to instal my car stereo
  • 43 Answers
Battery
White/Yellow Stripe
or White/Blue Stripe
Accessory Yellow/Red Stripe Ground Black Illumination Red Dimmer Red/Black Stripe Power Antenna Yellow/White Stripe Left Front Speaker (+) Blue/Green Stripe Left Front Speaker (-) Gray/Black Stripe Right Front Speaker (+) Red/Green Stripe Right Front Speaker (-) Brown/Black Stripe Left Rear Speaker (+) Blue/Yellow Stripe Left Rear Speaker (-) Gray/White Stripe Right Rear Speaker (+) Red/Yellow Stripe Right Rear Speaker (-) Brown/White Stripe
Posted on Nov 14, 2008
Which color wire is the hot wire that goes to the car stero
Most likely the red one. black is ground yellow is memory.
Dec 23, 2013 | 2001 Buick Regal
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1992 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1992
STEREO WIRING COLOR CHART:
Constant 12V+: Blue/White
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness: 70-1720
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Distributor
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Above Fuse Panel (Blue Connector)
Parking Lights: Red/Black - (+) Above Fus Panel (White Connector)
Head Lamp: Red/White - Steering Column
Hood Pin: n/a
Factory Disarm: Disarms with Unlock
Door Trigger: Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) Driver's Door at Door Lock Module
Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module
Horn: Blue/Red - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Blue/Yellow
Windows DOWN: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
VSS Wire : Yellow/Red - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 01, 2010 | Honda Civic Cars & Trucks
What is the color code for wiring of 1999 honda civic
Honda Civic Stereo Information Constant 12V Blue/White Switched 12V Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Driver's Pillar Front Speakers 6 1/2" Doors Left Front ( ) Blue Left Front (-) Gray/Black Right Front ( ) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear ( ) Blue/Yellow Left Rear (-) Gray/White Right Rear ( ) Red/Yellow Right Rear (-) Brown/White
Mar 07, 2011 | 1999 Honda Civic
I cut the plugs from the facturay harness for the radio now i am trying to hook everything back up and do not now what colors from the harness goes to the stero. then what the other colors go to that are...
Here are the stereo wiring colors.
1995-97 Nissan Maxima Stereo Wiring Constant 12V+ Pink/Blue Switched 12V+ Blue/Black Ground Vehicle Chassis Illumination Red/Blue Dimmer Red/Orange Antenna Trigger Black/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Jan 16, 2011 | 1997 Nissan Maxima
Stereo wiring- what colors are wat?
1992 Honda Accord Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: White/Yellow
Radio Switched 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Yellow/White
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2?
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2?
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Dec 22, 2010 | 1992 Honda Accord
What color wire should I tap on the distributer for a tachometer? 1992 honda civic cx
If that engine has an old dist with a coil, try one side of the coil, if that doesn't do it, try the other. If the coil is not present, but a coil pack, you will have wires coming out of it, besides the plug wires, one of them will do it, try the red one. make sure the tach is grounded and just check it with a test wire. It should go. Hope this helps.
Oct 17, 2010 | 1992 Honda Civic
I need the stock wire diagram that connects to the car stereo for a 2000 honda civic
2000 HONDA CIVIC FACTORY RADIO WIRE COLORS
BATTERY WHITE/BLUE
ACCESSORY YELLOW/RED
GROUND BLACK
ILLUMINATION RED/BLACK
LEFT FRONT SPEAKER BLUE/GREEN(+) GRAY/BLACK(-)
RIGHT FRONT SPEAKER RED/GREEN(+) BROWN/BLACK(-)
LEFT REAR SPEAKER BLUE/YELLOW(+) GRAY/WHITE(-)
RIGHT REAR SPEAKER RED/YELLOW (+) BROWN/WHITE(-)
Oct 10, 2010 | Car Audio & Video
Honda civic 1992 manual having carbon rate 8.5% but here in UAE allowed only 4.5% what to do to reduce the carbon rate please urgent
go to oreillys and ask for de-carbonizer.its in a little orange/red bottle. ITs called RXP Kicker is the fastest way to clean out combustion chambers and exhaust systems, reduce emissions (CO, VOC's and NOx)/ Co is what you have too much of
Aug 18, 2010 | 1992 Honda Civic
I need the radio wiring diagram for 88 honda civic hatchback
1988 Honda Civic Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: White/Blue
Radio Switched Ignition 12V+ Wire: Yellow/Red
Radio Illumination Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: N/A
Radio Amplifier Turn On Wire: N/A
Front Speaker Size: N/A
Front Speaker Location: N/A
Rear Speaker Size: N/A
Rear Speaker Location: N/A
Here can find the Stereo Wire Harness OEM Honda Civic 86 87 88 89 90 (car radio wiring installation parts)
Hope help with this.
Apr 26, 2010 | 1988 Honda Civic 2 Door
Speaker wire diagram
Constant 12V+ White/Yellow
Switched 12V+ Yellow/Red
Ground Black
Dimmer n/a
Antenna Trigger Yellow/White
Antenna Left Rear
Feb 18, 2009 | 1992 Honda Accord
Pie Hon03 F/Mm Car Stereo Wiring Harness Honda / Acura Adapter Harness for Use with Hon03 F/Mm 2003 and Up Factory Navigation Radios Logo
617 people viewed this question
Top Pie Car Audio & Video Experts
xxxxxx xxx
Are you a Pie Car Audio and Video Expert? Answer questions, earn points and help others
