Question about Sharp AR-C270 Color Copier
Dont know ip for my Sharp AR_C270 i just bought
Just bought a sharp ar-c270 network copier, but cant set it up to print without knowing the present ip address,or how to asign a new one
  • Sharp Master
  • 2,794 Answers
Find out what the gateway setting are on your computer and assign an ip address based on the gateway.
For example if your gateway is 192.168.0.1  then a good ip address would be 192.168.0.XXX.  xxx=available ip address to use.
Your copier does have a DHCP setting that allows the router to assign on automatically for you if the copier is connected to one but you should assign that ip address manually after using DHCP because if the power goes out, it could assign a different one than the previous assignment making the IP port assignments to print with on your computer useless without creating a new port.
Posted on Oct 21, 2008
Sharp ar-c330 with an error code of H4-01. Any
The fuser temperature is low.
Use sim. 5-02 to check blinking of the heater lamp.
if it blinks normally check the thermistor and the harness.
If it not lighted check the heater lamp and thermostat if its defective replace the heater lamp or the thermostat.
Jun 10, 2009 | Sharp AR-C270 Color Copier
Sharp ar-c330
Hi gw16336
It means the mainboard has a malfunction. The printer would need to be serviced by Sharp or a Sharp approved service centre.
May 01, 2009 | Sharp AR-C270 Color Copier
MANUAL FOR SHARP ARC270
Here's a link to the manuals download page at Sharp:
http://www.sharpusa.com/products/TypeManuals/0,1083,18,00.html
They don't list an AR-C270, but a C260 is listed. Maybe it will give you some help. You can also try contacting their customer service through the site if you still need more information
Feb 18, 2009 | Sharp AR-C270 Color Copier
Sharp AR C-330 Error Code E 710
E7-10 refers to black shading correction.
sometimes caused by a poor conection between the icu and the ccd. check ribben cables.
Nov 28, 2008 | Sharp AR-C270 Color Copier
IP Address on a Sharp AR-M237
The easy way to do it is to set the copier up for AUTO DHCP.  That way the copier will connect to the router and assign a free IP address to the copier.
Then go into internet explorer and type in the ip address of the copier.  If you can get a control panel screen of the copier to appear.  It worked.
Once you get the IP address, take it off of AUTO DHCP and type in the IP address that the router assigned to the copier.
Oct 16, 2008 | Sharp AR-C270 Color Copier
Sharp AR-C270 Copier Error code F11
Have you tried unplugging the finisher to see if that eliminated the code? Or gives you a different F code?
Feb 08, 2008 | Sharp AR-C270 Color Copier
Sharp Copier AR-C270 Code Problem
sir there is no code of HS may be it is other code H4 or H2 so please write correct code
Oct 06, 2007 | Sharp AR-C270 Color Copier
NO IP ADDRESS FOR THE AR-C270 sharp copier!!!!?
Custom settings, List print, Print test page, NIC Page.
Dec 15, 2006 | Sharp AR-C270 Color Copier
Sharp AR-C270 Color Copier Logo
241 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
