Brand new computer Takes a long time to start up and my mouse(pointer) wanders when I'm trying to use it
    Sergeant:
  • 352 Answers
Hi mkf,
Do you know how to run msconfig on your pc? If so we can help. If not request to have may explain the whole process.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Posted on Oct 19, 2008
  • anaanymous Oct 19, 2008
    that's to read "me" instead of "may" sorry for the confusion
A circle with a line going through it takes the place of my cursor on my computer?
Firstly, go to
Control Panel
Find Mouse
Click Pointers along the top
Ensure that your default pointer is the normal mouse, like so:
If not, press "Use Default" and it should reset the mouse pointer to normal.
If it looks like the mouse pointer is supposed to be normal in this screen, let me know and we'll see if there's something else wrong.
Dec 23, 2012 | Computers & Internet
The mouse
Hello there.
I recommend doing the following:
1) Shut down the computer (you can hold down the power button on the front of the computer base unit or laptop power button for a few seconds instead of using the mouse)
2) Unplug the mouse base station.
3) Plug the mouse base station in again
4) Turn on the computer and let it start up as normal.
5) Watch for any system messages appearing, like found new hardware.
These steps will verify that there is not a problem with the mouse's base station plugged into the computer. Another thing to check is if the mouse requires batteries, this is often overlooked.
If after doing this there is still no pointer registered, i would suggest trying the mouse in another computer, and if possible trying a different mouse on the same computer.
If the mouse works on another computer then it could be a software problem, which we can help you with.
If the mouse doesn't work on another computer, but a different mouse works fine on the same computer, then im afraid your mouse has to be replaced.
Please post back after trying the above steps and let us know. Telling us which mouse you have exactly will futher help.
Hope this helps.
May 09, 2008 | Logitech Cordless Mouse
Samsung laptop cursor tweeking
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 10, 2012 | Samsung SENS R460 LAPTOP LCD SCREEN 14.1"...
Mouse pointer blinking like crazy
could be a memory problem word takes a lot of memory up on your computer , you could try resetting the pointer on the computer also
Sep 27, 2012 | Dell Wireless Keyboard Optical Mouse w0147
After booting my mouse takes about ten minutes to function and when it does there is no response from the rightclick
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware make sure you have the correct mouse selected also under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Feb 05, 2011 | Logitech V450 Nano Cordless Laser Mouse
Pointer has a mind of its own and wanders. Sometimes jumps around before it finds my target.
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
make sure that the right type of mouse is selected it will be in the hardware tab or
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
hope this helps
Dec 11, 2010 | Logitech MX310 Mouse
Pointer is stuck
Either the computer is not detecting the mouse (was it correctly plugged-in to the computer when you started the computer?) or the mouse's battery is dead, or something else inside the mouse is broken.
Try a different mouse.
Try the mouse in a different computer.
May 26, 2010 | HP DC172B Mouse
The mouse does not work
Change the batteries. If still a problem, try the mouse on another workstation. If it still doesn't work, it will confirm that the mouse or USB receiver is faulty.
Jul 09, 2009 | Logitech V450 Nano Cordless Laser Mouse
Mouse Pointer freezing on Vista Intermittently
try to install the service packs and updates. You might want to save the downloaded files while you're at it. In case it works you need those for the other 2 machines. hope it helps
Sep 25, 2008 | Microsoft Windows Vista Ultimate Edition
Chapionship manager 2008
Have you tried checking the pointer's speed in control panel. mouse icon, pointer options ? Usually when you have different speeds it's because games work differently than Windows does. Check that first. If that does not work, see if there is anything obstructing/pressing against the mouses' cable.
Nov 06, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
