2000 Chrysler Sebring Logo
Posted on Oct 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fuel filter were is the fuel filter for a 2000 crysler sebring
Curt Downs
Level 3:
President:
  • Chrysler Master 1,779 Answers
  • Posted on Oct 19, 2008
Curt  Downs
Chrysler Master
Level 3:
President:
Answers
1779
Questions
5
Helped
976854
Points
6192
Under the vehicle, in fuel line above rear end of gas tank. Relieve pressure before changing, wear goggles and gloves, to protect yourself ( i relieved the pressure, but when pulling filter off, it came loose all of a sudden, sprayed gas in my eyes, trip to e-room-scary.)
Where is the asd fuse located on my 2000 crysler sebring its not convertable
The fuse and relay should be in the fuse box near the battery.
1helpful
Engine will turn over freely but will not start. engine was running when it sputtered and died and will not restart on a 2000 Crysler Sebring Coupe, 2.5, 2 door. May have ran out of gas. added 5 gal but...
see if the cam is turning when trying to start the engine (look through the oil filler cap) if its not, you may have a broken timing belt (and engine damage) if it wasn't empty on the fuel gauge I doubt it ran out of gas.
1helpful
What type of Maitainence is required for a 2007 Crysler Sebring 60 - 70k miles?
The following is the scheduled mainainence per Chrysler at 60,000 miles:
1. Change engine oil & filter
2. Air cleaner filters
3. Rotate tires
4. Check spare tire pressure & stowage
5. Change automatic transaxle fluid & filter
6. Engine coolant flush (every 60 months or 102,000 mile whichever comes first)
I hope this helped and good luck
2helpful
3answers
Is the fuel filter external or internal on a 2000 chrysler sebring convertable. 2.5 V-6?
The fuel filter is external, will be an in-line fuel filter meaning it's screw into the fuel line, more then likely will be under the hood over by the fire wall.
2001 crysler sebring 3.0 engine got out pump gas and it never crank back up it turns over but want start
It might be your fuel pump then. Hope this helps!?
Please rate solution - Thanks.
7helpful
2answers
Oil Change on a 2006 Crysler Sebring
this the picture of the where is the drain plug located
How do you drain the antifreeze
Remove the lower radiator hose
1helpful
Sebring
test results say they really don't work. but just find your fuel filter and attach to that line. or call fuel max company and if they are a good company they should have assistance.
2answers
Need to change fuel filter
were is the fuel filter for the 2000 crysler sebring
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
