Question about Acer Aspire 3680 Laptop
CD/DVD-R Burner quit working!
I will put a disc in "d" to drive and it acts like it is reading and then it tells me to out a new disc in drive. I have checked the drivers and they are all there and updated. One day it was working - then it quit. You can hear it trying.
  • 136 Answers
There are two probable causes for that:
1 - the laser died or is misaligned due to use or mishandling - get a new one;
2 - or the laser lens is dirty. Try cleaning (very, very gently) with a 80% water/20% alcohol solution, close the drive, let it dry for a minute, and try loading a disc.
Good luck
Posted on Oct 19, 2008
My LG Super Multi DVD Burner (GH22NS40) is not working properly anymore. It used to read everything I put in (DVD, game CD, Music CD) but now it fails to read game CDs pretty much all the time. I was...
Hi Makman,
Please follow the below steps,
  1. Make sure there is no loose connection in the cable of the DVD RAM drive , try changing the slot if that is possible.
  2. Secondly , make sure you have a lens cleaner so that you can clean the lens and then check if things work fine.
  3. If the problem persists , the better option would be to get it checked via a external drive connector and see if it works fine or check it at your friend's PC and see the results,
  4. If then the problem persists, then it's surely an indication that the drive will die soon and will not be able to read anything or even probably be detected.
Hope this helps..:) Your feedback would be appreciated.
Jun 16, 2011 | LG GH22NS40 DVDRAM Burner
My Ge Force will burn audio but not DVD.I have tried with Ashampoo,Record Now and Express Burner.The burning programme tells me there is no disc in drive
Hi Brian.
I think you are a little confused.
Your GeForce FX 5500 is a graphics card
All this does is allow you to see your desktop on a monitor and play some games.
For burning discs you need a cd/dvd burner. This is a cd/dvd drive that you can use to read and write cd's and dvd's
You say that your program is telling you that there is no disc in the drive. (Your CD/DVD burner drive)
You can burn audio discs so this tells me you know that much and you have blank cd's so my two things I need to tell you are these..
1. To make a DVD or Burn a DVD you need a BLANK DVD disc in your burning drive. Maybe you have mistakenly placed a CD in the drive instead?
2. Your Burner drive may not burn DVD's only CD's?
Check on the door to the drive that opens to allow you to place discs into it. It should say something like DVD multi recorder or Compact Disc re-writeable. If it does not say DVD on it anywhere your drive is not capable of burning DVD movies and therefore you will need to purchase another burner.
I hope this helps?
Sep 08, 2010 | Nvidia GeForce FX 5500 Video Card Graphic...
Addonics dvd/cd-rw
Sometimes this can be caused by settings or any hardware changes, but if you haven't changed anything probably not. I have had mine act like yours, I ended up installing a new DVD player.
Nov 05, 2017 | Addonics (AEMFR888D) DVD±RW Burner
The cd drive aint reading blank disc
You must have the burner program (roxio or nero) identify the CD/DVD RW Drive. If the burner program didn't come with the drive at the time of purchase go to roxio or nero site and look for updates for your particular drive. If you don't have that info...look in divice manager under CD/DVD-Rom Drives and it will tell you.
Failing that...look for updates of "Firmware" at the manufacturer of your drive...
Good luck...hope this helps
Apr 23, 2009 | Computers & Internet
DVD burner problem
I have the same unit like you. I Have experienced that the cd/ dvd burner doesn't work because cables might have loosen up. Check the IDE cable if it was connected properly. Try to Check also the burner eg. Nero maybe it was not installed properly. Check the installation settings If it was installed completely. Try to check also the system of your computers may be the Direct X component was not installed.
If you have tune up utilities, Try to Check it properly using the device manager if it was installed in your system.
Lastly, after you have tried all of this but nothing is happening. Your unit CD/ DVD has faulted. Better buy a new one.
Jan 13, 2009 | LG Computers & Internet
My Philips DVD8421 burner will not recognize a blank DRD-R disc.
Ok, the reason is quite simple. The Philips DVD8421 does not recognise the DVD-R format.Not all DVD/CD burners read all discs. It does recognise DVD+R though. So all you need to do is use these discs instead. This should solve your problem.
Hope that helps.
Dec 05, 2008 | Philips (JR24CDRW99) CD-RW/DVD-ROM (Combo)...
ATAPI DVD+RW Burning Problem
DVD / CD-RW is usually a a combo drive
DVD-RW is a dvd rewritable drive
Dec 30, 2007 | KHypermedia (KHCRW522452) (20326452) CD-RW...
My DVD-RW doesen't read CD or DVD
Is this a new drive? Is so, it's probably faulty and you should return it to where you purchased it. If you've used it before, are you using the same kind of discs? Or are the new and different brand? If so, try to get the same kind that worked before. Another thing you should do is clean the drive. You can buy cd drive cleaning kits really cheap.
Aug 07, 2007 | Gigabyte DVD BURNER GO-W1616A RT...
Dell Cd/Dvd burner not working properly
I have a Dell XPS 400 that's about 3 years old. I have a DVD reader and a DVD-RW device. The former works - the latter takes forever to read discs (particularly DVD data discs.)
I'm starting to think some of the generic DVD-RW devices Dell uses in its computers are prone to early failure. The DVD-RW in my XPS-400 was called "HL-DT-ST DVD+-RW GSA-H21N".
I'm going to try cleaning it, and then just swap it out for a better device.
Jul 03, 2007 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Acer Aspire 3680 Laptop Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
