I have a mitsubishi 35" television and when turned on, there is only a horizontal line about halfway up, all the way across the screen. If I change the input, the line changes color, but the rest of the screen remains dark. thanks
  • jackcin Oct 19, 2008
    The model is CS-35505. It is not a projection television. It's about 11 years old, but had been a great television, so I'm obviously wondering whether the repair cost would be so high I should replace it, or just get it fixed. Any idea what a repair shop might charge for such a job? thanks
    thanks,
    I expected this was probably the best way to go, but needed to hear it.
    Brigadier General:
  • 6,966 Answers
Initially, it would appear that you unit has a fault vertical deflection amplifier (IC).
If you could perhaps post back the exact model number, then we can give more specific details. The unit will have to be opened. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 19, 2008
  • Louie  Role
    Louie Role Oct 19, 2008
    Hi again,
    • Additionally, other than the model number, a useful bit of information is the Chassis # which should be something like EE2;
    • Incidentally, a good number of Mitsubishi products uses either a μPC1378H or AN5521 for their vertical deflection.
    Of course again to be more specific, the exact model number and/or chassis number is required.
    Cheers.
  • Louie  Role
    The replacement parts, I doubt if would be expensive. It is the service fee that you might have to reconsider. Depending on your location and accessibility. If you are uncomfortable with a DIY, perhaps a knowledgeable buddy could perform the actual soldering.
    Mitsubishi CS35505
    • check/Replace Vert. output IC (TA8427K);
    • Check/Replace R597? (1.2 ohm resistor) in +27 volt source to Vertical. Pls verify, if tested with new Vertical IC and this resistor is open, the HOut (2SD2349) will be blown;
    • In some instances, it is the AN5306NFBS that misses output vertical pulses.
    Master:
  • 848 Answers
Check the filter caps in the main power supply area.....
  • gopinath pasupathy Oct 19, 2008
    there is chance of bad capacitor in the horizontal deflection or video circuitry...... you can spot a bad capacitor in circuit with a ESR meter........
    replace the tv since it is 11 years old ...it will be costlier to repair it rather than buying new one .......your tv is too old so there is chance that you need to change lot of components like resistors,capacitors , transformer , crt etc ......ageing of electronic components causes lot of trouble ......so replace your tv ........
Limes across screen when first turned on, by turning off and on sometimes fixes it, what could cause that problem?
If the lines are colored or even look 3d it is a convergence problem--if other lines it will depend on what they look like and what the model number is.
May 27, 2012 | Mitsubishi Televison & Video
I have a Mitsubishi WD-62525. In general the picture is great from all sources (cable, component, and hdmi). However, there occasionally are very thin, horizontal lines that flicker across the screen....
I have seen this problem before. It is usually caused by a malfunctioning color wheel. Replacing it should resolve the problem. Let me know if you wish to fix it yourself so that I can find you a replacement.
Jan 16, 2011 | Mitsubishi WD-62525 62" Rear Projection...
1992 35" TV has no picture...just a horizontal line
if you fix also not expensive just vertical ic problem
Jun 05, 2009 | Televison & Video
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
Apr 08, 2009 | Mitsubishi CS-27205 TV
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi CK-3513R - Horizintal white line
this ic is soldered onto the board with a heat sink it is related to horizontal circuit.your problem could also be the flyback.good luck
Apr 12, 2007 | Mitsubishi CK-35308 35" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
