Question about Consew 206RB
Loose top stitch when in reverse 206 RB4 Consew
This machine works perfectly going forward, but has very big loops on the top side of material when going in reverse. I just purchased the used machine today, so I am hesitant to mess with the tension adjustments until somebody can point me in the right direction. Thanks, JR.
  • 30 Answers
Do you know how to check the timing of your machine? It sounds like a timing problem to me. If you don't know how to check the timing:
take the side plate off, take the needle plate off, take the presser foot off, and put a new needle in the machine. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line. Then, turn the handwheel toward you until the top line is where the bottom line was. At this point, the tip of the hook should be directly in the scarf of the needle.
Posted on Jan 05, 2009
How do i adjust my consew 105 so the stitches do not loop on the bottom?
If the thread is looping under the fabric, it is a top tension issue.
Make sure you are using a new needle and that the needle/thread/fabric are compatible.
Verify it is threaded correctly and that the thread is firmly seated in the tension disks.
If the top thread is still looping under the fabric, then the upper tension is too loose.
Nov 07, 2016 | Consew Sewing Machines
Sewing machine not working in reverse
try a new needle
try a different thread top and bobbin
try adjusting the top thread tension one number or letter at a time
higher sewing on a scrap piece of paper till the stitches look
normal
make sure the top thread does not come off the thread take up lever
Jan 11, 2013 | Sewing Machines
Stitch looks great on top and bottom has loops and loose
try adjusting the top tension one number or letter higher till the stitch looks normal
change the needle
May 11, 2012 | Consew Sewing Machines
206 rb4 skips stiches through heavy vinyl
try
changing the needle
clean under the needle plate & bobbin area for lint or loose threads
Apr 26, 2012 | Consew 206RB
The thread on the top side of my material starts looping after 4-5 stitches. I've tried every number of thread tension, and even on 0 it loops on the right side of the material, not on the back.
Check the tension on your bobbin thread. When you hold it by the thread and let it dangle does it just drop down without any resistance at all? If so then you need to tighten it a bit. If the bobbin thread is too loose it can not pull the top thread down enough thus puts the loops on the top side of the stitch.
Feb 25, 2011 | Brother LS2125i Sewing Machine
Have a Consew 206RB-1. Seems within the span of a few hours today that whenever I'm turning while sewing any material, it will drop a stitch. When sewing in a straight line, it's perfectly fine. Can't seem...
It is probably because you need to move slower when moving the material around, as otherwise the thread beneath will just stretch over and make a new stitch. just slow down loads and should work! this probably isnt the right answer but hope i may of helped! :)
Oct 28, 2010 | Consew 206RB
My material is not feeding through the machine, how do i set it to feed. it works in the reverse mode, but not forward.
If when you sew in reverse you have big stitches then you will need a shop adjustment if you have made sure beforehand that you have the correct stitch length to sew forward.
Mar 07, 2010 | Brother XL-2600
BOTTOM STITCH IS ALWAYS LOOSE
If the top stitch is loose, then you need to tighten the bobbin tension: if the bottom stitch is loose, tighten the top tension. Hope this helps. It could also be the size needle and thread you are using for a particular fabric. Different fabrics require different notions.
Mar 13, 2008 | Sewing Machines
Consew 206RB Logo
318 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
