Question about Philips Magnavox 20MS233S 20" TV
Blue Screen with thin horizontal white lines
I have a 20" Smart Series Phillips Magnavox TV, which I purchased in 1999. It's always worked with - excellent picture and sound quality - until recently. I now have a blue screen with thin horizontal white lines in place of a picture. The audio appears to be functioning well. Does anyone know what may be causing this problem, and how I can fix it?
Thanks!
  • agimasou Nov 21, 2008
    sanyo tv blue screen white H lines then flashes then turns off
  • fdennis50200 Apr 13, 2009
    I have a 13 inch smart series that was manufacture in 2003 it worked good until now all i get is a blue screen i have cable to it but i can't get any channels i un plugged the cable and the screen is still blue.this has happen to me twice the first time the picture came back not this time,no white lines.
  • 88 Answers
THI IS THE INTERNAL CIRCUTRY FAULT BEST YOU
call the service person and dont try to open it other than in side of TV SET HAVING Hazard of electrical shock be handle most care fully .
and check video board and all.
Posted on Nov 14, 2008
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
No audio and have a thin white verticle line across tv
Always suspect a bad EEprom...very common on this TV! See a tech, he will have to select one of six eeproms to fix this!
Jan 10, 2010 | Philips Magnavox 27MS343S 27" TV
No picture on magnavox 32MT6015D
THAT THIN WHITE LINE IS YOUR HORIZONTAL LINE MEANING YOU ONLY HAVE THAT. THE GOO NEWS IS YOU HAVE HIGH VOLTAGE MEANING YOU ONLY NEED VERTICAL TO FIX IT.. I WOULD REPLACE THE VERTICAL TRANSISTOR OR CHECK FOR ANY BURNED RESISTORS ON THE VERTICAL SIDE
Feb 22, 2009 | Philips Magnavox 32MT6015D TV
White horizontal lines in my 27 in Phillips Magnnavox tv
I have seen this on mine. Check the cable going into your TV and make sure it is good. The ground portion of the cable could not be making a good connection.
Jan 17, 2009 | Philips Magnavox 27MS343S 27" TV
Thin white horizontal lines across top of TV
replace vertical out put ic and related capacitors
please refer to a qualified tv personal to check tv
Jan 17, 2009 | Televison & Video
Need codes to unlock the smart block on my phillips magnavox tv
do you have a 3 digit code for RCA TV for the philips universal remote?
Dec 30, 2008 | Televison & Video
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Standby light flashing
This is possibly a sign that there is a fault condition. Short circuit line output transistor
Jan 23, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
Philips Magnavox 20MS233S 20" TV Logo
214 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
