Freezer is freezing but fridge is only 50 deg. 3months ago freezer and frige quit and repairman replaced timer and defrost heater. Couple days ago I noticed frost in the back of the freezer and the frige wasnt cooling properly. I unplugged and took the back off and vacummed a ton of dirt and fuzz out. Someone said to clean the coils too but I can't find them. Please help
-   Freezer is freezing/cooling fine. Refridge side is barely even cool.
-   Guest
Dec 28, 2008
-   AFTER HEAVY USE, FRIDGE DOES NOT COOL. THEN NOTICE THAT FREEZER IS ICED OVER. HAPPENED AGAIN TWO MONTHS LATER. SERVICEMAN CAME OUT, SAID TO CALL WHEN IT HAPPENS AGAIN, CHARGED $95 FOR THAT SAGE ADVICE. NOW IT IS HAPPENING AGAIN. IT SEEMS TO BE EVERY TWO MONTHS. -   Guest
Popular Solutions for Master Bilt Indoor Step In
Master Bilt Indoor Step In Cooler 70""W x 70""D x 92 and...
whirlpool two door type. upper section on refrigerator does not blow cold when freezer door closes....
(More)
whirlpool two door type. upper section on refrigerator does not blow cold when freezer door closes. bottom section is blow fine. If freezer door is open both bottom and top blow cold well. why is this happening?
whirlpool fridge freezer arc7610 11.7cf (auto defrost)
Fridge and freezer are not cool enough...
(More)
Fridge and freezer are not cool enough spoiling food.
This has been happening persistently for some time.
When find there is no motor or auto defrost noise. We have been turning both fridge and freezer off using thermostats and then turning on fridge which starts motor, then reset thermostats. Its then ok for a while but it doesn't get cool enough.
Bottom Freezer is working fine. Upper refrigerator is barely cooling no matter what number I set it...
(More)
Bottom Freezer is working fine. Upper refrigerator is barely cooling no matter what number I set it at (1 or 7). Any ideas on where I can start to diagnose this problem? Do you know where online I can view a repair manual and/or parts breakdown? Thanks!
my Maytag Refrigerator was not cool at all even that havr air-blow and it compressor up for about...
(More)
my Maytag Refrigerator was not cool at all even that havr air-blow and it compressor up for about 10-20 second and it on and off one in awhile
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
