Question about KitchenAid KGRS807SSS Gas Kitchen Range
Replace oven UI -KitchenAid KGRS807SSS Gas Kitchen Range Problem
I have a range KGRS807SSS. I wanted to use oven tonight but it says  Error code FIEO and REPLACE OVEN UI. What is UI and what do  I need to do? Thank you,
Everest
  • 1 more comment
  • Anonymous Jan 26, 2009
    Same problem. Irritating, since it hasn't even been in use for 1 year yet.
  • Anonymous Mar 29, 2009
    same here!!!
  • Anonymous May 09, 2009
    my oven says the same thing. I had 2 burners on high boiling lobster. No idea why?
Unplug the stove for at least two minutes or throw the breaker for the same time. So far, has worked 100% of the time for me for all error codes. Apparently something gets out of whack and turning off or unplugging must reset the system.
Posted on Feb 26, 2013
tony2155
  • 64 Answers
SOURCE: range has error of stuck key
need to replace touch pad not cheat
Posted on Jun 23, 2009
catriver
  • 878 Answers
SOURCE: Oven/Broiler Igniters for KitchenAid range KGST307
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Posted on Apr 02, 2007
Cyril J
  • 45 Answers
SOURCE: Kitchenaid Selectra Range Fuse location?
unit does not have fuses , if the top works ok then you are getting 220 volts , you probly have a bad control
Posted on May 16, 2008
SOURCE: Kitchenaid Superba Gas Range
It appeared to be something to do with the plenum and cleaning - repair man came - cleansed and it was okay. MK
Posted on Aug 31, 2008
  • 1214 Answers
SOURCE: KitchenAid KESS907 Electric Range E1 F1 Error Code
F1 E1, replace Electronic Range Control.
In other words, the controller board has failed.
Posted on Jan 29, 2009
Oven does not light all the time.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 05, 2011 | KitchenAid KGRS807SSS Gas Kitchen Range
Error code FTE1
dsd Sorry to read about your problem, I hope this helps you out.
you have a keypad issue
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | KitchenAid KGRS807SSS Gas Kitchen Range
Kitchenaid DF Range F04 error code
I have a dual fuel kitchenaid convection range and I put it in self cleaning mode last night. Afterwards it said F 04 on the display. The doors open again, but neither of the ovens work
Nov 17, 2009 | KitchenAid KDRP487MSS Dual Fuel (Electric...
Error code F1E0 AND Replace UI ???
F1-E0 - EEPROM Communication Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 29, 2009 | KitchenAid KESC307 Electric Kitchen Range
KITCHENAID KGRS807 ERROR MSG F6E0
Problem with the time keeping unit. You will need to reset the unit. Unplug it for 30 minutes then plug it back in. If that does not work then check for bad ground wires that are not fully grounded on the unit. If you find a problem and need to order the part you can order it at repairclinic.com
Feb 22, 2009 | KitchenAid KGRS807SSS Gas Kitchen Range
Error Code F2E1
Did you try unplugging it for a couple of minutes and replugging it?
This might reset the computer control.
Jan 17, 2009 | KitchenAid KGRS807SSS Gas Kitchen Range
We just purchased the KGRS807SSS gas kitchen range
This is normal. Typically the vent from the oven will come up between the cooktop and the control panel.
Sep 28, 2007 | KitchenAid KGRS807SSS Gas Kitchen Range
KitchenAid KGRS807SSS Gas Kitchen Range Logo
986 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
