Question about Radio Shack Pro-82 Scanner
I have a radio shack weather alert pro 82
It has no screen display, but it still picks up freqiences . what went wrong, did it get wet inside some how, i need for the numbers to re-apear in the display agian. so i know what im lisenting to as far as what channel i'm on.
  • cj354 Oct 19, 2008
    help!!
  • Anonymous Nov 13, 2008
    I have the same problem. Monitor works fine, except there is no display. If I press down against the bottom of the display you can read the display. Let go and everything goes blank.
    Problem Solver:
  • 5 Answers
Tilt the scanner in a different direction while looking at the display. Do you see anything on the display when you look at it from a different angle? Sometimes manufacturers don't put the LCD display in correctly, and because LCD's have a really small viewing angle it can result in not seeing what is displayed.
Posted on Dec 31, 2008
My Radio Shack Pro-82 Scanner is not working at all.i turned it on and it wont even scan. i cant even hear the squelch. and the only time it picks up something is when its on the air setting it picks up...
Ok I have had the same problem with the Pro 82 and the biggest problems I've found for it not to scan is Corrosion of the terminals not only outside but inside. Even on the keypad and pcb board. SOLUTION: Just take it all apart with a small philips pecision screwdriver and with a dry toothbrush scrape all the corrosion off the board. This always solves my problem and it should yours. Even if theres no corrosion visible on the terminals be assured there is still some inside keping this from functioning correctly. Shotgun420
Jul 30, 2011 | Radio Shack Pro-82 Scanner
My Radio Shack Pro-82 Scanner batt. went dead , now I have no sound
That means you have to put new batteries in your scanner... or recharge your rechargable batteries but if you use rechargable batteries use your yellow battery cradle for rechargeable batteries and your black cradle for alakline batteries....foe pro 82...
Feb 28, 2011 | Radio Shack Pro-82 Scanner
My scanner is locked on weather alert and no buttons will work
Just take apart the scanner with a small phillips precision screwdriver and clean the pcb board of all corrosion with a dry toothbrush. And it should work like new. Shotgun 420
Jan 03, 2011 | Radio Shack Pro-82 Scanner
My pro-82 scanner scans threw all channels but will not pick up any frequencies?
To verify that the scanner is working properly, program one or more of the weather frequencies(162.4, 162.425, 162.45, 162,475, 162.5, 162.525, 162.55, 161.65, 161.775, 163.275) into memory and then scan. NOTE: Not all frequencies are in use in all areas, so you may need to try several. If you receive the weather broadcasts, then you may need to adjust the squelch setting on your scanner to receive local signals. You also need to verify that the frequencies programmed into the scanner are valid, active frequencies in your area. For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
If the scanner fails to receive the weather broadcasts, you need to check the antenna connections inside the unit and/or have the scanner checked/repaired by a qualified technician.
Bill B
Jul 08, 2010 | Radio Shack Pro-82 Scanner
How to program radio shack pro 82 scanner
is it a digital scanner? You know that everyone has gone digital there fore making that kind of scanner outdated and if you are trying to listen to police u wont pick anything up. I was told that some raido shacks will re program it for you.
Oct 11, 2009 | Radio Shack Pro-82 Scanner
I cant get it to pick up any channels
not a lot of info hear.try input a weather freq like 162.400 MHz if your hear that the scanner ok the freq. are just not txing or wrong
Jul 10, 2009 | Radio Shack Pro-82 Scanner
Pro-82 scanner
go to cityfreq.com and see if the frequencies in your area have changed. you might even need a new anteanna radio shack should have a really good one for 20 buck. a little longer than the original but good
Jun 15, 2008 | Radio Shack Pro-82 Scanner
Scanner
If it's still under the year warranty I would reckomend taking it to your local radioshack Retail store to send in for repair. Otherwise it sounds like the the speaker or the audio amplifier might be going out.
Mar 03, 2008 | Radio Shack Pro-82 Scanner
Radio Shack Pro-82 Scanner Logo
110 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
