Question about Refrigerators
Where does the little tube in the back of chefmate refrigerator go and how do I correctly reinstall the freezer section of the refrigerator?
Where does the little tube on the freezer go? Where do I snap it back in at?
Posted on Aug 08, 2010
Why is my bottom freezer on my refrigerator is leaking water
Your drain system is obstructed, I would remove all the ice and clear out the drain within the freezer section (hint you need to remove the false wall to verify the drain is clear). Then replace the drain tube in the back of the unit by the compressor to correct this issue. Good Luck
Aug 16, 2014 | Maytag 21.9 Cu. Ft. White Freestanding...
Gladiator Freezerator wont stay frozen in the bottom portion. It will go to temp when temp is mved, but then start to warm up. Why?
If the bottom freezer section of the Gladiator Freezerator is thawing out the usual cause is from the coils in the back of the top refrigerator section being iced up. The ice blockage prevents the fan from circulating cold air into the bottom freezer section. These units have a design flaw due to the defrost drain freezing up preventing water from draining out from under the coil. The long-term solution is to remove the back wall of the refrigerator section to get to the coil, thoroughly defrost the coil making sure the drain tube is clear, then wrap a couple turns of #12 or #14 copper house wire around the bottom of the defrost heater element and run it a few inches into the drain tube. Advise unplugging the unit when you do this.
I've had this fix on my Gladiator for a couple years and it has been working perfectly ever since. The freezer stays a constant 0 degrees F and no more thawed out food.
May 09, 2014 | Gladiator Freezerator Top Freezer...
Fridge section not cold, freezer section o.k.!
Normally, the cold is only generated in the freezer compartment, and then the cold is pulled or pushed throuch cooling tubes from the freezer section to the refrigerator section. So if your cooling tubes become blocked by ice (usually caused by a defrost circuit failure) then the freezer will seem to work fine but the refrigerator section will not receive the cold air it should.
Suggest you remove the food from the freezer section, then remove the shelves and then the back panel of the freezer. If there is a lot of ice on the evaporator then you should manually defrost the unit. Unplug it from the wall and use a hair dryer to melt the ice. There will be an entrance to a cooling tube right below the evaporator make sure the you keep blowing the hot air from the hair dryer down than tube until you can feel it in the refrigerator section.
If there was ice, you also need to troubleshoot the defrost circuit and find out which component failed. It is normally made up of the defrost heater, defrost thermostat and defrost timer and troubleshooting methods can be found in the tips section.
NOTE: There will be a lot of water to deal with when you defrost your freezer so make sure you are ready to handle it with buckets and large sponges or a wet/dry vac.
Jul 13, 2011 | Frigidaire Refrigerators
We inherited a Roper refrigerator with the purchase of our house. There is freezing cold water dripping into the refrigerator section from the freezer section. Often times the water will freeze within the...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Oct 02, 2009 | Refrigerators
My Sub-Zero drain ices up too!
There is a drain tube heater and a floor pan heater kit for this model from Subzero
This is Not for a DIY project
Affordable Appliance Repair
Lake Forest, CA.92630
Aug 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
My chefmate RS 06DR is freezing everything
temp should be38-40 degree F the tub is for ice maker
Aug 14, 2009 | U-Line 15R Compact Refrigerator
Freezer problems
this particular refrig has only one temperature control which as you know is loated in the refrig section. but temperature isnt your problem. when the icemaker fill tube freezes up like yours has it is generally a sign of a bad icemaker fill valve. the valve seals will go bad and allow water seepage into the line, this seepage will freeze creating a snowball effect freezing the tube. you can use a hair dryer to remove the ice from the tube, and either replace the fill vlave yourself or have it replaced
btw the fill valve is the part that the other end of the fill tube is connected to on the back/bottom of the refrig in the compressor compartment. Good luck and message me back if you have any questions. Thanks Peyton
Feb 24, 2009 | Hotpoint HTS17BCM Top Freezer Refrigerator
Fan in freezer - evaporator fan?
HI. thanks for the question. yes the fan in the freezer must be replaced.and also the drain tube in the freezer, is clogged. cut power to the fridge. remove back panel . replace the fan motor . also clean ice build up. clean drain tube, from freezer to the drain tray, at the back, near the compressor. thanks the appliance doc. please rate my answer. thanks
Oct 07, 2008 | GE GTS22WCP Top Freezer Refrigerator
Ie tube freeze
You may need to balance the distribution of cold air between the freezer and refrigerator section.
The temperature setting influences both and there is normally a control that lets you divide the cooling between the two compartments.
If you don't have one, get an inexpensive (<$5 US) refrigerator thermometer, normally a simple dial-type, and monitor your refrigerator temperature (maybe somewhere in the middle) overnight when not often opened, set the main control to get the temperature between 40-45 degrees F.
Then check the freezer temp.; it should be <10 degrees F (0 is better), then swap back to the fridge to correct the main setting.
Go back and forth until you have both compartments close to the mentioned ranges.
Jun 24, 2008 | LG LRSC26940ST 36" Side-by-Side...
Water inside chefmate refrigerator
Moisture inside the 'fridge condenses on the coolest parts. Most are designed so that the moisture runs down into a channel and is directed out through a small tube somewhere at the back of the compartment, near the bottom.
I would guess that the tube is blocked near the top.
Try finding the tube and carefully inserting something flexible down it to clear the blockage. Don't use anything too rigid, or anything metallic, as these may damage the tube and cause more serious problems. I have done this before using a pipe cleaner.
Jun 06, 2008 | Refrigerators
Refrigerators Logo
249 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
