Question about Olympus Camedia C-350 Digital Camera
3-350 card setup
When i press the quick view button. the screen will be on card setup. it will have 2 options, turn off? and format.
  • dswan55406 Dec 01, 2008
    This problem occurs when I insert a new FujiFilm xD picture card
    Problem Solver:
  • 17 Answers
Formatting the card will erase all images. dont do that until you have them backed up on a cd or your hard drive
Posted on Oct 24, 2008
Installation CD & Quick Guide
Follow this link for your manual, driver, and FAQ's http://www.megxon.com/techsupp/download/X3/X3_supp.htm Driver install 1. Download driver file "X3_Driver.exe" and save it to PC hard disk. 2. This driver file is a self-extracting archive, run it and it will extract automatic. 3. Run "X3 Driver.exe" and will show "WinRAR self-extracting archive" dialog. Press "Install" start extracting. 4. After, in hard disk will create a "X3 Driver" folder. 5. Enter "X3 Driver" folder and find "Install" folder. 6. Enter "Install" folder, find "SETUP.EXE" and run it. The installation wizard will guide you through the installation. -------------------------------------------------------------------------------- How to set the USB function to PC Camera or Storage mode (Regarding how to set the USB function to PC Camera or Storage mode, please reference user manual in page 42.) When connect DSC to PC, it will become a storage device or PC camera depend on the setting of USB in the setup mode. 1. Press the "Manu" button (in the back, left-up side of 5 ways switch) into Menu section. 2. Then press right key to "Setup". 3. Press down key to "USB" then press right key. 4. Press up or down key and change it to "PC camera" or "Storage". 5. Press "OK" key to confirm. -------------------------------------------------------------------------------- How to Format internal memory or memory card (Regarding how to format, please reference user manual page 27. ) > Formatting SD Card Prior to its initial usage, format the SD card. To format the SD card, please insert your compatible SD card into SD slot. Then proceed with the following steps: 1. In "Capture" mode, press "MENU" button into the setting mode. 2. You can see "Capture" and "Setup" in the screen. 3. Press right key to "Setup" then press down key to "Format". 4. Press right key to next step. 5. Press down key to "Confirm". 6. Press "OK" button to confirm. The SD card will be formatted. > Formatting the Internal Memory Take out SD card from the slot and format the Internal Memory by following the above mentioned steps . NOTICE 1. Prior to formatting the SD card, deactivate the ¡§Protect SD card¡¨ function. 2. The internal memory cannot be formatted when the SD card is in the camera.
Oct 03, 2007 | Megxon X33 Digital Camera
How to format a sd card
Hello and welcome to FixYa!
1- If you want to format it by keeping in digital camera then follow the given procedure:-
  • Put the SD card into your digital camera and then turn the power on. Press the button on your camera to bring up your recently shot photographs.
  • Press the "Menu" or "OK" button on the camera to bring up the photograph options. Choose the option that says either "Setup" or "Options."
  • Scroll over to the "Format" option and hit "OK." Choose the option to set the file format to "FAT16."
2- You can also format it by connecting it to computer through card reader, For it follow the given procedure:-
  • Turn on your computer and put the SD card into the card reader slot on the front of your computer or the external card reader attached to a USB port. Wait to see if your operating system automatically opens a window prompting you for information. Click on the option to "Open a folder to view files" if the window pops up.
  • Click on the "Start" button if your operating system does not automatically prompt you to open a folder. Choose the "My Computer" option to bring up a new window.
  • Right-click on the drive bay for your card reader, and then choose the option that says "Reformat" from the pop-up menu. Click on the option to set the formatting to "FAT16" if you receive a separate pop up window asking you which file system to set the card to.
You can also get help from the given video, if you choose second option
If you think this solution helps you then your token of appreciation in the form of Rating as Four Thumbs and a testimonial will be esteemed.
Thanks you for using FixYa!
Apr 09, 2011 | Vivitar ViviCam 3720 Digital Camera
HOW TO FORMAT SD CARD
other way to format is Put the SD card in card reader and follow these steps:-
Right-click on the drive bay for your card reader, and then choose the option that says "format" from the pop-up menu. Click on the option to set the formatting to "FAT16" if you receive a separate pop up window asking you which file system to set the card to.
good luck
hope it helps if so do rate the solution
Nov 29, 2010 | Kodak EasyShare DX4350 Digital Camera
How do i format my sd card
1 Press the Menu button. 2 Press to highlight Setup Menu , then press the OK button. 3 Highlight Format , then press the OK button. 4.Highlight an option, then press the OK button: MEMORY CARD-deletes everything on the card; formats the card. CANCEL-exits without making a change. INTERNAL MEMORY-deletes everything in internal memory including email addresses and album names; formats the internal memory. 5.Highlight Continue Format, then press the OK button. (When the formatting is complete, the Setup menu appears)
Nov 09, 2010 | Kodak EasyShare CX6200 Digital Camera
When i take pictures rapidly the screen says ''processing'' , often for up to10 seconds or more. this happens with a 2 gig non hi def card and 8 gigHD card. regardless of pixel setting.this has just...
It could be caused by your SD card needing to be formatted.
Format your SD card. NOTE this will delete all existing data on your SD card.
Do the following:
  1. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
  2. Turn on the camera.
  3. Press the Menu button, then go to the Setup Menu.
Scroll up or down to the Format option, then press the OK button
Jan 25, 2010 | Kodak EASYSHARE Z1285 Digital Camera
WRITE PROTECT
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Jun 17, 2009 | Olympus Camedia C-350 Digital Camera
My C-740 will not re-format the memory card. I can not reveiw any pic's on the card. Was working fine last week when I used it.
Try the following steps to reformat your card!!,
  • Press the power button on the camera if the camera is not already on.
  • Switch the mode dial to 740playbackmode.jpgand press the Quick View button 740monitor.jpg if the LCD display is not on.
  • Press the menu button 740menu.jpg.
  • Press the right arrow button to select the "Mode Menu."
  • Use the up and down arrow buttons to select the CARD tab, then press the right arrow button.
  • Press the right button again to enter the CARD SETUP menu.
  • Use the up and down arrow buttons to select YES in the FORMAT option screen and press the OK button.
  • Press the up arrow button to select YES, then press the OK button.
    • This will permanently erase all your unlocked pictures, including your locked files. You will not be able to get them back later.
    • A bar appears showing the progress of the reformatting. Do not press any buttons on the camera during this time..
HOpe this helps you..!!!
Kind Regards!!...
Jul 31, 2008 | Olympus Cameras
Deleting all photos
It's on <a href="http://www.fixya.com/support/p220497-olympus_camedia_c_350_d_560_digital/manual-2351/page-91">page 91</a> of the
<a href="http://www.fixya.com/support/p220497-olympus_camedia_c_350_d_560_digital/manual-2351/">User Manual</a>
In the playback mode (ie shutter closed and press "quick view") press "OK" (the centre button!)
select MODE MENU (right),
CARD (down twice),
CARD SETUP (right twice),
"ALL ERASE" should be highlighted, (up/down will toggle between "ALL ERASE" and "FORMAT"), with "ALL ERASE" highlighted press "OK",
press up to select "YES", then hit "OK".
That's it you are done.
Mar 22, 2008 | Olympus Camedia C-350 Digital Camera
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
Olympus Camedia C-350 Digital Camera Logo
88 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
