Question about Philips Magnavox 51MP392H Rear Projection Television
Projection tv the problem is doble image
  • Philips Master
  • 5,138 Answers
Replace Both STKs 392-020s up grade with 040s, if they are 392-110s,150s go to 180s.
Posted on Nov 02, 2008
TvRCA d52w20 52 pulgadas doble imagen
mi tv rca no enciende solo dejo de funcionar y ya, que es lo que debo de revisar en este caso?
Jul 21, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv shows doble colors how do i fix it
Thats a convergence issue. You can get the Phillips DPTV305 - DPTV335 convergence repair kit from www.tvrepairworld.com which fits your model and also includes the step by step instructions for the repair.
Jun 28, 2011 | Philips Magnavox 51MP392H Rear Projection...
My tv se ve doble la imagen
Most likely a failure of the convergence output IC's. There are 2 of them and they should both be replaced as well as checking the low value resistors surrounding them for open. Cost of repair should be around $300
Bill W.
integrityhomeworx.com
Mar 08, 2011 | Hitachi 53UDX10B 53" Rear Projection...
TV has red lines and showing double the picture. One Sears tech suggested may have to replace bulb for $500???
yes thats a good price to replace a bad red picture tube and at the same time the convergence ic , this is for the doble picture and lines
Apr 12, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Sony projection t.v. i'm starting to see doble
Replace Both of your convergence ICs they will be big black ics and will have part number on them example STK392-110 use 150s better ICs
Dec 02, 2009 | Televison & Video
Red ghost in the screen
you can get the KP46WT510 convergence repair kit which will usually repair that issue at the following link the repair kit contains both ICs six pico fuses and 4 of the feed resistors also includes instructions with pictures on how to do the repair.
http://servicemanuals.vstore.ca/
Feb 09, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
DOBLE IMAGE
THE CONVERGENCE DRIVER CHIPS NEED REPLACED. CHECKSUPPLY SAFETY RES ARE OK AFTER REPLACEING STKs RESET CONVERGENCE. CHANCE BOTH STKs.
Sep 09, 2008 | Toshiba 43H72 43" Rear Projection...
HITACHI 57F500A
Work is needed on the convergence board; Could be just resistors or the ICs and resistors. Seems to be an ongoing issue, especially for sets that have their brightness levels turned higher than usual to compensate for room ambient light..accordianman
Jul 24, 2008 | Hitachi 57F500 57" Rear Projection...
Philips big screen projection tv
sounds like the Convergence ICs are getting ready to go. Does it appear as a outline almost 3D? If so its convergence if its more like a glowing halo its coolant in the blue CRT that needs changing.
Jun 20, 2008 | Philips 51PW9363 51" Rear Projection...
SAMSUNG PCL5415R
Probable bad convergence IC's---STK units on large heat sink.
Also,possible blown fuse (soldered-in) hidden under heat sink.
Samsung is known for making the fuse devices hard to find.
Let me know if you need more help....T.
Oct 19, 2007 | Samsung PCL5415RB 54" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
