Question about Kenmore 73952 Gas Dryer
Removing front panel
How do I remove the front panel from the dryer to check the burner assembly.
I have no heat coming out of the gas dryer.
  • 367 Answers
The first thing to do is to remove the plastic plug on the lower left front corner of the dryer. it is just a small square plastic piece. This way you can see if the ignitor is glowing red. But to answer your question, You remove the 2 screws underneth the lint filter. Then the top will just pop up with a screwdriver. Then there is 2 5/16 screws holding the front on. (this is for the most common kenmore. If this sounds all wrong i will tell how the other model comes upart.
Posted on Nov 20, 2008
My dryer is not heating. how do you access the ignitor and gas valve?
Remove the front access panel you should see the gas valve, ignitor and a flame sensor If any part of the burner assembly looks damaged then a malfunction will occur and this will be the cause of no heat
Sep 28, 2015 | Dryers
Need to convert from natural gas to propane
Take 3 screws out of bottom side of Z shaped metal part on the back of the dryer's top. Stand in front of dryer and use the palms of your hands to sharply push dryer top back about 2 inches and lift top off. Open door and remove screw at 4 and 8 O'Clock position. Remove control panel (ususally 2 screws and a bunch on retaining plastic parts along the top side) and set on top of dryer or unplug electrical plugs and set aside. Remove screws at top of front panel. Unplug light bulb and door switch. Tilt front panel forward and lift off bottom tabs, then unplug moisure sensor wire at bottom, allowing front panel to be set aside. Remove 4 screws at sides of drum support assembly, lift up and off. Release belt, and remove drum. (easier to do if flat metal part originally right behind control panel is removed first) Use belt as a handle and lift drum out of dryer, allowing access to burner assembly. Change burner orfice and regulator blocker. Re-assemble and test.
Nov 18, 2011 | LG Dryers
I have a gas dryer that the igniter plug glows, but does not light the gas. One time when I had the front panel off the gas ignited and the dryer heated, but only burned for a minute then shut off. Now I...
with front off it will short cycle. If ignitor glows and then goes out without lighting, you have bad burner coils. The 2 black round things on burner assembly. Unplug unit then unplug coils and remove bracket with 2 screws. install coils and test.
Aug 27, 2010 | Dryers
How do you replace ignitor on maytag mdg2300 dryer
The igniter can be accessed for replacement through the front of the dryer by removing the front panel. Once the front panel is removed, unplug the igniter from the gas valve assembly then remove the screws securing it to the burner assembly. Secure the new igniter in place then plug it to the gas valve assembly. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock. Take extra care in handling the igniter to avoid breaking it into pieces due to its fragility.
The front panel can be removed by removing the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer. Follow these steps in reverse order when reinstalling the front panel.
May 28, 2010 | Maytag MDG2300BWW Electric Dryer
I have a Whirlpool GGW9879PW0 gaas dryer. When starting cold I hear the click of the igniter, the igniter glows and the burner ignites. When starting warm or when the burner cycles the burner never comes...
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 279834.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Reverse process to re-assemble. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Motor and idler pulley for dyer will be on right. Gas components will be on left. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
Sep 06, 2009 | Dryers
How to replace gas coil valves on Whirlpool LGR5636EQ3 Gas Dryer
DOES YOUR DRYER HAVE THE LINT SCREEN ON THE TOP? IF SO, REMOVE THAT AND TAKE TWO SCREWS OF(CARE NOT TO DROP IT INTO THE VENT). PULL THE TOP PANEL TOWARD YOU LITTLE BIT AND LIFT UP, THERE WILL BE TWO 5/16 SCREWS INSIDE FRONT PANEL, REMOVE AND UNPLUG THE LID SWITCH CONNECTOR, FRONT PANEL WILL COME OUT. THE GAS VALVES AND COILS ASSEMBLY WILL BE ON THE BOTTOM RIGHT. UNPLUG AND TAKE THE SCREWS OFF THE BRACKET AND REPLACE COILS. CHECK FOR CONTINUITY ON COILS, IT SHOULD READ 1.3 TO 1.9 OHMS. THE ONE WITH THREE TERMINAL, CHECK OHM FROM MIDDLE TERMINAL TO OUTSIDE TERMINALS.
BOYNISMO@YAHOO.COM 714-334-1998.
Aug 21, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
The drier is working but there is no heat. This occured about a month ago and the service man came out, replaced the filter (which was worn down partly due to using drier sheets) and unclogged the vent...
hi..
Open the burner access door and then turn the dryer on. Watch inside the burner compartment for the glow coil to light up and glow. If all the controls are set correctly on the front control panel and the dryer is running, but the glow coil fails to glow, you've located the defective part. The glow coil will need to be replaced.
To remove the coil, turn off the gas first. Unplug the dryer from the electrical wall plug. Then remove the entire gas valve as an assembly. The nut on the gas valve to remove it from the gas supply pipe turns counter clockwise. There will be small sheet metal screws used to secure the plate to which the burner assembly parts are attached. The plate holds the entire assembly and is attached to the bottom of the dryer's cabinet.
Next, remove the glow coil from the burner assembly. Take the entire assembled part to the local appliance retail parts store for a replacement coil. Glow igniters are fragile and they break easily. Handle and install the new igniter carefully. Glow igniters are a non-returnable and non-refundable electric component.
Be advised that some new replacement igniters do not come with quick disconnect ends. In this case, it is OK to cut off the quick, disconnect from the old igniter and attach it to the new igniter. Simply clip off the wires several inches above, disconnect the old igniter, attach to the wires of the new igniter, and wire nut the two ends together. Repeat the process to attach the other set of wires and wire nut them together. There is no positive nor negative polarity to be concerned with.
Jul 08, 2009 | Fisher and Paykel Dryers
No heat
First remove the door.
then the front panel and top
Hold start and door button to begin.
now look at the burner assembly
The bar should heat up
then gas valve opens
If the bar doesent light check for 120vac at plug to it.
If it lights ,but goes out quickly, it is the flame sensor.
Mar 13, 2009 | Maytag Neptune MDG5500AW Gas Dryer
No heat
there's no fuses on the unit. the cord connects to the control panel, the motor and the gas controller. you may need to remove the door and some screws holding the front panel in place. the panel will come forward and there may be some wires to disconnect for the light. the panel bottom has two tangs and notches they fit into. on the right bottom is the burner - check to see if anything is loose in the burner tube. maybe there's some loose change inside the drum or the blower housing. check the klixon thermostats on the burner and blower housing. the flame sensor may be loose
Aug 19, 2007 | Kenmore 93042 Gas Dryer
Kenmore 73952 Gas Dryer Logo
227 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
