Question about Compaq Presario R3000 Notebook
Won't boot I recently reloaded XP pro on my Compaq Presario R3000 laptop. While trying to resolve some device manager issues by running a hardware scan on microsoft web page, my screen went black and I'm unable to get past the following screen with the following wording: Intel undi, pxe-2.0 (build 082) copyright(c) 1997-2000 intel corp. For Realtek RTL8139(x)/8130/810x PCI past ethernet controller v2.13(020236) PXE-E61:Media test failure, check cable PXE-MOF: exiting PXE ROM.
  • d_ephraim01 Oct 19, 2008
    Thank you Joe! You are a God send. God bless you!
    Donald Ephraim
  • Compaq Master
  • 4,338 Answers
The error means that the computer is not seeing the hard drive.Hit F10 to get into BIOS and check that your hard drive is showing . If it is hit ESC and tell it to save settings. Then restart the PC.
If your hard drive does not show in BIOS, there is something wrong with it. It may be co-incidental that canceling the scan caused your hard drive to fail.
You can try to do an XP repair. Boot your XP cd:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just reinstall the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 19, 2008
Blue screen compaq presario windows xp sp2 cq40
Did you just install a new program or a piece of hardware, update a driver, install an update, etc.? If so, there's a very good chance that the change you made caused the BSOD:
Startup using Last Known Good Configuration to undo recent registry and driver changes.
Use System Restore to undo recent system changes.
Roll Back device driver to version prior to your driver update.
Scan your computer for viruses. Some viruses can cause a Blue Screen of Death, especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. Most Blue Screens of Death are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return hardware settings to default in Device Manager. Unless you have a specific reason to do so,the system resources that an individual piece of hardware is configured to use in Device Manager should be set to default. Non-default hardware settings have been known to cause a Blue Screen of Death.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
If this doesn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of blue screen
Oct 10, 2013 | Compaq Presario Notebook
My USB connections have stopped working in my Compaq Presario, how can I fix it?
Check any USB device on the another laptop and then on this Laptop.
If it is not working then try to reinstall USB drivers.
Go to Device manager
Universal Serial Bus controller
Right click and Uninstall
follow the procedure on the all the devices under Universal Serial Bus controller.
Restart the laptop. check with the USB device again.
Hope this will help.Plz get back if this does not resolv ur issue.
May 23, 2010 | Compaq Presario R3000 Notebook
Webcam not working
First you might go to Device Manager, right click your hardware device in the list and select Update Driver Software; then click Search automatically for updated driver software.Drivers on the Windows Update site are directly provided by hardware manufacturers. Microsoft tests drivers in various environments before they are published.
If it does not work on your issue, I'd suggest you installing the Vista driver in Compatibility mode. Remove and rescan that hardware device in Device Manager, right-click on the driver executable/installer file -> Properties and select the Compatibility tab; click the checkbox before Run this program in Compatibility mode for option and select Windows Vista in the list-down box; then try installing the device driver. In addition, you can use the Windows XP driver for testing.
In between understand that Windows 7 is a new operating system and whole driverstore has been reprogrammed; you might wait for another period of time till the retail version is released and push the vendor company to upgrade their device driver.
Apr 13, 2010 | Compaq Presario R3000 Notebook
COMPAQ presario AUDIO none
Check Device Manager to see if the Audio device is working and enabled, if not install the latest audio driver.
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Use this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Dec 26, 2009 | Compaq Presario R3000 Notebook
I have a compaq presario r3000 running xp home. When I boot, it never finishes booting. It gets stuck in boot mode and just stays that way.
hi
some of your OS files got corrupted or deleted.
you just have to repair the OS using bootable CD.
be carefull while selecting the options dont select the FORMAT option just select the repair option..this will do.
if you find the solution useful plz rate me carefully
Jun 30, 2009 | Compaq Presario R3000 Notebook
I have a 4 year old compaq presario r3000 with xp home edition installed, now the problen is it won't boot because the hal.dll is corrupted or missing, I have been wanting to install Windows Vista Home...
i wud say that plz dnt install windows vista coz tat wud eat up lot of computer's memory and ur computer wnt be running ,,it wud b walking,,and u wud get irritated,,moreover u wud face problems with the 3rd party softwares tat u wud try to installl,,resulting in more problems,,my advice,,go with xp,,easy convenient to use
best of luck,,giv a good rating use,,keep me posted
May 16, 2009 | Compaq Presario R3000 Notebook
My compaq preasrio r3000 black screen cant conect to an external
have you any other A/V ports out ie Svid etc if so try that via an A/V lead, if that works reset your bios settings to minimal settings, if that doesnt work search the 'net someone somewhere has had the same problem! try shining a flashlight/lamp onto the screen whilst booting up, if you see anything on the screen then your inverter is definatly gone and yes it could still be your inverter! your laptop may have software/hardware issues with an external monitor?
Mar 09, 2009 | Compaq Presario R3000 Notebook
Compaq presario r3000 windows update failed
you don't have the legitimate serial key fo rth Windows XP.
sorry we don't porived help for cracking the serial number.
you just have to work with sp3. without any updates.
Oct 14, 2008 | Compaq Presario R3000 Notebook
Compaq Persario R3000
i have a problem can you please send me a atachment of this driver base system device so i can instal it to my laptop compaq presario r3000
my email is sogunade@yahoo.com
Sep 04, 2008 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Notebook Logo
296 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
