Question about Sony KDL-32M3000 32 in. LCD Television
Slow moving images on screen
When i turn on my tv a white vertical line appears and slowly disappers and then you see the sony logo. then the chaneel slowly appears like it is moving slow like it is cold or something. even the menus move slow like what ever is being highlighted has a tail. i have tryied reseting everything and still nothing. happened once before and in a day or so it went away. please help. thank you
  • Anonymous Dec 11, 2008
    Same problem
  • Anonymous Mar 15, 2009
    slow moving images on screen"
  • 320 Answers
Either the TCON board or the panel is bad. Sony supplies the two parts as a unit so you will have to have them replaced together. Hope it is under warranty because it is expensive
Posted on Oct 19, 2008
What cause Vertical lines on my Toshiba TV Model 46G310U that affect the way the image is seen. Also some white bands Horizontally are appearing?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 07, 2015 | Toshiba Televison & Video
I have same sony model, I have problem with vertical lines on LCD Screen, When i power recyle and switch on the TV, i can see the clear image , After on mintue and half the image fade and i can not see...
Unless you are really good in TV electronics, there is really no simple solution...the transformer for the video screen is heating and shorting out. I hope you have a warantee or guarantee on it!
Dec 02, 2012 | Sony 46 KDL46EX520 LCD TV
White and purple flickering vertical lines. No image or sound.
I Hope this helps!
Sony has extended the Warranty for people experiencing picture anomalies due to LCD Panel failure through October 31, 2012.
See here:
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Jan 04, 2010 | Sony KDL-46XBR4 46 in. LCD Television
Vertical aqua colored line on the screen of my laptop
the cells inside of the lcd itself are starting to go bad which is why your seeing lines on the screen. To fix the problem you'll need to replace the lcd.
In the meantime you can hook up an external monitor and use that so you don't have to deal with lines on a bad lcd screen.
Jun 26, 2009 | Compaq Presario M2000 Notebook
Screen shows no image for picture taking or playback
Is this Sony DSC-T1 camera or some other model? let me know to help you out.
Jun 15, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Slow moving dark picture, low color resolution
You probably have a bad main digital video board. I would not suggest a person with prior electronics experience to perform this repair as the set holds extremely high voltages for hours after being turned off.
If you want to try it yourself, you can get the replacement part here
http://www.discount-merchant.com/ProductDetails.asp?ProductCode=1016710-SONY&Click=17845
A service manual would come in handy when you are working on something like this. You may want to try searching for one before starting this repair. If you cant find it then let me know and I will guide you with the repair.
Apr 21, 2009 | Sony KDL-32M3000 32 in. LCD Television
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KV-35S42 35" TV
Check first for bad solder on the vertical IC, Im not sure for your set as I do not have the service manual, but it may be location IC301. If after resoldering it does not fix it you may have to replace it and you should replace the electrolytic capacitors in the vertical section. Hope this helps. Don
Jul 31, 2007 | Sony KV-35S42 35" TV
White Horizontal Lines near the top of my Screen
this symptom is what we called vertical fold-over. vertical fold-over is characterised by a white horizontal bar on the bottom or top of the raster due to the concentration or compression of the trace lines. it an image is present, the bottom or top portion is fold over. this is caused by a vertical deflection current with poor linearity, which compresses the trace lines at the bottom or top of the screen. this symptom is is caused by a defective sawtooth wave genetator circuit, or improper biasing or defective feedback circuit of the vertical drive or vertical output transistor/ic. the negative feedback circuit in vertical deflection circuit compensates for the linearity of the trace portion of the sawtooth wave. a decrease in the capacitance of the sawtooth generator capacitor is usually the trouble. but if you do not understand anything what i have written here, better bring it to a qualified tv technician for your own safety also. good luck!
Mar 01, 2007 | JVC TM-2703SU 27" TV
Sony KDL-32M3000 32 in. LCD Television Logo
636 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
