Question about Dishwashers
Dishwasher wont finnish rinse cycle
Dishwasher lights only stay on for about 5 or 10 minutes then machine stops working altogether, inside the floor will be full of water. Have cleaned all filters etc inside, and checked water filters and supply on the outside.
  • rheesey Oct 21, 2008
    thank you for the solution,now i will try it out!Rheesey
  • 2,071 Answers
Machine stops working this a symptom of defected motor timer.Before testing the timer motor, unplug the dishwasher or shut off the power at the breaker panel to avoid an electrical shock hazard. The timer motor regulates the length of time power is routed to each component. If the timer motor does not function properly, it can result in a wide range of problems. Common symptoms include sticking in a cycle, cycle times running too long,or short, or failure of the dishwasher to start at all.
To service the timer motor, it is necessary to access the control panel in the door. Access varies by model; on some models you can remove just the control panel on others you must remove the interior or exterior panel of the door.
Hope it may help you;
Regards,
VOTIT
Posted on Oct 19, 2008
    Master:
  • 848 Answers
Can you provide the make and model number of your dishwasher ..........
If it is wiring fault
check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer light on front panel of dishwasher has stopped working--how is it replaced?
Most of the led lights are fused to the circuit board. Sounds like the circuit board is going or gone bad. I'm not sure because you did not give the model of the dishwasher.
Most of the control lights are led and do not go bad. But the circuit board that controls the lights can go bad. You may be able to fix the control circuit board but replacing it would be easier.
Oct 14, 2014 | Maytag Dishwashers
Bosch dishwasher gets stuck at 1 minute
New and highly targeted viral marketing campaigns can instantly place your product, service or brand in front of potential customers. See the best examples of viral marketing videos and social media strategies. Viral Marketing Company Plan Strategies and Resources Viral Shot
Mar 11, 2014 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher will not finish cycle.
This could be one of a few things,first it sounds like it may be getting stuck on the rinse cycle,check if the water in the machine is hot if not there is either an element problem or the timer is not functioning properly,if the water is hot then it may not be draining before taking on rinse water the best way to determin if it is indeed draining and refilling is to switch the machine off ,take the drain hose and put it on the floor or in a bucket,if it drains let it finnish and then put back and switch the machine on it should fill and continue.if it does not drain then you have a blocked pipe or fualty pump,Do not reset the machine
Dec 28, 2009 | Kenmore Dishwashers
Wsher stops in the rinse cycle wiht a n F4 message
f2 error means long drain or no drain
check the drain pump
replace drain pump if nessesary
Mar 17, 2009 | Kenmore Washing Machines
Bleeping dishwasher
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
  • Nov 03, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
    Dwf50 hotpoint aquarius dishwasher
    hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
    I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
    Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
    Jun 16, 2008 | Hotpoint 24 in. DWF32P Free-standing...
    Dishwasher runs but does not clean
    Try using a cycle that doesn't heat the water. (Quick cycle?) Using high heat rinse or sanitize will stop the timer while it heats the water. The sensor may be bad.
    Apr 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
    Brand new dishwasher not working
    try this test: add water (one gallon each try) by hand fill and try the cycle again. Continue until light goes out. If light never goes out, then faulty water level switch or wiring. If light goes out, then water inlet valve is stopping too early, but need more info to determine why. Try this test: open door and find the door switch. Then activate the switch and turn on machine to watch water come in. It should not just "dribble" in; try to determine if water pressure is sufficient coming in.
    Jun 19, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
    Bosch SHU5316
    Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door.
    Apr 15, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
    Dishwashers Logo
    94 people viewed this question
    Top Dishwashers Experts
