Question about Rockford Fosgate Punch 300S Car Audio Amplifier
AMP WON'T WORK POWER SUPPLY?
Hi, My Rockford 300s amp was working fine (running a little hot , but still playing loud). Anyway stopped working yesterday. LEd will not light up, fuse is not blown, everything else checked, ulitmately I opened it up, and it looks like a couple of wires in the "big circle of wires" right behind the power supply, a few look burnt. I believe that may be the problem, but I'm not sure. Any suggestions. Thanks
    President:
  • 3,130 Answers
That big coil of wires ytou described is the transformer for the switching power supply. Sounds like you over heated it and blew out the supply or the output section. From what you described you should take or send this unit into be serviced as there are no user serviceable parts in this unit except a fudse maybe and if thats blown theres more problems as thats there ( the fuse) just so the whole bloody thing dosent burn up your car! Good Luck
Posted on Jun 14, 2006
Why did speakers get really loud, then stop working?
Have you checked the fuse on the amp and/or make sure the amp did not burn out?
Aug 01, 2015 | Rockford Fosgate Car Audio & Video
I have a hifonics Zrx1200.2 amp. I am running 2 Rockford fosgate p3 12s with it. The specs on amp and subs match perfect. So I have everything wired correctly, it least I sureeee think so. Subs are dvc...
u could just not have enough battery power or the load on the amp is to much. if the amp is in stereo mode it should work but if it is in bridge mode the ohms would be to low .. best thing is to get a sub amp with a 1 ohm stable capacity.. and you amp should be at least one third more powerful than the subs..eg: if the 2 subs is 1000 w each the the amp should be 2500 rms and up to prevent the amp from maxing out and over heating etc.
Jun 09, 2013 | Car Audio & Video
Why does my 6x9 amp drop or not let the sound play at all when my subs are on? it just started to happen? they worked together fine before. i turn the subs off and the 6x9 work? but when i turn the subs on...
You probably have too much hooked up for the size of your power supply which is presumably a small car battery. You either need to get:
A) New, better bigger battery.
B) Capacitor in series with battery.
C) Both of the above.
Mar 08, 2010 | Rockford Fosgate Punch Stage P212 S4 Car...
No sound
Interchange with a known working amp, if work check your wiring and speakers.
Aug 23, 2009 | Rockford Fosgate Punch 300S Car Audio...
Car Amp
i'd try looking at the remote wire
Dec 13, 2008 | Rockford Fosgate Punch 300S Car Audio...
Amp gets very hot in as little as 5-10 min.
Whats the omh load and how old is amp??? The old Rf amps always got hot that how they worked.... No ventilation????
Nov 05, 2008 | Rockford Fosgate Punch 700S Car Audio...
Stopped working
either your amp is blown which it very well could be. or your just hooking something up wrong in the wiring. make sure ur battery wire and small blue amp wire are secure with a good ground
Jul 11, 2008 | Rockford Fosgate Punch 300S Car Audio...
Rockford Fosgate
If it is the power supply use IRF3205 and change the gate resistors to 47 ohm. Also replace the 4 power supply drivers.
Oct 03, 2017 | Rockford Fosgate Punch 300X Car Audio...
Amp turns on but doesnt power my subs
well ill need 2 know wat knobs are all on the front of your amp
Nov 07, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
No power
hi, some car amps need a high current remote supply to turn on. first make sure that you are using the proper gauge b+ and gnd cable for this particular rockford amp. then try switching the remtote turn on to this amp thru a simple Relay.(use the remote supply from your headunit as a trigger for the relay). do these connections without connecting any spks or rca line inputs. once amp is switching on then connect all other cables. OR lastly check the main fuse on the RF amp?? cheers
Jul 22, 2007 | Rockford Fosgate Punch P325.2 2-Channel...
Rockford Fosgate Punch 300S Car Audio Amplifier Logo
199 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
