Question about Omega 4000 Juicer
How do I replace the latch arm?
Omega 4000 jucier. has a broken latch arm. I have a replacement for it.
How do I take off the old one and put on the new one? (without beraking anything)
    Champion:
  • 356 Answers
I WOULD CALL OMEGA AT 717 561 1105. I REPLACED ONE
ON AN OMEGA 1000 BY REMOVING BOTTOM OF JUICER
TO VIEW LATCH ARM WHERE IT ATTACHES FROM INSIDE
THE HOUSING. YOU CAN FIGURE IT OUT. IT HAS TO BE
PRIED A LITTLE AND SLIPPED UP AND OUT.
Posted on Jul 05, 2009
    Problem Solver:
  • 6 Answers
Go to :
foxinternational.com
Posted on Oct 21, 2008
Just received replacement Latch arm for Omega 1000. Old one is removed. Can not put the new one. Top part does not slide in. Also noted the old part and new part look different. Base is longer in the...
Believe it can be done. You might have to file or shave the new arm a little then seat it as best
as possible and tap it in place with a screw driver and hammer. If you do manage to attach
the new arm and the fit is a little too snug when you latch down the cover, file the upper tip
of the arm for a little more tolerance. Also, believe it or not, a worn blade will produce less
vibration. There is a set screw bottom center. With the juicer fully assembled, unlock it,
turn it clockwise until feed chute contacts the shredder blade and back it off a half turn.
You now have the proper gap between the chute and blade.
Jan 30, 2011 | Omega 1000 Juice Extractor
I cannot remove the broken latch arm on my Omega 1000 Juice Extractor to replace it with a new latch arm. I have tried to follow vague instructions on the web, but I cannot remove it. Thanks.
It's a real pain and even bigger pain to snap the new one in place. Best way to do it is remove
the 4 screws, not the center one, and separate the base. You will then have access to the
latch arm from within, but remember how everything goes back together again.
Jan 27, 2011 | Omega 1000 Juice Extractor
The left arm-clamp has come off. It seems to be different from the left arm-clamp. At first I thought I just needed to figure out how to reset the spring, but a neighbor seems to think that the arm was...
They break. The latch arm is one piece, spring and all. So if any part of it is still in the
juicer it's broken. Order a pair from Omega and have them walk you through replacing
them.
Nov 22, 2010 | Omega 1000 Juice Extractor
Latch arm broken on my omega 1000 juicer. I have ordered one. How is it attached?
Omega can walk you through it, but have a file handy because the new latch
arms are not a perfect fit for the older juicers. You might want to remove the
4 screws on the bottom to separate the base for better access. If you have
a little mechanical ability it can be done, if not it could get tense.
Aug 26, 2010 | Omega 1000 Juice Extractor
I need one of the clutch arms on Omega 1000 juice extractor replaced. I live in South Africa (Johannesburg) and so far could not find an agent. It broke off from side. The machine has been standing...
Hello Christien,
I would order a latch arm from Omega. they are around $7.00 plus change.
www.omegajuicersdirect.com
Regards
Alan Hood
amiman
UK
Jun 10, 2010 | Omega 1000 Juice Extractor
Need to replace latch arm omega juicer
First thing to do is call Omega and order a pair
at 1 800 633 3461 and also ask them for tips on
how to remove and install the arm. If your juicer
is older the new arms may not be an exact fit, and
you will have to do a little filing and improvising to
install them. Its helpful to remove the 4 screws on
and view of the situation.
May 20, 2010 | Omega 1000 Juice Extractor
HI, I have omega 1000 juicer, and the latch arm was broken. I ordered the replacement latch arm online. I received my order today and there is no intruction how to replace it. I looked in omega 1000 manual...
There are no instructions. Call Omega 1 800 633 33461
for advice. Also new arms on an older juicer may not
be an exact fit so you might have to do a little filing
down on the arm to get it to fit. You can remove the
4 screws on the bottom to separate the base and get
a clearer picture of what you have to do. Basically
you have to pry the base of the arm away and push
up to remove it. If you're not handy you may need
some help cause it gets tricky.
May 08, 2010 | Omega 1000 Juice Extractor
One bracket broke. Tried to glue it with no success.
IF YOU ARE TALKING ABOUT THE LATCH ARM, YOU CAN BUY THEM FROM OMEGA AT
717 561 1105. TRICKY TO REPLACE. I REMOVED THE BOTTOM OF THE MACHINE AND
GAINED ACCESS THAT WAY. ONCE YOU SEE THE LATCH ARM SUPPORT PRY IT AWAY
FROM THE JUICER AND SLIDE IT OUT. CALL OMEGA THERE ARE 2 WAYS TO REPLACE
THE LATCH.
Sep 29, 2008 | Omega 1000 Juice Extractor
How to replace latch arm for omega 1000 juicer?
Getting the old one out is the hardest part if the arm was broken off like mine. First locate the rectangular part where the arm attaches to the case. If the old arm, or most of it, is still attached, grasp it and pull firmly away from the case until you hear a click. Then, still pulling it away from the case, push it up toward the top of the case until it slides out. If the arm is broken off you have to pry it from the top until you hear the click. I used a small paring knife. Once you get it this far, wedge something like a toothpick behind it to keep it pulled away from the case. Then you need to push this push this part up. It is pretty tight so you might want to use some type of tool, like the blade of a flat screwdriver. Once you get the old one out, putting the new on in is just the reverse of taking the old one out.
Dec 11, 2007 | Omega 1000 Juice Extractor
Omega 4000 won't start even after reset
LOOK UNDER WHERE YOU PUSH DOWN
ON THE LATCH ARMS TO SECURE THE
LID. ONE ONE SIDE THERE MAY BE A
SMALL INTERLOCKING SWITCH WHICH
WOULD PREVENT THE JUICER FROM
RUNNING WITHOUT THE COVER LOCKED
DOWN. USE A SMALL SCREW DRIVE TO
CORRECT IF MISALIGNED. THE JUICER
ALSO COMES WITH A 15 YEAR WARRANTY, SO OMEGA WILL FIX FOR
FREE.
Oct 31, 2007 | Omega 4000 Juicer
Omega 4000 Juicer Logo
455 people viewed this question
Top Omega Juicers Experts
eyecam
Andrew Taylor
Andrew Taylor
Are you an Omega Juicer Expert? Answer questions, earn points and help others
