Question about Sony Handycam DCR-HC32 Mini DV Digital Camcorder
The LCD panel on the Sony Handycam DCR-HC32 will not light up and no icons are visable. When I turn on the camera, in any of the three modes, it sounds like it is working, but nothing shows up on the LCD screen. I press on the LCD screen as if there were an icon visible and it will play, ff, rwd, but I can't see the picture so I don't know where it is on the tape. Please reply if there is any fix to the camera. Thanks
  • 3 more comments
  • pistolpete2 Dec 11, 2008
    I have the same problem..........
  • wallypmel Dec 31, 2008
    Same video camera, 3 1/2 years of use, totally blank screen out of nowhere but buttons all work. Never had a problem w/ a Sony product before.
  • shirazman Jan 01, 2009
    strange, i have never had a prob with my cam, yesterday it worked fine, this morning wen i turned it on the screen went all white, then to black n nothing since. I view thru viewfinder n see all the buttons there, push the screen and everything works, but no display. Why have all 4 of these problems presented in the past few months, 3 of them in the past 2 weeks?
  • 2cooldogs Jan 01, 2009
    Same problem here. Recently the lighting flickered on my lcd screen of my DCR-HC32 then it was gone. I can still see through the viewfinder, but only when the lcd is closed (against the camera). I can push where the icons used to be and hear it rewind, stop, etc. Camera is 3 years old with minimal use. Sony's flat repair fee is just a few dollars shy of a new purchase, probably more when I add shipping. Any suggestions appreciated!!!
  • jonschwerman Jan 18, 2009
    exactly the same issue -first a few buttons stopped working on the lcd touch screen, then a few weeks later it started getting lines. Now, nothing - no buttons, no screen functioning at all. Viewfinder works, but not the lcd panel. Only about 3 years old, and I thought Sony was the best name out there!!
  • Sony Master
  • 5,412 Answers
Contact Sony service centre
Posted on Jul 03, 2017
  • 473 Answers
SOURCE: Sony TRV-19 Camcorder - Black screen in camera mode
Fixed it, at least temporarily I had the side off my trv250 examining it, especially the CCD connection. I had read the post about soldering a capacitor to pins 1 and 3 (from the left) on the bottom row. I didn't have the specific capacitor on hand, but I started touching some of the small ones I did have to those pins. I found that after I touched a 100uF, 10V cap to pins 1 and 3 the picture suddenly came back to life and stayed that way after removing the cap. I have no idea how long this will last, and I've set up the cam on a tripod in the livingroom with the LCD display facing me so I can monitor it. If you, like me, figure you have nothing else to lose, you might want to give this a try. Note: my camera was suffering from the green smeary horizontal lines problem, and wasn't completely black. I'm not sure if this makes a difference or not.
Posted on Sep 14, 2005
SOURCE: sony handycam dcr-trv19e mini
Thank for that qestion,
At this point, if you are a lay-man or person you need to eject the camcorder and aloud it open and put under sun light for an hour. If its do the same, take it to a technicain.
but if you are a technicain, dismantle the camcorder and put the machinusm under hot tempreture for 20minute. then mount it back and your camcorder will be fine.
I have done this time and again and it has never fail me.
I hope you will smile.
Posted on Jun 11, 2008
SOURCE: Camera
I am assuming you meant your video (not just pictures) - you need a firewire cable - I have same camera - I use a firewire cable (4pins on each end) and connect to my IBM Laptop with Vista - vista does everything else to capture.
If you need to transfer photographs from the flash memory card -- I suggest the best way is to remove the flash memory card and use a USB flash card reader that you can hook up to your computer.
You may be able to do these otherways by installing the Sony software that comes with this camera - or can be downloaded from Sony website.
Posted on Jul 19, 2008
  • 6 Answers
SOURCE: cassette tape will not load
there is a small motor at the lower right corner ( if you face the tape side of the camcorder). check if the motor reponds to a 5v voltage. if not, that is the problem
Posted on Sep 06, 2008
SOURCE: Sony Handycam DCR-TRV330 Digital-8 won't calibrate tapes to be able to view
hi there. i just actually had this problem right now. and heres how i fixed it :) it had the error so i took out the tape left it ejected for about 5 seconds. then put the tape back. it read for a little then errored again so it was close. next what i did is plugged the camera in (last time this error happened i plugged in the power and it fixed it) still no fix so i took off the battery waited 5 seconds then put it back on. after that i ejected the tape again and re put it in and it worked! you could try anyone of those things. and usually they work for me. maybe it has something to do with the cameras being old.
Posted on Oct 21, 2008
SONY HC32 - LCD panel not working when pressing icons. Also, when it does work, the incorrect functions appear for the menu selected
I had similar trouble on my 2nd hand HC32 - turned out to be faulty flex cable that runs between LCD and the main body.
Cost me around 60 USD to fix by non-SONY service shop.Now it works like new.Worth every dime for this outdated camcorder.
Jul 22, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
My Handycam shows a bluish screen(DCR-HC32E)
did you happen to drop the cam? there could be a technical error with the LCD screen. take it to the nearest Sony service center and have them take a look at it. you can try resetting the cam and see if it changes anything.
Jun 11, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
I have a sony dcr-hc32 that when i turn it on i can see throuth the view finder but when i flip open the viewing screen there is no picture and the view finder goe's away. thanks
There is connecting ribbon wire between LCD board and Camera main board and this ribbon wire is cracked and needs to be replaced.
Let me know if you want to replace it at own to provide you part number.
Dec 11, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony Handycam DCR-HC32 Not Working, Not Ejecting Tape, LCD Flicker
DCR-HC32 need new tape mechanism as shown in below exploded view.
Its part number is as follows..
A-1082-424-A MD (Z210) SUB ASSY
Nov 06, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Board dcr-hc 32
dear sir
good evening,
i have bought the sony handycam DCR-HC32. cam is working in order. but there is some problems. that the red colour on LCD is off. what is the reson.
pl explain the fault & repair reson.
thanks
kamal58_asr@yahoo.co.in
Sep 15, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Digital camera
Hello ABBEY ROSE,
I think, its touch-screen control at LCD panel camera and can you see picture in small viewfinder?
May 18, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Display on camera is all red and black with static
call sony support there is a know problem with the cable to the lcd
Feb 26, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Problem with the lcd
Possibble cause can be the broken flat cable between LCD and Main board. Regards, Arpi
Mar 16, 2007 | Sony DCR-HC32 W/ ULTIMATE HC32 HANDYCAM...
Battry Mode not working
If where you put the batteries in are corroded you can use a small file or sand paper to clean them up so you can get better connections hope this helps Merry Christmas
Dec 03, 2017 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony Handycam DCR-HC32 Mini DV Digital Camcorder Logo
96 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
