Question about Canon PIXMA iP1600 Printer
Printer leaves streaks of empty lines while printing
My printer was giving me gud service all until now when its not working properly.Even when it has a new cartridge it wont print properly.All the printouts i get from this printer have spaces or streaks of white lines.Can some1 tell me how to fix this prob??
SOURCE: Black Ink Skipping
If you open the printer so the cartridges move to the center and lift the gray handle so you are able to pull the printer head out. Chances are when you do... you will see all the corrosion. Just clean it off and you should be good to go.
Posted on Dec 05, 2007
SOURCE: Orange light blinking
Hey guys, I finally brought my ip4500, not ip4300 1month ago, and am having the same problem. I experimented with the printer inks. And finally i have fixed this problem. I suspect it may work for ip4300, or other similar pixmas as well. Please follow at your own risk.
Scenario:
The printer error led flashes 15 times. And, The ink tank lights are flashing endlessly, or does not light up at all. If the ink light is off, it does not mean that the chip is corrupt.... Do not replace it, like i have. lol.
Problem: one or more of the inktank chips are corrupt. If at least one cartridge is corrupt, the printer will not work. Must purchase corrupted ink cartridge, or call canon for replacement.
Solution: Instead of buying a complete set of ink, find out which ink cartridge is corrupt, and needs replacing:
1.put all ink tank into the printer without the chip. close printer cover. computer should alert that "the following ink tank cannot be recognised. Printing cannot be executed because the ink tank...." You should see a picture of the ink in the alert box.
The picture in the warning box shows that the black, black. yellow, magenta, cyan are not inserted.
2.Starting with the blue ink, remove blue ink from the printer, reinsert chip into ink tank, then put the ink tank back into the printer. Close Printer cover. Notice that this time, if the ink chip isn't faulty, computer alerts that only black, black, yellow, magenta are not inserted into your printer.
If it is faulty, then you see another alert box, about unrecognized ink - if so go to step 4.
To test if the chips on the other ink cartridges(tanks) are faulty:
3. Repeat step 2, with the rest of the ink tanks. from right to left(blue, magenta, yellow, pgiblack, black)
4. Purchase corrupt ink tank. or call Canon for a replacement.
lemme know if this helps you.
Posted on Mar 19, 2008
Ajkill
  • 2035 Answers
SOURCE: white horizontal streaks in documents
I Am Experiencing Poor Print Quality With My Dell™ Printer
Table of Contents
Verify the Printer Ink Levels Using the Dell Printer Solution Center
Clean the printer contacts and print a test page
Clean the Printer Nozzles Using the Dell Printer Solution Center
Dell™ Printer Additional Information
» Verify the Printer Ink Levels Using the Dell Printer Solution Center
Poor print quality of a document or picture may be the result of low ink levels or dirty printer nozzles or contacts.
To check the printer's ink levels, perform the following steps:
1.
Click the Start button, point to All Programs, point to Dell Printers, and then point to Dell (printer model).
2.
Click Dell Printer Solution Center.
3.
Locate the printer's ink levels on the lower right corner of the Dell Printer Solution Center window.
4.
If the printer's ink levels indicate that ink cartridges are empty, click the Order Ink button to place an online order for replacement ink cartridges.
For information about ordering ink for your Dell printer, refer to article: Obtaining Ink for a Dell™ Printer
Back to Top
» Clean the printer contacts and print a test page
To manually clean the printer nozzles and contacts, perform the following steps:
1.
Turn the printer off and remove the power cord from the back of the printer.
2.
Open the printer lid.
3.
Manually move the ink-cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right hand side of the printer.
4.
Take a warm, semi-damp paper towel and gently clean the wiper on the right side of the maintenance station.
5.
Lift up on the cap(s) that cover the ink cartridge(s).
6.
Remove the ink cartridge(s), and using a new warm, semi-damp paper towel, gently clean the contacts on the ink cartridge(s).
Verify that the contacts on the ink cartridge(s) is/are sufficiently dry prior to re-inserting into the printer.
7.
Re-insert the ink cartridge(s) back into the correct printer slot(s).
7.
Close the printer lid.
8.
Re-attach the printer power cord to the back of the printer unit.
9.
Press the Power button to turn the unit back on.
10.
11.
12.
Click the Maintenance tab.
13.
Click the Print a test page icon.
A test page prints.
Back to Top
» Clean the Printer Nozzles Using the Dell Printer Solution Center
To clean the printer nozzles and contacts using the Dell Printer Solution Center:
1.
2.
3.
4.
Click the Clean to fix horizontal streaks icon.
5.
Click the Print button.
Note:
The printer will make sounds when cleaning the nozzles that are not commonly heard during normal usage
Posted on Mar 21, 2008
SOURCE: Printer will not print black ink
I had the same problem. My color cartridges printed fine, but the black did not print -- just blank. I called Cartridge World and they suggested the problem could be a clogged line. They recommended a nozzle rocket cartridge, sort of a "Drano" for print cartridges. I brought in my black cartridge and they dumped the black ink and filled it with a cleaning solution (at no cost). I placed this back into the printer and proceeded to start printing multiple pages in black in order to allow the solution to move through the lines and break up any clogs. It took about 30 pages, but the light gray color finally began to come through (it should look light gray, not black). I was told to try and use the entire cartridge before replacing with a regular black ink cartridge. Worked great!
Posted on Aug 06, 2008
  • 37 Answers
SOURCE: PIXMA iP6220D doesn't use/recognize CL-51 cartridge
Take the photo ink out.
Posted on Aug 19, 2008
Streaks or lines
Vertical streaks:
Check,which color/s streaks are appearing on print out,remove that cartridge/s check on drum surface for streaks.. if found replace that cartridge/s..check.
Horizontal streaks:
This problem appears when the cartridge/s image drum not rotating properly. Resit the cartridges properly, print 20nos of blank pages, then check.... replace the cartridge..
Dec 29, 2012 | HP Color LaserJet 2600n Printer
When we attempt to print it leaves black streak marks. At first it printed all black and when we went to setup under maintainence we chose alignment and clean cartridges. This worked however we still see...
If an inkjet printer gives white streaks where it should be black, it means the ink is very low, or there is dirt under the nozzles preventing it from printing properly, or, in the case of non original cartridges, ink might be leaking which prevents the bubbles of ink to squirt onto the page.
If the streaks are black where it should be white, is sounds like some dust or fluff below the cartridge leaves ink smears on the page.
Aug 23, 2011 | Lexmark X4650 InkJet Printer
My printer is not working properly. On the test page, not every line prints clearly.....faint and grey compared to other lines. Lines 1, 4, 8, ll, 14, etc. prints very light compared to the other lines. ...
sounds like your heads are all gummed up with dried ink.Is this a older printer or previously used if so run the cleaner that should have come with your printer software. keep running it until clean or bring it to get cleaned.
Feb 22, 2011 | Computers & Internet
"Check Color Cartridge" displays even after replacement of cartridge -though I don't think original cartridge was empty- and stops printer from printing. The new cartridge is installed properly, and...
  1. First, check your cartridges. HP cannot guarantee the quality of remanufactured or refilled cartridges.
  2. Second, make sure your paper is not causing the problem. Paper that does not accept ink well can cause your images to smear or bleed. Plain paper is not the best choice for high-density graphics. Click here to see how to pick the best paper for your project .
  3. If the paper is not the problem and you are using genuine HP cartridges, print a clean test to see if the printer and cartridges are functioning properly. Load the printer with clean, plain, white paper and print a clean test page. To see how to print a clean test page, see your printer's User's Guide , or see HP Deskjet Printers - How To Print Internal Tests , or HP All-in-One Product Family - Printing Self-Test Reports .
  4. Evaluate the clean test page. Different printers produce different pages, but you should recognize elements from the examples below on your test page. In general, cartridge and printer problems are indicated by streaks, missing colors, or wrong colors.
    • Examples from a good printer and cartridges (your test page may not look exactly like this): Figure 1: Solid colors that match color dots on cartridge labelc00059224.gif Figure 2: Pattern unbroken, or broken in only a few placesc00059225.gif
      c00059227.gif If your test page looks more like the good examples above than the bad examples shown in the next two sections below, the printer and cartridges are probably not causing the problem. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - streaked or broken bars or lines Figure 3: Fading, missing, or streaked bar - low-ink or empty cartridge, clogged nozzles, or electrical problemsc00059228.gif
      Figure 4: Color completely missing (magenta bar missing below)c00290898.gif Figure 5: Lines broken randomly - clogged nozzlesc00059231.gif
      Figure 6: Lines broken in pattern - dirty contacts or other electrical problemsc00059232.gif
      Figure 7: Color completely missing (magenta pattern missing below)c00290899.gif If your test page looks like these examples, you probably have a cartridge that is empty, has clogged nozzles, or dirty contacts. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - colors do not match the color dots on the cartridge label (Note: do not compare the test page colors to the colors of the examples on this web page. Your monitor may not display the colors properly). c00059234.gif c00059235.gif If your test page looks like these examples, you probably have a cartridge in which the inks have mixed. Click here to continue troubleshooting .
Oct 26, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
Leaves streaks vertically on paper changed cartridge still there. 2600n printer
when you open the front of the print you will see the streaks on the black transfer sheet.
Close the front door half way or until all the cartridge doors open.
You will see the same streaks on the problem cartridge(s) as on the transfer sheet.
Change that particular cartridge, let the printer recalibrate, and presto streaks are gone.
Feb 13, 2010 | HP Color LaserJet 2600n Printer
HP L7700 officejet printer leaves streaks on black ink lines only. Have cleaned heads repeatedly, changed black and color cartridges - nothing works.
Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Nov 28, 2009 | HP Office Equipment & Supplies
Magicolor 2530 DL
The streaks are typically a sign of a toner drum going bad, or possibly just dirty, or even caused by the toner being low, as you have mentioned it to be. 1 way I know to 'clean' the drums is to have the printer run multiple blank pages. If your software will not allow you to print blank pages, type a single character by using this little trick, hold down the ALT key, and type 2 5 5 on the number pad in a blank text document. This will allow you to print the "blank" document, I would suggest about 10 copies. This should help for a short duration, and doesn't use any toner.
Hope this helps!
Backu
Oct 30, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Occasional streak in a line of text.
cartridge would me nearly empty or the printhead is blocked remove and try to clean gently if no difference then servicing is required.
Aug 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA iP1600 Printer Logo
278 people viewed this question
old marine
old marine
